Cooling tower analysis and design
Hello everyone,
I just graduated with M.S. in Civil Engineering. Can anybody explain or forward links if any regarding analysis and design of cooling tower on roof top?
I want to understand how can wind load be mitigated?
I am designing a 4' steel frame which will be resting on existing beam. The frame will support the cooling tower.
Thank you in advance for your time and help.
-Nishant Joshi
-Nishant Joshi
RE: Cooling tower analysis and design
I want to know how will the wind force transferred to the beam?
Thank you!
I do not know what is kicker assembly. Few questions:
1 - The lateral win pressure will generate shear on the frame?
2 - The overturning moment from chiller should be converted into forces and applied on the frame?
I am getting reactions on the frame which are higher than existing beam capacity in shear. Can I increase the shear capacity by increasing the beam depth, as retrofitting is not an option.
Thank you!
Draw your structure completely and understand the load path; the way the forces make their way to the roof should be self evident, and you should see how, and where, to apply the loads to the frame. It seems like you should speak with you supervisor about some of this if you are confused.
If the beam is existing, how can increasing the beam depth not be a retrofit? If you cannot retrofit the beam, move your frame to an area it can work, such as posting off existing columns, or to a beam that has capacity. If that is not an option, then the owner needs to understand that they need to reinforce the roof.
Thank you so much for your help. I really appreciate it!
