Doubt - Material used in the manufacture of nozzles in the pressure vessels according to ASME VIII -
Good day,
In Which chapter or (UG) standard ASME VIII - Div 1 says the nozzles must be made of metal bars. And never sheet metal. What page? Please. UG - 14?
Thank you.
Thank you.
RE: Doubt - Material used in the manufacture of nozzles in the pressure vessels according to ASME VIII -
Mike
I could use tubes to manufacture nozzle, instead of sheet metal and bars metal?
If yes, I would use tubes,because it will be more economical. Not need machining.
Thank you.
Mike
