Bystronic bystar 4kw
Hi
I have a bystar 4 kW and I am having trouble with 10mm mild steel plate some of the holes will not cut the whole way around just wondering if anyone can help.
Thank you
RE: Bystronic bystar 4kw
I would post the parameters you are using, gas pressures/type, feedrates etc and supply pics if possible, there are some really good expertise here in that area and that info will help them to help you.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
when was the last time you had the optics serviced? can you post a picture of the areas you're having trouble with?
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
I will take some pictures tomorrow it just seems very inconsistent Maybe it is the optics due for a service next week
where are you located?
In nsw Australia
