Error code 928 caught when loading a .prt file in our VC++ application
Hello everyone!
We have one application built on VC++ 2013 with NX 64-bit libraries in order to retrieve NX designs and save into our data.
Recently we found if our application is built with NX9 64-bit library and it works very well. But if it is build with NX10 64-bit library, it cannot load any NX .prt file. The Error Code 928 is caught.
Below is the log file. Any ideas will be really appreciated!
James
*** C:\temp\Inter5904870.syslog
*** system log created by [user name] on Mon Jun 22 18:32:30 2015 Eastern Daylight Time
Node Name :- m4213
Machine type :- GenuineIntel Family 6 Model 10 Stepping 5, Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
OS :- Windows NT (x64) 6.1 Windows 7 Professional (Build 7601) Service Pack 1
:- 64 bit software version
:- Session is running as administrator
# Processors :- 8
:- 1 packages, 4 cores, 8 logical processors
:- cache L1 256Kb / L2 1024Kb / L3 8192Kb
Memory :- 9207Mb
Total Swap :- 18412Mb
Free Swap :- 13773Mb
Machine supports 8TB address space
Running customer environment
Session is running in codeset 1252 17
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\ugxml.dll
UGXML is using 'UTF-8' as the local code page
************** Licensing Information **************
Server ID : ***** - OurCompamy
Webkey Access Code : *******
License File Issuer : SIEMENS
Flex Daemon Version : 11.10
Vendor Daemon Version String : 6.4
Toolkit Version : 6.4.2.1
************** Bundle Information **************
Number of bundles in use : 1
Bundle [ 0 ] : NX41000
Main executable was not signed
Attempting to see if main executable calls into a signed shared library
C:\svn\dev_new\stable_v9.5\Executable2013\x64\Debug\Interface_NX.exe - was not signed
C:\Windows\SYSTEM32\ntdll.dll - was not signed
C:\Windows\system32\kernel32.dll - was not signed
C:\Windows\system32\KERNELBASE.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libufun.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libjam.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsyss.dll - was not signed
C:\Windows\system32\MSVCR110.dll - was not signed
C:\Windows\system32\MSVCP110.dll - was not signed
C:\Windows\system32\ADVAPI32.dll - was not signed
C:\Windows\system32\msvcrt.dll - was not signed
C:\Windows\SYSTEM32\sechost.dll - was not signed
C:\Windows\system32\RPCRT4.dll - was not signed
C:\Windows\system32\USER32.dll - was not signed
C:\Windows\system32\GDI32.dll - was not signed
C:\Windows\system32\LPK.dll - was not signed
C:\Windows\system32\USP10.dll - was not signed
C:\Windows\system32\ole32.dll - was not signed
C:\Windows\system32\ODBC32.dll - was not signed
C:\Windows\system32\MPR.dll - was not signed
C:\Windows\system32\SHLWAPI.dll - was not signed
C:\Windows\system32\SHELL32.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libnxc.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpatch.dll - was not signed
C:\Windows\system32\CRYPT32.dll - was not signed
C:\Windows\system32\MSASN1.dll - was not signed
C:\Windows\system32\WINTRUST.dll - was not signed
C:\Windows\system32\OLEAUT32.dll - was not signed
C:\Windows\system32\WS2_32.dll - was not signed
C:\Windows\system32\NSI.dll - was not signed
C:\Windows\system32\COMDLG32.dll - was not signed
C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\COMCTL32.dll - was not signed
C:\Windows\system32\NETAPI32.dll - was not signed
C:\Windows\system32\netutils.dll - was not signed
C:\Windows\system32\srvcli.dll - was not signed
C:\Windows\system32\wkscli.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libufunx.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcmod.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libann.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcustdef.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugmath.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpman.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdisp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libasmo.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libassy.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libassybox.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdman.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugutils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\PSKERNEL.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\PFKERNEL.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmdpk.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdraw.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libassypos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libevaluator.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgeom.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgeomutil.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfacet.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libocc.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdmapplication.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdmservices.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugmr.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libklo.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfusion.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpart.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpkp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libinterop.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmodl.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfeatutils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartmodl.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcamsmom.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcsfadp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcsf.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmodlmath.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmodlgeom.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartdisp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartutils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgenpos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartnav.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libphymat.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpdi.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsket.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcoreblockdata.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartcommon.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libptr.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libimage.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtable.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\cg.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\cgGL.dll - was not signed
C:\Windows\system32\OPENGL32.dll - was not signed
C:\Windows\system32\GLU32.dll - was not signed
C:\Windows\system32\DDRAW.dll - was not signed
C:\Windows\system32\DCIMAN32.dll - was not signed
C:\Windows\system32\SETUPAPI.dll - was not signed
C:\Windows\system32\CFGMGR32.dll - was not signed
C:\Windows\system32\DEVOBJ.dll - was not signed
C:\Windows\system32\dwmapi.dll - was not signed
C:\Windows\system32\WINSPOOL.DRV - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpgs.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfeaturerecognition.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtceng_utils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfacetstore.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtline.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtemplate.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfasthidden.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libnxpos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\xerces311.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\icuuc51.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\icudt51.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\liblwks.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmd.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\librout.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcompos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libautomotive.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpmi.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmsp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmsputil.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgdt.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmswp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdctkloader.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsbsm.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartmodule.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libuginit.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugmi.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libhm.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libvsweep.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libship.dll - was signed
NX 10.0.0.24
No user customizations read from UGII_PACKAGE_DIR - environment variable is not set
No user customizations read from UGII_SITE_DIR - environment variable is not set
No user customizations read from UGII_GROUP_DIR - environment variable is not set
No user customizations read from UGII_USER_DIR - environment variable is not set
Processing customer default values file C:\Users\[User_Name]\AppData\Local\Siemens\NX100\NX100_user.dpv
User customizations file C:\Users\[User_Name]\AppData\Local\Siemens\NX100\NX100_user.dpv does not exist
Failed to populate drafting standard data in level 1.
Failed to populate drafting standard data in level 2.
Failed to populate drafting standard data in level 3.
Processing drafting standard file C:\Program Files\Siemens\NX 10.0\ugii\drafting_standards\nx_ISO_Drafting_Standard_Shipped.dpv
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\application\liblinedesignerschemalocator.dll
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\application\liblinedesignerjalocator.dll
UPDATE: predefined fail option is <Unknown>
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libattr.dll
3D DCM version 480302004
Threaded compress ON decompress ON compression level 1
FR_PSMARK: system page size = 4096, ram block size = 1024, disk file threshold =32769, buffer size = 16384
*** Enabling SMP using 4 threads on 8 processors ***
Parasolid version 27.0 build 178 on 19:45:03 16-08-2014
CMOD delete: predefined, dumbify-feature option is <TRUE>
CMOD delete: predefined, propagate-delete option is <ON>
CMOD update: predefined, fail-on-missing-refs option is <OFF>
2D DCM version 630001001
Descriptive Part Names set to $FILENAME
Assemblies: Model reference set defined to be MODEL.
Lightweight Customer Defaults: Smart is disabled, Remove All
Parsing Ship Recipes file: C:\Program Files\Siemens\NX 10.0\nxship\data\ShipNamesRecipes.xml
Successfully parsed Ship Names Recipe of type Hull.
Successfully parsed Ship Names Recipe of type Deck.
Successfully parsed Ship Names Recipe of type Longitudinal Bulkhead.
Successfully parsed Ship Names Recipe of type Transverse Bulkhead.
Successfully parsed Ship Names Recipe of type Pillar System.
Successfully parsed Ship Names Recipe of type Stiffener System.
Successfully parsed Ship Names Recipe of type Edge Reinforcement System.
Successfully parsed Ship Names Recipe of type Seam.
Successfully parsed Ship Names Recipe of type Generic Plate System.
Successfully parsed Ship Names Recipe of type Standard Part.
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libnxvtk.dll
Command line:
A master env file has not been loaded
************** Locked Unigraphics Configuration Variables **************
UGII_PRODUCT_NAME NX
UGII_VERSION v10
UGII_FULL_VERSION v10.0.0.24
UGII_MAJOR_VERSION 10
UGII_MINOR_VERSION 0
UGII_SUBMINOR_VERSION 0
************** System Environment Variables **************
Path C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Siemens\NX 10.0\UGII\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;c:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\HP\Digital Imaging\bin;C:\Program Files (x86)\HP\Digital Imaging\bin\;C:\Program Files (x86)\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\TortoiseSVN\bin;c:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files (x86)\Intel\Compiler\Fortran\10.0.026\IA32\Bin\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
SPLM_LICENSE_SERVER 28000@m4213
TEMP C:\Users\[User_Name]\AppData\Local\Temp
TMP C:\Users\[User_Name]\AppData\Local\Temp
UGII_3DCONNEXION_LIBRARY C:\Program Files\Siemens\NX 10.0\ugalliance\vendor\startup\3DxNX.dll
UGII_BASE_DIR C:\Program Files\Siemens\NX 10.0
UGII_KEEP_SYSTEM_LOG YES
UGII_LANG english
UGII_ROOT_DIR C:\Program Files\Siemens\NX 10.0\UGII\
UGII_TMP_DIR C:\temp
UGII_UGDOC_BASE http:\\localhost:8181
UGS_LICENSE_SERVER 28000@m4213
UGS_LICENSING_NOTE on
USERDNSDOMAIN [User_DNS_domain_Name]
USERDOMAIN [User_domain_Name]
USERNAME [User_Name]
USERPROFILE C:\Users\[User_Name]
Using ugii_env.dat file from C:\Program Files\Siemens\NX 10.0\UGII\\ugii_env.dat
Using LineDesigner_env.dat file from C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\manifest\LineDesigner_env.dat
Using ugii_env_ug.dat file from C:\Program Files\Siemens\NX 10.0\UGII\\ugii_env_ug.dat
************** Unlocked Unigraphics Configuration Variables **************
UGCHECKMATE_HIDE_CHECKER %mqc_report_blanked_entity
PATH C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Siemens\NX 10.0\UGII\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;c:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\HP\Digital Imaging\bin;C:\Program Files (x86)\HP\Digital Imaging\bin\;C:\Program Files (x86)\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\TortoiseSVN\bin;c:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files (x86)\Intel\Compiler\Fortran\10.0.026\IA32\Bin\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\
UGII_PLATFORM x64wnt
HOME C:\Users\[User_Name]\AppData\Local\Temp
UGII_LANG english
UGII_LOCALIZATION_FILES C:\Program Files\Siemens\NX 10.0\localization\translations
GEARWIZARD_DIR C:\Program Files\Siemens\NX 10.0\localization\\GearWizard
GC_TOOL_DIR C:\Program Files\Siemens\NX 10.0\localization\\gc_tools
UGII_08_FILE C:\Program Files\Siemens\NX 10.0\ugopen\08.ugf
UGII_10_FILE C:\Program Files\Siemens\NX 10.0\ugii\10.ugf
UGII_SCHEMA C:\Program Files\Siemens\NX 10.0\ugii\ugschema
UGII_ENGLISH_THREADS C:\Program Files\Siemens\NX 10.0\ugii\thd_english.dat
UGII_METRIC_THREADS C:\Program Files\Siemens\NX 10.0\ugii\thd_metric.dat
UGII_OLD_SKETCH 0
UGII_DUMBIFY_FEATURE 1
UGII_WAVE_DELETE 0
MOLDWIZARD_DIR C:\Program Files\Siemens\NX 10.0\moldwizard
MOLDWIZARD_LIB_DIR C:\Program Files\Siemens\NX 10.0\moldwizard
ELECTRODE_DESIGN_DIR C:\Program Files\Siemens\NX 10.0\moldwizard\electrode
PDIEWIZARD_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\pdiewizard
PDIEWIZARD_LIB_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\pdiewizard
TOOLING_BASE_DIR C:\Program Files\Siemens\NX 10.0\tooling_base
EDIEWIZARD_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\ediewizard
EDIEWIZARD_LIB_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\ediewizard
UGWELD_DIR C:\Program Files\Siemens\NX 10.0\ugweld
UGII_WELD_BASE_DIR C:\Program Files\Siemens\NX 10.0\ugweld
UGII_UDF_LAYER_ORIGINAL 0
UGII_INOP_SE_IMPORT_ONLY_DESIGN_PART 0
NXDESIGNTOOLS_DIR C:\Program Files\Siemens\NX 10.0\design_tools
UGCHECKMATE_DIR C:\Program Files\Siemens\NX 10.0\design_tools\checkmate
UGCHECKMATE_CONFIG C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\customization\ugcheckmate.dat
UGCHECKMATE_XMLLOG_XSL_FILE C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\examples\checkmate_log.xsl
UGCHECKMATE_MENU_TEMPLATE_FILE C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\templates\user_defined_menu_template.txt
NXCHECKMATE_LOCALIZATION_DIR C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\localization
NXREQUIREMENT_DIR C:\Program Files\Siemens\NX 10.0\design_tools\requirement
NXISSUETRACKING_DIR C:\Program Files\Siemens\NX 10.0\design_tools\issue_tracking
NXMARKUP_DIR C:\Program Files\Siemens\NX 10.0\design_tools\markup
UGII_CAM_BASE_DIR C:\Program Files\Siemens\NX 10.0\mach\
UGII_CAM_CUSTOM_DIR C:\Program Files\Siemens\NX 10.0\mach\custom\
UGII_CAM_RESOURCE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\
UGII_CAM_SAMPLES_DIR C:\Program Files\Siemens\NX 10.0\mach\samples\
UGII_CAM_AUXILIARY_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\
UGII_APT_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\apt.voc
UGII_BCL_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\bcl.voc
UGII_ISO_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\iso.voc
UGII_UNIMAJ_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\unimaj.voc
UGII_UNIMIN_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\unimin.voc
UGII_VERICUT C:\Program Files\Siemens\NX 10.0\win_nt\commands\vericut.bat
UGII_CAM_THREAD_MILL_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\thread_mill\
UGII_CAM_THREAD_MILL C:\Program Files\Siemens\NX 10.0\mach\auxiliary\thread_mill\thrm.dll
UGII_CAM_BATCH_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\batch\
UGII_CAMBATCH_BACKGROUND_EXE C:\Program Files\Siemens\NX 10.0\mach\auxiliary\batch\cambatch_background.exe
UGII_CAM_TAGGING_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\
UGII_CAM_TAGGING_DLL_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\application\
UGII_CAM_TAGGING_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\english\
UGII_CAM_TAGGING_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\metric\
UGII_CAM_FILE_SEARCH_PATH .\;C:\Program Files\Siemens\NX 10.0\mach\;C:\Program Files\Siemens\NX 10.0\mach\resource\
UGII_CAM_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\
UGII_CAM_CONFIG C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\cam_general.dat
UGII_SHOPS_DIE_MOLD_CONFIG C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\shops_diemold.dat
UGII_SHOPS_MACHINERY_CONFIG C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\shops_machinery.dat
UGII_CAM_TEMPLATE_SET_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_set\
UGII_CAM_TEMPLATE_PART_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\
UGII_CAM_TEMPLATE_PART_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\
UGII_CAM_TEMPLATE_PART_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\
UGII_CAM_TEMPLATE_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\images\
UGII_CAM_LIBRARY_TEMPLATE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_dir\
UGII_CAM_LIBRARY_TEMPLATE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_dir\
UGII_CAM_SHOP_DOC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\shop_doc\
UGII_CAM_PART_DOC_CONFIG_FILE C:\Program Files\Siemens\NX 10.0\mach\resource\shop_doc\shop_doc.dat
UGII_CAM_POST_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\
UGII_CAM_POST_CONFIG_FILE C:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\template_post.dat
UGII_CAM_LIBRARY_MACHINE_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\
UGII_CAM_USER_DEF_EVENT_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\user_def_event\
UGII_CAM_TOOL_PATH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\tool_path\
UGII_CAM_WIZARD_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\wizard\
UGII_CAM_DEBUG_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\debug\
UGII_CAM_DEFAULT_TYPE_TEMPLATE C:\Program Files\Siemens\NX 10.0\mach\resource\template_set\cam_general.opt
UGII_CAM_IMAN_TYPE_TEMPLATE C:\Program Files\Siemens\NX 10.0\mach\resource\template_set\cam_teamcenter_general.opt
UGII_CAM_FEATURE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\
UGII_CAM_FEATURE_DATA_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\english\
UGII_CAM_FEATURE_DATA_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\metric\
UGII_CAM_FEATURE_IMAGES_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\images\
UGII_CAM_SPREADSHEET_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\spreadsheet\
UGII_CAM_MACHINING_KNOWLEDGE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\machining_knowledge\
UGII_UG_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\ug_library\
UGII_CAM_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\
UGII_CAM_LIBRARY_TOOL_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\
UGII_CAM_LIBRARY_TOOL_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\ascii\
UGII_CAM_LIBRARY_TOOL_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\genius\
UGII_CAM_LIBRARY_TOOL_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\inclass\
UGII_CAM_LIBRARY_TOOL_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\english\
UGII_CAM_LIBRARY_TOOL_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\metric\
UGII_CAM_LIBRARY_TOOL_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\graphics\
UGII_CAM_LIBRARY_TOOL_ASCII_LOAD_LIMIT 100000
UGII_CAM_LIBRARY_DEVICE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\
UGII_CAM_LIBRARY_DEVICE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\ascii\
UGII_CAM_LIBRARY_DEVICE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\ascii\
UGII_CAM_LIBRARY_DEVICE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\inclass\
UGII_CAM_LIBRARY_DEVICE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\graphics\
UGII_CAM_LIBRARY_MACHINE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\
UGII_CAM_LIBRARY_MACHINE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\ascii\
UGII_CAM_LIBRARY_MACHINE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\ascii\
UGII_CAM_LIBRARY_MACHINE_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\genius\
UGII_CAM_LIBRARY_MACHINE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\inclass\
UGII_CAM_LIBRARY_MACHINE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\graphics\
UGII_CAM_LIBRARY_INSTALLED_MACHINES_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\installed_machines\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\ascii\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\ascii\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\genius\
UGII_CAM_LIBRARY_UDF_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\udf\
UGII_UG_LIBRARY_GENIUS_TCP_HOST localhost
UGII_UG_LIBRARY_GENIUS_TCP_PORT 2326
UGII_INSPECTION_BASE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\
UGII_INSPECTION_RESOURCE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\
UGII_INSPECTION_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\configuration\
UGII_INSPECTION_CONFIG C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\configuration\inspection_general.dat
UGII_INSPECTION_USER_DEF_EVENT_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\user_def_event\
UGII_INSPECTION_TEMPLATE_SET_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_set\
UGII_INSPECTION_TEMPLATE_PART_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\
UGII_INSPECTION_TEMPLATE_PART_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\
UGII_INSPECTION_TEMPLATE_PART_METRIC_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\
UGII_INSPECTION_POST_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\postprocessor\
UGII_INSPECTION_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\
UGII_INSPECTION_LIBRARY_TOOL_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\
UGII_INSPECTION_LIBRARY_TOOL_ASCII_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\ascii\
UGII_INSPECTION_LIBRARY_TOOL_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\genius\
UGII_INSPECTION_LIBRARY_TOOL_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\inclass\
UGII_INSPECTION_LIBRARY_TOOL_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\english\
UGII_INSPECTION_LIBRARY_TOOL_METRIC_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\metric\
UGII_INSPECTION_LIBRARY_TOOL_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\graphics\
UGII_INSPECTION_LIBRARY_DEVICE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\
UGII_INSPECTION_LIBRARY_DEVICE_DATA_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\ascii\
UGII_INSPECTION_LIBRARY_DEVICE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\ascii\
UGII_INSPECTION_LIBRARY_DEVICE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\inclass\
UGII_INSPECTION_LIBRARY_DEVICE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\graphics\
UGII_INSPECTION_LIBRARY_MACHINE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\
UGII_INSPECTION_LIBRARY_MACHINE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\ascii\
UGII_INSPECTION_LIBRARY_MACHINE_DATA_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\ascii\
UGII_INSPECTION_LIBRARY_MACHINE_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\genius\
UGII_INSPECTION_LIBRARY_MACHINE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\inclass\
UGII_INSPECTION_LIBRARY_MACHINE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\graphics\
UGII_INSPECTION_LIBRARY_INSTALLED_MACHINES_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\installed_machines\
UGII_KF_CLASS_DIR C:\Program Files\Siemens\NX 10.0\ugii\dfa
UGII_TAB_LABEL_FORMATS_FILE C:\Program Files\Siemens\NX 10.0\ugii\tab_label_format_file.xml
UGII_PMI_SYMBOL_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\ugii\symbol\PMI_Symbols
UGII_CGM_DEFAULTS C:\Program Files\Siemens\NX 10.0\ugii\cgmdef.txt
UGII_HELP_RELEASE_NOTES http:\\localhost:8181/tdoc/nx/10/release_notes/#uid:index
UGII_HELP_WHATS_NEW http:\\localhost:8181/tdoc/nx/10/whatsnew/#uid:index
UGII_HTML_UGDOC http:\\localhost:8181/tdoc/nx/10/nx_help/#uid:index
UGII_CSHELP_MAPS C:\Program Files\Siemens\NX 10.0\ugii\docmaps
UGII_CSHELP_DOCS http:\\localhost:8181/tdoc/nx/10/nx_help
UGII_CSHELP_API_DOCS http:\\localhost:8181/tdoc/nx/10/nx_api
UGII_CSHELP_DEFAULTS_DOCS http:\\localhost:8181/data_services/resources/nx/10/nx_help/en_US/graphics/fileLibrary/nx/cust_defaults/
UGII_CSHELP_FUSION_DOCS http:\\localhost:8181/data_services/resources/nx/10/nx_api/en_US/graphics/fileLibrary/nx/fusion/
UGII_LEARNING_CFM_URL https://www.siemens.com/plm/LearningAdvantage
UGALLIANCE_DIR C:\Program Files\Siemens\NX 10.0\ugalliance
UGII_DEFAULT_MENU_DIR C:\Program Files\Siemens\NX 10.0\ugii\menus
UGII_CUSTOM_DIRECTORY_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\custom_dirs.dat
UGII_UG_CUSTOM_DIRECTORY_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\ug_custom_dirs.dat
UGII_MAIN_MENU_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\ug_main.men
UGII_VIEW_POPUP_MENU_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\ug_view_popup.men
UGII_PMAN_XML_DEF_DIR C:\Program Files\Siemens\NX 10.0\LOCALIZATION
UGII_LOCAL_USER_DEFAULTS C:\Users\[User_Name]\AppData\Local\Siemens\NX100\NX100_user.dpv
UGII_CHARACTER_FONT_DIR C:\Program Files\Siemens\NX 10.0\ugii\ugfonts
UGII_CHARACTER_FONT_DEFAULT blockfont
UGII_EDITOR notepad
UGII_LIB1 C:\Users\[User_Name]\AppData\Local\Temp
UGII_LIB2 C:\Program Files\Siemens\NX 10.0\ugii\
UGII_UTIL C:\Program Files\Siemens\NX 10.0\ugii\
UGII_TAPEBAUD 1200
UGII_UGMX C:\Program Files\Siemens\NX 10.0\ugmx\me\etc\startmcad
UGII_MXUG_FILE C:\Users\[User_Name]\AppData\Local\Temp\
UGII_UGMX_FILE C:\Users\[User_Name]\AppData\Local\Temp\
UGII_SHARE C:\Program Files\Siemens\NX 10.0\UGII\
UGII_SPREADSHEET C:\Program Files\Siemens\NX 10.0\ugii\
UGII_LOAD_OPTIONS
UGII_PHYS_MATERIAL_LIB_DIR C:\Program Files\Siemens\NX 10.0\ugii\materials\english\
UGII_PHYS_MATERIAL_LIB_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugii\materials\
UGII_PHYS_MATERIAL_LIB_PATH .\;C:\Program Files\Siemens\NX 10.0\ugii\materials\
UGII_CAE_REPORT_TEMPLATES_DIR C:\Program Files\Siemens\NX 10.0\UGSTRUCTURES\
UGII_CAE_POST_TEMPLATE_USER_DIR C:\Users\[User_Name]\AppData\Local\Temp\post_template_files
USER_GEO_UNF *C:\Program Files\Siemens\NX 10.0\unfold\flatpat.grx
USER_PUNCHTOOLS *C:\Program Files\Siemens\NX 10.0\punchpress\buildtool.grx
USER_PUNCH *C:\Program Files\Siemens\NX 10.0\punchpress\punchlaser.grx
USER_PUNCHGRID *C:\Program Files\Siemens\NX 10.0\punchpress\punchgrid.grx
USER_PDAIF C:\Program Files\Siemens\NX 10.0\ugpatif\ugpatif
USER_ICADIF C:\Program Files\Siemens\NX 10.0\icadif\uficad
UNC_LANG eng
UNC_CAM_DIR C:\Program Files\Siemens\NX 10.0\sheetmfg\unc\
UGII_UGSMD_STDS_LIBRARY C:\Program Files\Siemens\NX 10.0\ugii\
UGII_ROUTE_UGMANAGER_MODE FALSE
UGII_ROUTE_ELEC_KIT_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec
UGII_ROUTE_MECH_KIT_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech
UGII_ROUTE_LGCL_KIT_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech
UGII_ROUTING_KIT_UNITS metric
UGII_ROUTING_APP_VIEW_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\appview\
UGII_ROUTE_ELEC_APP_VIEW C:\Program Files\Siemens\NX 10.0\ugroute_elec\appview\ugroute_elec_metric.xml
UGII_ROUTE_MECH_APP_VIEW C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\ugroute_mech_metric.xml
UGII_ROUTE_LGCL_APP_VIEW C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\ugroute_lgcl_metric.xml
UGII_EPLIB_PART_LIB_VIEW_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\appview\
UGII_EPLIB_TABLE_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\tables\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\tables\
UGII_ROUTE_ELEC_PART_PATH C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\parts
UGII_ROUTE_MECH_PART_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\parts
UGII_ROUTE_LGCL_PART_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\parts
UGII_ROUTING_DESIGN_RULES_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\rules\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\rules\
UGII_ROUTE_ELEC_TCL_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec\rules\tcl\
UGII_ROUTE_MECH_TCL_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\rules\tcl\
UGII_ROUTE_LGCL_TCL_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\rules\tcl\
UGII_RLIST_PATH C:\Program Files\Siemens\NX 10.0\ugroute_elec\rlist\
UGII_FMBD_FORMATS_FILE C:\Program Files\Siemens\NX 10.0\ugroute_elec\rlist\fmbd_annotation.fmt
UGII_FMBD_USE_LAYOUTS FALSE
UGII_FMBD_PATTERN_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\parts
UGII_FMBD_CGM_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\parts
UGII_FMBD_DISABLE_ROTATION_VECTOR_ALIGNMENT FALSE
UGII_RLIST_SCHEMA_FILE C:\Program Files\Siemens\NX 10.0\ugroute_elec\rlist\routelist.xsd
UGII_ROUTING_BOM_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\parts\
UGII_ROUTING_BEND_TABLES_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\tables\
UGII_ROUTE_SKIP_ENGAGE_CHARX TRUE
UGII_ROUTE_SKIP_LENGTH_ADDITION_CHARX TRUE
UGII_ROUTE_SKIP_ROUTING_LEVEL_CHECKING TRUE
UGII_ROUTE_CONVERT_SLACK_TO_LOCK_LENGTH TRUE
UGII_MECH_ROUTE_ISOGEN_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\isogen\
UGII_MECH_ROUTE_ISOGEN_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\isogen\\data\
MAYA_PCB_DIR C:\Program Files\Siemens\NX 10.0\ugpcbxchange
UGII_REFL_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugii\ugvisuals\
UGII_TEXTURE_TIFF_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugstudio\
UGII_NO_TIFF_SEARCH
UGII_LI_TOP C:\Program Files\Siemens\NX 10.0\ugphoto\ray_traced_studio
UGII_LI_CLBIN_DIR C:\temp
UGII_LI_LAYLA_DIR C:\Program Files\Siemens\NX 10.0\ugphoto
UGII_RENDER_ARTISTIC_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\artistic_render\
UGII_SHOWROOM_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\ug_environment
UGII_USER_SHOWROOM_DATA_DIR
UGII_CANNED_MATERIAL_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\ug_canned_mattex
UGII_HDR_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\hdr_images
UGII_ENV_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\env_images\
UGII_SYSTEM_SCENE_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\system_scene_data_dir
UGII_TRUESHADING_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\true_shading
UGII_MAX_FACETING_SCALE 125.0
UGII_SDI_BASE C:\Program Files\Siemens\NX 10.0\nxplot
UGII_CGM2PDF C:\Program Files\Siemens\NX 10.0\nxplot\bin\pdf
UGII_SDI_OUTPUT_DIR C:\temp
UGII_SDI_PS_PAGE_SIZE 1
UGII_SDI_ALLOW_LARGE_TIF 1
UGII_SDI_EXPORT_NEW 1
STEP203UG_DIR C:\Program Files\Siemens\NX 10.0\step203ug\
STEP214UG_DIR C:\Program Files\Siemens\NX 10.0\step214ug\
DXFDWG_DIR C:\Program Files\Siemens\NX 10.0\dxfdwg\
IGES_DIR C:\Program Files\Siemens\NX 10.0\iges\
UGTO2D_DIR C:\Program Files\Siemens\NX 10.0\ugto2d\
UGII_CATIA_DIR C:\Program Files\Siemens\NX 10.0\ugcatia\
UGII_CATIAV5_DIR C:\Program Files\Siemens\NX 10.0\catiav5\
UGII_NXPROE_DIR C:\Program Files\Siemens\NX 10.0\nxproe\
UGII_SW_SCHEMA C:\Program Files\Siemens\NX 10.0\ugii
UGII_SW_LIBRARY C:\Program Files\Siemens\NX 10.0\ugii\CrossCadWareX64.dll
UGII_UGMANAGER_DIR C:\Program Files\Siemens\NX 10.0\ugmanager\
UGII_MSC_NASTRAN C:\Program Files\msc\bin\nastran.exe
UGII_NX_NASTRAN C:\Program Files\Siemens\NX 10.0\nxnastran\bin\nastran64L.exe
UGII_MSC_NASTRAN_VERSION 2005
UGII_NX_NASTRAN_VERSION 10
UGII_ANSYS C:\Program Files\ansys_inc\ansys100\win\v100\ANSYS\bin\intel\ansys100.exe
UGII_ANSYS_VERSION 10
UGII_ANSYS_PRODUCT ane3fl
UGII_ABAQUS C:\Program Files\abaqus\win\6.6-2\exec\abq662.exe
UGII_ABAQUS_VERSION 6.6
UGII_TMG_DIR C:\Program Files\Siemens\NX 10.0\nxcae_extras\tmg
UGII_MONITOR_DIR C:\Program Files\Siemens\NX 10.0\nxcae_extras\tmg\exe
UGII_CONVERT_OLD_MOTION_CONTACTS 0
UGII_CREATE_OLD_MOTION_CONTACTS 0
UG_IMAGE ugspawn.bat
UGII_USERFCN C:\Program Files\Siemens\NX 10.0\ugopen
UGII_GDT_DIR C:\Program Files\Siemens\NX 10.0\ugii\gdt_files
QUICKSTACK_DIR C:\Program Files\Siemens\NX 10.0\tolstackup\ugquickstack
UGII_QS_DEFS_DIR C:\Program Files\Siemens\NX 10.0\tolstackup\ugquickstack\application
TOLSTACKUP_DIR C:\Program Files\Siemens\NX 10.0\tolstackup
UGII_TSV_DEFS_DIR C:\Program Files\Siemens\NX 10.0\tolstackup\application
UGII_ANNOTATION_TEMPLATE_DIR C:\Program Files\Siemens\NX 10.0\ugii\inh_files\
UGII_TABLE_TEMPLATES C:\Program Files\Siemens\NX 10.0\ugii\table_files\
UGII_UPDATE_ALL_ID_SYMBOLS_WITH_PLIST 1
UGII_SURFACE_FINISH OFF
UGII_VSAEXPORT_DIR C:\Program Files\Siemens\NX 10.0\ugvsaexport
UF_MF_PA_PATH C:\moldflow\mpa300\bin
UF_MF_PA_FACET_TOL 0.05
UF_MF_PA_MAX_EDGE 10.0
UF_MF_PA_STL_DIR
UF_MF_PA_STL_SUF slp
UGII_FEAT_FAILURE_REPORT_TEMPLATE_FILE C:\Program Files\Siemens\NX 10.0\UGII\\xsl\FeatureFailureReportTemplate.xsl
UGII_ONESTEP_ANALYSIS_TEMPLATE_FILE C:\Program Files\Siemens\NX 10.0\UGII\\xsl\OnestepAnalysisTemplate.xsl
UGAUTOMOTIVE_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive
UGBODYDES_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\bodydes
UGDIEDES_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\diedes
UGDIEENG_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\dieeng
UG_VPACK_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging
AUTOSTAMPING_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\diedes
UGII_VD_WS_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_spreadsheet.xls
UGII_VD_WS_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_text.xml
UGII_VD_APO_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\a_pillar_obstruction_requirement_spreadsheet.xls
UGII_VD_APO_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\a_pillar_obstruction_requirement_text.xml
UGII_VD_MC_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\mirror_certification_requirement_spreadsheet.xls
UGII_VD_MC_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\mirror_certification_requirement_text.xml
UGII_VD_DFV_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\direct_field_view_requirement_spreadsheet.xls
UGII_VD_DFV_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\direct_field_view_requirement_text.xml
UGII_VD_DP_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\driver_posture_requirement_spreadsheet.xls
UGII_VD_DP_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\driver_posture_requirement_text.xml
UGII_VD_JOINT_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\manikin_joint_angle_requirement_spreadsheet.xls
UGII_VD_JOINT_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\manikin_joint_angle_requirement_text.xml
UGDIEDES_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\diedes
NXSHIP_DIR C:\Program Files\Siemens\NX 10.0\nxship
NXSHIP_GSD_DIR C:\Program Files\Siemens\NX 10.0\nxship\shipgsd
NXSHIP_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\nxship\data
UGII_PYTHON_HOME C:\Program Files\Siemens\NX 10.0\ugii\python
UGII_PYTHON_DLL python33.dll
UGII_PYTHON_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\ugii\python
UGII_PYTHONPATH C:\Program Files\Siemens\NX 10.0\ugii\python;C:\Program Files\Siemens\NX 10.0\ugii\python\Python33.zip
JK_KIT C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit
JK_KIT_DEV C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit
JK_KIT_PLATFORM nt4
PYTHONPATH C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit\lib\python2.5;C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit\library\script;C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit\lib
UGII_BACKGROUND_URL C:\Program Files\Siemens\NX 10.0\UGTIPS\background\english\background.html
OT_PUB_APPLICATION_DIR C:\Program Files\Siemens\NX 10.0\pvtrans\ot_pub
UGII_DOTNET_USE_USER_DEFINED_KEYS 1
UGII_JVM_LIBRARY_DIR \bin\server
UGII_JVM_OPTIONS
UGII_CLASSPATH
PVTRANSUI_DIR C:\Program Files\Siemens\NX 10.0\pvtrans
UGII_DRAFTING_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\drafting_standards
UGII_LOCAL_USER_DRAFTING_STANDARD_DIR C:\Users\[User_Name]\AppData\Local\Siemens\NX100
UGII_PMI_DIR C:\Program Files\Siemens\NX 10.0\ugii\pmi
UGII_CAE_AFUAPP C:\Program Files\Siemens\NX 10.0\ugstructures\ftk\afuapp.jar
UGII_SCREW_CLEARANCE_HOLE_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\modeling_standards
UGII_THREADED_HOLE_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\modeling_standards
UGII_ENABLE_HOLE_SERIES 1
UGII_DRILL_SIZE_HOLE_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\modeling_standards
UGII_DRAWING_COMPARE_OUTPUT_XML 0
UGII_SHIP_DRAFTING_DIR C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting
UGII_SHIP_DRAFTING_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\application
UGII_SHIP_DRAFTING_ANNOTATION_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_annotation_mapping_file.xml
UGII_SHIP_DRAFTING_AREACENTERLINES_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_area_centerline_mapping_file.xml
UGII_SHIP_DRAFTING_DRAFTINGLINES_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_drafting_line_mapping_file.xml
UGII_SHIP_DRAFTING_SYMBOLS_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_symbols_mapping_file.xml
UGII_SHIP_DRAFTING_ANNOTATION_SYMBOLS C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\symbol\ug_drafting_shipbuilding_default_symbols.sbf
UGII_TC_SOA_VERSION TC11000.1.0
NXREPORTS_DIR C:\Program Files\Siemens\NX 10.0\nxreports
NXVISUALREPORTING_DIR C:\Program Files\Siemens\NX 10.0\nxreports\visual_reporting
UGII_STEREO 1
UGII_STEREO_DISABLES_UI_TRANSPARENCY 1
UGII_STEREO_ADJUST_PERSPECTIVE_AUTOMATICALLY 1
UGII_LEGACY_TOL_FEAT_SETTINGS 0
UGII_ENABLE_TS_UPDATE_FOR_SLIVER_REGIONS 0
LOCALAPPDATA C:\Users\[User_Name]\AppData\Local
UGII_LANG english
LINE_DESIGNER_APP_DIR C:\Program Files\Siemens\NX 10.0\line_designer
NX_VERSION=10.0.0.24
Versions of DLLs are:
c:\program files\siemens\nx 10.0\ugii\dbghelp.dll 6.11.1.404 6e4c0000 169000 3678414c-4cb6b373-ddc11881-91f03434-1 18-Nov-2014 21:46
c:\program files\siemens\nx 10.0\ugii\pvmtoolkit.dll 0.27.0.70 7fed4380000 427000 0-0-0-0-0 18-Nov-2014 22:14
c:\program files\siemens\nx 10.0\ugii\vtk.dll 0.11.4.12 7fed47b0000 335000 0-0-0-0-0 18-Nov-2014 21:43
c:\program files\siemens\nx 10.0\ugii\libnxvtk.dll 10.0.0.24 7fed4af0000 d0000 49cf7f0f-4bb500e0-c7b290-dffcc72d-1=libnxvtk___1416455362cyp 19-Nov-2014 23:49
c:\program files\siemens\nx 10.0\ugii\libhidl.dll 10.0.0.24 7fed4d40000 54000 c9b3b954-4479df83-c9d8aa0-7ac35b91-1=libhidl___1416455823cyp 19-Nov-2014 23:57
c:\program files\siemens\nx 10.0\ugii\libattr.dll 10.0.0.24 7fed4bc0000 b1000 de36ac92-472a8614-f8f317b3-5444ff0b-1=libattr___1416456751cyp 20-Nov-2014 0:12
c:\program files\siemens\nx 10.0\line_designer\application\liblinedesignerjalocator.dll 10.0.0.24 7feeeec0000 d000 1c766765-457219ca-680f41a8-4d30fe7a-1=liblinedesignerjalocator___1416455666cyp 19-Nov-2014 23:54
c:\program files\siemens\nx 10.0\line_designer\application\liblinedesignerschemalocator.dll 10.0.0.24 7feeeed0000 7000 8ae8e712-4f5be8db-7f6be185-e860eff-1=liblinedesignerschemalocator___1416454626cyp 19-Nov-2014 23:37
c:\windows\system32\wship6.dll 6.1.7600.16385 7fefcc60000 7000 be71ccca-4d102676-1b946e83-d2c9de34-2 14-Jul-2009 1:41
c:\windows\system32\dhcpcsvc.dll 6.1.7600.16385 7fef7ec0000 18000 8dc91c79-44329e40-d41461ab-5d8c8d77-2 14-Jul-2009 1:40
c:\windows\system32\dhcpcsvc6.dll 6.1.7601.17970 7fef7ef0000 11000 4463cba8-447cf16f-e08fd585-1beea6ec-2 09-Oct-2012 18:17
c:\windows\system32\icmp.dll 6.1.7600.16385 733a0000 3000 55994337-48cf1b83-e8abb797-a37a1423-2 14-Jul-2009 1:27
c:\program files\siemens\nx 10.0\ugii\ugxml.dll 10.0.0.24 7fed4da0000 21000 7085b88f-4825056f-3e3169ab-31f441d7-1=ugxml___1416454537cyp 19-Nov-2014 23:35
c:\windows\system32\ntdsapi.dll 6.1.7600.16385 7fef9180000 27000 9e965c81-42fe0277-29adefae-fe8e75f7-2 14-Jul-2009 1:41
c:\windows\system32\wbem\fastprox.dll 6.1.7600.16385 7fef6bd0000 e2000 c00ea070-487950c6-aba4d88c-e21af810-2 14-Jul-2009 1:40
c:\windows\system32\wbem\wbemsvc.dll 6.1.7600.16385 7fef6a80000 14000 dfe6ffac-4abb97b2-fb7e25a9-356777e-2 14-Jul-2009 1:41
c:\windows\system32\wbemcomn.dll 6.1.7601.17514 7fef87b0000 86000 3a1fa1e9-49ea0abe-bad06cb9-ff424b85-2 20-Nov-2010 13:27
c:\windows\system32\wbem\wbemprox.dll 6.1.7600.16385 7fef8840000 f000 901a9329-4c144bba-1a530fab-8a3c0cad-2 14-Jul-2009 1:41
c:\windows\system32\netbios.dll 6.1.7600.16385 7fed4dd0000 a000 d704d499-4161beb8-4f76c299-4a24d0a5-2 14-Jul-2009 1:41
c:\windows\system32\rasadhlp.dll 6.1.7600.16385 7fef9280000 8000 c6a5b28b-48c4c3e7-f680b4aa-bad860a7-2 14-Jul-2009 1:41
c:\windows\system32\fwpuclnt.dll 6.1.7601.18283 7fef7f10000 53000 e9841642-48264d43-a08d1bb1-74229135-2 12-Oct-2013 2:29
c:\windows\system32\winnsi.dll 6.1.7600.16385 7fef97f0000 b000 20d0e4c9-45af82ca-a60f26a5-1856c2e6-2 14-Jul-2009 1:41
c:\windows\system32\iphlpapi.dll 6.1.7601.17514 7fefa400000 27000 8b5a2d4e-425e17ef-5777bb2-c792bcd3-2 20-Nov-2010 13:26
c:\windows\system32\winrnr.dll 6.1.7600.16385 7fef9270000 b000 9207717-4b377dfc-38e949bd-39817c37-2 14-Jul-2009 1:41
c:\windows\system32\dnsapi.dll 6.1.7601.17570 7fefcaf0000 5b000 94b9dfed-487e96e6-483f77a1-c36d6014-2 03-Mar-2011 6:24
c:\program files\common files\microsoft shared\windows live\wlidnsp.dll 7.250.4225.0 7fef9310000 2e000 eb02dea5-4a43b860-fbe1e196-f39b94b-1 21-Sep-2010 18:49
c:\windows\system32\pnrpnsp.dll 6.1.7600.16385 7fef91d0000 19000 7346e3b8-41fe3165-78b059b9-9acc857f-2 14-Jul-2009 1:41
c:\windows\system32\napinsp.dll 6.1.7600.16385 7fef91b0000 15000 d77abf6d-43d68c46-aa21a7a4-cb7e3453-2 14-Jul-2009 1:41
c:\windows\system32\nlaapi.dll 6.1.7601.17964 7fefab20000 15000 3edbfa33-4a04d500-9f63478b-986e2a39-2 03-Oct-2012 17:44
c:\windows\system32\wshtcpip.dll 6.1.7600.16385 7fefc610000 7000 cda0b508-4b9ab885-8b4b9b92-85b3a106-2 14-Jul-2009 1:41
c:\windows\system32\winmm.dll 6.1.7600.16385 7fefaf20000 3b000 df6e9d24-4ddf11ce-69c398b3-6bc95bd0-2 14-Jul-2009 1:41
c:\windows\system32\linkinfo.dll 6.1.7600.16385 7fef6f60000 c000 c2631c18-4b16996d-a4cd8f80-98aeb0d9-2 14-Jul-2009 1:41
c:\windows\system32\networkexplorer.dll 6.1.7601.17514 7fef0d80000 19c000 ec2b7b4e-43353312-827916bc-be8093a6-2 20-Nov-2010 13:27
c:\windows\system32\slc.dll 6.1.7600.16385 7fefa660000 b000 bec5c21c-44e4ffe1-2f04708e-271dff52-1 14-Jul-2009 1:41
c:\windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll 6.2.9200.16492 7fef6680000 4000 7b3fc2ad-45b8863b-9c1e30b3-a58f5b1c-1 14-Jun-2013 21:45
c:\windows\system32\ieframe.dll 11.0.9600.17840 7fef0f90000 dc3000 30378c67-430f46c8-b709378c-14fcf5ee-2 22-May-2015 17:57
c:\windows\system32\shdocvw.dll 6.1.7601.18222 7fef4db0000 34000 140dcf70-4638695f-b8e89e8f-6155b8ba-2 26-Jul-2013 2:24
c:\windows\system32\searchfolder.dll 6.1.7601.17514 7feead50000 d7000 9713a195-42aa67a2-5434cbb-84e3726b-2 20-Nov-2010 13:27
c:\windows\system32\psapi.dll 6.1.7600.16385 778e0000 7000 cabcb96-4c455961-85fc50a7-d6632a66-2 14-Jul-2009 1:41
c:\windows\system32\thumbcache.dll 6.1.7601.17514 7fef71a0000 1f000 ff0e912-42d955fe-cb26829b-c3b71cb5-2 20-Nov-2010 13:27
c:\windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll 6.2.9200.16492 7fefa480000 4000 132f4760-4c59bf95-ec6d719c-54fea763-1 14-Jun-2013 21:45
c:\program files\internet explorer\ieproxy.dll 11.0.9600.17840 7feef0b0000 ba000 a41c8756-4a2acfa2-1104ce8c-149c8877-2 22-May-2015 17:21
c:\windows\system32\actxprxy.dll 6.1.7601.17514 7fef3b60000 ee000 69c2fd19-42821a2c-139237a2-ad026b34-2 20-Nov-2010 13:25
c:\windows\system32\sspicli.dll 6.1.7601.18869 7fefd2a0000 25000 7fc8506a-4af236d1-3b55eeb0-ec78c43e-2 25-May-2015 18:19
c:\windows\system32\secur32.dll 6.1.7601.18869 7fefd240000 b000 e8cd8424-4b41c450-b21b5685-7abb16f4-2 25-May-2015 18:19
c:\windows\system32\structuredquery.dll 7.0.7601.17514 7feeae30000 7b000 1dd182a4-4a61de89-fa5aeb9-b5394ab0-1 20-Nov-2010 13:27
c:\windows\system32\xmllite.dll 1.3.1001.0 7fefb790000 35000 83e39fac-4f602fa2-570bd1a1-1e815291-2 16-Jun-2011 5:49
c:\windows\system32\msls31.dll 3.10.349.0 7fef4910000 42000 37ac0096-4e2cf922-c26ce585-346891e-2 16-Dec-2013 15:41
c:\windows\system32\cscapi.dll 6.1.7601.17514 7fef5e50000 f000 9a2b5950-4290695a-55a1cfa2-a4a6353c-2 20-Nov-2010 13:25
c:\windows\system32\cscdll.dll 6.1.7601.17514 7fef8040000 c000 83477b6b-4a83abbc-f2e1e480-e1fbc535-2 20-Nov-2010 13:25
c:\windows\system32\cscui.dll 6.1.7601.17514 7fef4960000 7e000 45ee018-4e9bcad0-15a8ed98-b3efd23a-2 20-Nov-2010 13:25
c:\windows\system32\ehstorshell.dll 6.1.7600.16385 7fef6120000 35000 c0b7993f-443e69de-63c3048b-e30827d6-1 14-Jul-2009 1:40
c:\windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcp90.dll 9.0.30729.6161 6f800000 d3000 61205b8e-42b8a845-8bddec86-b8dc04d7-1=msvcp90.amd64 01-Jul-2011 7:23
c:\program files\tortoisesvn\bin\intl3_tsvn.dll 0.14.4.0 180000000 17000 c327fef2-4336c770-af4d5eb0-4dff39ba-1 17-Apr-2010 16:10
c:\program files\tortoisesvn\bin\libaprutil_tsvn.dll 1.3.9.0 6ee60000 3d000 c6c23d5c-473ba47e-5be0d29f-db0fcafa-1 17-Apr-2010 16:10
c:\windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcr90.dll 9.0.30729.6161 74d80000 a3000 36e1a242-4825d264-db2eb9ab-a88c05d4-1=msvcr90.amd64 01-Jul-2011 7:23
c:\windows\system32\mswsock.dll 6.1.7601.18254 7fefcc70000 55000 1d73630d-481803bc-dd76c0b6-8ef5af90-2 08-Sep-2013 2:27
c:\program files\tortoisesvn\bin\libapr_tsvn.dll 1.3.8.0 6eec0000 2a000 bae7b101-426e3bfd-9f5d86b6-a499a074-1 17-Apr-2010 16:10
c:\windows\system32\userenv.dll 6.1.7601.17514 7fefd510000 1e000 9279a318-45e88c07-fb9db88b-671b0d6-2 20-Nov-2010 13:27
c:\windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll 6.2.9200.16492 7fefd500000 5000 9eadf45e-44a8cfab-b8955b9a-fa5e5768-1 14-Jun-2013 21:45
c:\windows\system32\iertutil.dll 11.0.9600.17840 7feff090000 2c7000 59a314e5-4058fa25-fb65ef9e-dfb1ea5f-2 22-May-2015 19:00
c:\windows\system32\normaliz.dll 6.1.7600.16385 778f0000 3000 c00c7f7-44c5797e-816f6582-418366b-1 14-Jul-2009 1:31
c:\windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll 6.2.9200.16492 7fefd4f0000 3000 d8e99801-401b5d4f-57b68c9d-c3fe333-1 14-Jun-2013 21:45
c:\windows\system32\api-ms-win-downlevel-version-l1-1-0.dll 6.2.9200.16492 7fefd760000 4000 db5dfd4e-4ae6294d-9597b8b0-f1c32159-1 14-Jun-2013 21:45
c:\windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll 6.2.9200.16492 7fefd750000 4000 ad372fe0-4793bacc-8d33a6bc-c749cf61-1 14-Jun-2013 21:45
c:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll 6.2.9200.16492 7fefd880000 4000 a9f1e723-464f81b9-18ec1585-a5f46f73-1 14-Jun-2013 21:45
c:\windows\system32\wininet.dll 11.0.9600.17840 7fefeda0000 25a000 87534f12-40661c9e-24f822b8-e88fca92-2 22-May-2015 17:50
c:\windows\system32\shfolder.dll 6.1.7600.16385 7fef8050000 7000 d94d04f6-4fe1baab-bc129299-7d76aa6-2 14-Jul-2009 1:41
c:\program files\tortoisesvn\bin\tortoisesvn.dll 1.6.8.19260 5590000 fe000 b8392a5-4202d1ce-7253f0b6-669a05e2-1=TortoiseShell 17-Apr-2010 16:10
c:\program files\tortoisesvn\bin\tortoisestub.dll 1.6.8.19260 5940000 10000 0-0-0-0-0 17-Apr-2010 16:10
c:\program files\common files\tortoiseoverlays\tortoiseoverlays.dll 1.1.1.19039 5960000 1b000 630458e1-45c83b44-5af657a0-2f95be54-1 21-Mar-2010 12:55
c:\windows\system32\apphelp.dll 6.1.7601.18777 7fefd2d0000 57000 664c4a18-44387f4a-1e2546b2-899880a3-2 04-Mar-2015 4:41
c:\windows\system32\windowscodecs.dll 6.2.9200.17251 7fefb620000 161000 58566eb3-44dfe01d-d8377694-bf26a7e2-1 03-Feb-2015 3:31
c:\windows\system32\dui70.dll 6.1.7600.16385 7fefba10000 f2000 5e6c1900-4d33d2e0-89596d8b-3edc7d67-2 14-Jul-2009 1:40
c:\windows\system32\duser.dll 6.1.7600.16385 7fefb9c0000 43000 6066e433-413b9825-58bfcf88-73775f85-2 14-Jul-2009 1:40
c:\windows\system32\explorerframe.dll 6.1.7601.17514 7fef3810000 1ca000 ddd7bebf-44c2392b-183e61be-5a73342e-2 20-Nov-2010 13:26
c:\program files\common files\microsoft shared\ink\tiptsf.dll 6.1.7601.18512 7fef2010000 7f000 3d4f7786-4c53feea-49480896-c3195fd2-1 18-Jun-2014 2:19
c:\windows\system32\profapi.dll 6.1.7600.16385 7fefd4d0000 f000 dc86d275-437fbbb0-4bcdb294-34b9d406-2 14-Jul-2009 1:41
c:\windows\system32\wldap32.dll 6.1.7601.17514 7fefebc0000 52000 8b747af7-4791eb20-b60d7eb5-bc5526d9-2 20-Nov-2010 13:27
c:\windows\system32\ntmarta.dll 6.1.7600.16385 7fefc020000 2d000 60a5ad5f-461cc924-76105abb-eecdeca8-2 14-Jul-2009 1:41
c:\windows\system32\propsys.dll 7.0.7601.17514 7fefb7f0000 12c000 df712cbf-4df1a5ab-1779d1a5-3ff5f8b6-2 20-Nov-2010 13:27
c:\windows\system32\sxs.dll 6.1.7601.17514 7fefd340000 91000 aa08dde0-4b7af906-c5c283b6-ef548e02-2 20-Nov-2010 13:27
c:\windows\system32\rpcrtremote.dll 6.1.7601.17514 7fefd420000 14000 eb674539-4fcb4d5b-beada088-1c7ba11e-2 20-Nov-2010 13:27
c:\windows\system32\rsaenh.dll 6.1.7600.16385 7fefc9d0000 47000 2bfa66bb-4b12f64f-a7e7b3b0-2d4ce58a-2 14-Jul-2009 1:43
c:\windows\system32\cryptsp.dll 6.1.7601.18741 7fefccd0000 18000 9dd8ff5e-4cdad686-fd99d396-a96ff856-1 03-Feb-2015 3:30
c:\windows\system32\version.dll 6.1.7600.16385 7fefc540000 c000 f7695888-4d77add1-5a42d593-17d71c6-2 14-Jul-2009 1:41
c:\program files\[our application]\common\xceedzipx64.dll 6.5.14460.0 7fed4f90000 c9000 eb2d96f2-42ea31b1-2306a68e-e258cde4-1 25-Sep-2014 23:37
c:\windows\system32\clbcatq.dll 2001.12.8530.16385 7feff360000 99000 60b9d310-440bc472-bf663fa1-e339fcf0-2 14-Jul-2009 1:40
c:\windows\system32\cryptbase.dll 6.1.7600.16385 7fefd330000 f000 f03e074b-4c9fb9e7-e4b0bf9b-aba0f32e-2 14-Jul-2009 1:40
c:\windows\system32\odbcint.dll 6.1.7600.16385 70ce0000 38000 0-0-0-0-0 14-Jul-2009 1:31
c:\windows\system32\imagehlp.dll 6.1.7601.18288 7fefed00000 19000 c957a42c-48d8302b-26e0029e-61494722-2 19-Oct-2013 2:18
c:\windows\system32\msvcp120d.dll 12.0.21005.1 7fed5060000 113000 6522ef5a-40fe8b49-2f6c44b0-9c1320de-1=msvcp120d.amd64 05-Oct-2013 3:58
c:\windows\system32\uxtheme.dll 6.1.7600.16385 7fefbfc0000 56000 b0692f27-454fb52c-c38a7ac-63e85d07-2 14-Jul-2009 1:41
c:\windows\system32\msctf.dll 6.1.7601.18731 7fefe860000 109000 933e1903-40fbd775-16beeaa7-f7126ca4-2 17-Jan-2015 2:48
c:\windows\system32\imm32.dll 6.1.7600.16385 7fefe830000 2e000 98f27ba5-41ecaee5-d00ce0be-ee0fd53a-2 14-Jul-2009 1:41
c:\windows\system32\msvcr120d.dll 12.0.21005.1 7fed5180000 211000 a9a944fa-4c0b7ed5-75cdf8b-7ca76e7d-1=msvcr120d.amd64 05-Oct-2013 3:58
c:\windows\system32\mfc120ud.dll 12.0.21005.1 7fed53a0000 a84000 4899bd79-43449817-ecacf5bc-78ea2139-17=mfc120ud.amd64 05-Oct-2013 3:58
c:\program files\siemens\nx 10.0\ugii\libdrfcmp.dll 10.0.0.24 7feea7f0000 13000 99915144-46e90eb3-21338d94-6f1e11db-1=libdrfcmp___1416454013cyp 19-Nov-2014 23:26
c:\program files\siemens\nx 10.0\ugii\libvdac.dll 10.0.0.24 7fed5e30000 ae000 789d99d0-45d2a1c8-8fb4e886-aad6e90-1=libvdac___1416457110cyp 20-Nov-2014 0:18
c:\windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18834_none_2b26557a71eb7442\gdiplus.dll 6.1.7601.18834 7fefbda0000 216000 e4eb4efa-424c9736-d701c8ab-ffc30acb-1=MicrosoftWindowsGdiPlus-1.1.7601.18834-gdiplus 20-Apr-2015 3:11
c:\program files\siemens\nx 10.0\ugii\libdrafting.dll 10.0.0.24 7fed5ee0000 1fb000 135e50b2-4f42697b-ae2c56ad-c4a4342f-1=libdrafting___1416455349cyp 19-Nov-2014 23:49
c:\program files\siemens\nx 10.0\ugii\libop2utils.dll 10.0.0.24 7fed60e0000 98000 5dc40f06-4234d81e-2e2764a3-f9f0d0e8-1=libop2utils___1416454752cyp 19-Nov-2014 23:39
c:\program files\siemens\nx 10.0\ugii\libschemalocator.dll 10.0.0.24 7fed6180000 29e000 dd5d69d7-405c225d-5b12e5a6-c8d5b9e7-1=libschemalocator___1416458429cyp 20-Nov-2014 0:44
c:\program files\siemens\nx 10.0\ugii\libaerosm.dll 10.0.0.24 7fed6420000 108000 e7398bbc-49de3dfe-1dc87b99-9f3f195c-1=libaerosm___1416452833cyp 19-Nov-2014 23:07
c:\program files\siemens\nx 10.0\ugii\libweld.dll 10.0.0.24 7fed6530000 485000 6eb0ce67-461471f7-c7d1dab4-cf180ed6-1=libweld___1416458275cyp 20-Nov-2014 0:38
c:\program files\siemens\nx 10.0\ugii\libmqccore.dll 10.0.0.24 7fed69c0000 132000 2b83db7e-46554b96-aff5d995-12a31948-1=libmqccore___1416457371cyp 20-Nov-2014 0:22
c:\program files\siemens\nx 10.0\ugii\libtoolingutils.dll 10.0.0.24 7fed6b00000 d1000 503a8344-4bf55144-11bbb395-73553d2-1=libtoolingutils___1416457022cyp 20-Nov-2014 0:17
c:\program files\siemens\nx 10.0\ugii\libkru.dll 10.0.0.24 7fed6be0000 26a000 8e833308-4dadba93-619a7183-3351c0f0-1=libkru___1416457872cyp 20-Nov-2014 0:31
c:\program files\siemens\nx 10.0\ugii\libship.dll 10.0.0.24 7fed6e50000 a15000 653ac8c3-4c09300c-110d1884-8c646ffc-1=libship___1416456502cyp 20-Nov-2014 0:08
c:\program files\siemens\nx 10.0\ugii\libvsweep.dll 10.0.0.24 7fed7870000 d0000 a0a19e56-41090518-554656ae-a6c9f80a-1=libvsweep___1416456128cyp 20-Nov-2014 0:02
c:\program files\siemens\nx 10.0\ugii\libhm.dll 10.0.0.24 7fed7940000 e0000 8c61fd55-45beaa5e-7f5a62ba-a5d0a58f-1=libhm___1416457075cyp 20-Nov-2014 0:18
c:\program files\siemens\nx 10.0\ugii\libugmi.dll 10.0.0.24 7fed7a20000 2d000 d5efd6e7-474424c1-6bf73792-71d19ead-1=libugmi___1416456161cyp 20-Nov-2014 0:02
c:\program files\siemens\nx 10.0\ugii\libuginit.dll 10.0.0.24 7fee9ff0000 22000 3e08f47d-4643466c-2498dd90-c4667ca5-1=libuginit___1416455757cyp 19-Nov-2014 23:56
c:\program files\siemens\nx 10.0\ugii\libpartmodule.dll 10.0.0.24 7fed7a50000 10f000 4f2fdba4-423f133d-9493b4b5-ea080bd9-1=libpartmodule___1416452701cyp 19-Nov-2014 23:05
c:\program files\siemens\nx 10.0\ugii\libsbsm.dll 10.0.0.24 7fed7b60000 59f000 eaf5f7ef-42976808-b01e97ad-356c3ef3-1=libsbsm___1416456375cyp 20-Nov-2014 0:06
c:\program files\siemens\nx 10.0\ugii\libdctkloader.dll 10.0.0.24 7feeacb0000 1c000 8d06bd3d-4d818468-349c2ebd-349c67ad-1=libdctkloader___1416455874cyp 19-Nov-2014 23:57
c:\program files\siemens\nx 10.0\ugii\libmswp.dll 10.0.0.24 7fed8100000 8c000 b1516bbb-496884a7-8b8597a0-cdcc038b-1=libmswp___1416456933cyp 20-Nov-2014 0:15
c:\program files\siemens\nx 10.0\ugii\libgdt.dll 10.0.0.24 7fed8190000 35d000 9551f8e5-468db7ce-c0cd6ba5-cad9b527-1=libgdt___1416454546cyp 19-Nov-2014 23:35
c:\program files\siemens\nx 10.0\ugii\libsmsputil.dll 10.0.0.24 7fed84f0000 38000 ab3e200f-4d8869f9-369e32af-89792b4d-1=libsmsputil___1416455864cyp 19-Nov-2014 23:57
c:\program files\siemens\nx 10.0\ugii\libsmsp.dll 10.0.0.24 7fed8530000 134000 9be33f88-488ea297-a668d895-b463172b-1=libsmsp___1416455523cyp 19-Nov-2014 23:52
c:\program files\siemens\nx 10.0\ugii\libpmi.dll 10.0.0.24 7fed8670000 8b3000 f8ea1499-4a95a7f9-ab73ea0-a26fe16c-1=libpmi___1416456261cyp 20-Nov-2014 0:05
c:\program files\siemens\nx 10.0\ugii\libautomotive.dll 10.0.0.24 7fed8f30000 c98000 c3c8af31-457eb323-e5d8ab4-6e9ff7c1-1=libautomotive___1416456038cyp 20-Nov-2014 0:01
c:\program files\siemens\nx 10.0\ugii\libcompos.dll 10.0.0.24 7fed9bd0000 18d000 3d880b1d-48d70621-fa2de38b-c3d0bb62-1=libcompos___1416453211cyp 19-Nov-2014 23:13
c:\program files\siemens\nx 10.0\ugii\librout.dll 10.0.0.24 7fed9d60000 bcb000 a92e0a35-40b42a32-478118ac-9360061b-1=librout___1416456653cyp 20-Nov-2014 0:11
c:\program files\siemens\nx 10.0\ugii\libsmd.dll 10.0.0.24 7feda930000 548000 eb65cffa-4f19f882-cf72ccad-d9287802-1=libsmd___1416455225cyp 19-Nov-2014 23:47
c:\program files\siemens\nx 10.0\ugii\liblwks.dll 10.0.0.24 7fedae80000 1f6000 7cab8167-46cab5ac-c3c68a9e-d83b623c-1=liblwks___1416457199cyp 20-Nov-2014 0:20
c:\program files\siemens\nx 10.0\ugii\icudt51.dll 51.2.0.0 6e630000 19f000 0-0-0-0-0 18-Nov-2014 21:47
c:\program files\siemens\nx 10.0\ugii\icuuc51.dll 51.2.0.0 6e9d0000 13d000 0-0-0-0-0 18-Nov-2014 21:20
c:\program files\siemens\nx 10.0\ugii\xerces311.dll 3.1.1.0 12000000 257000 42513dc3-47f0dc62-f7cc26ae-f0364fc7-1 18-Nov-2014 21:18
c:\program files\siemens\nx 10.0\ugii\libnxpos.dll 10.0.0.24 7fedb080000 98000 e2de0a5a-45a51ce8-c3494690-bd134381-1=libnxpos___1416456476cyp 20-Nov-2014 0:08
c:\program files\siemens\nx 10.0\ugii\libfasthidden.dll 10.0.0.24 7fedb120000 cf000 4a497dcd-45cb37c4-cc05ba3-11d3d27a-1=libfasthidden___1416455652cyp 19-Nov-2014 23:54
c:\program files\siemens\nx 10.0\ugii\libtemplate.dll 10.0.0.24 7fedb1f0000 3e000 7450ec81-4d307021-3edd18ba-1fa042e4-1=libtemplate___1416456936cyp 20-Nov-2014 0:15
c:\program files\siemens\nx 10.0\ugii\libtline.dll 10.0.0.24 7feeacd0000 24000 11c9341-43c76a2f-c71e3994-ae5fe965-1=libtline___1416457090cyp 20-Nov-2014 0:18
c:\program files\siemens\nx 10.0\ugii\libfacetstore.dll 10.0.0.24 7fedb230000 66000 eeb84873-40ab11e5-a895bea4-a8b90d5-1=libfacetstore___1416457432cyp 20-Nov-2014 0:23
c:\program files\siemens\nx 10.0\ugii\libtceng_utils.dll 10.0.0.24 7fef6110000 a000 5636552a-4d0341ee-dad3cc85-9fe4c567-1=libtceng_utils___1416454783cyp 19-Nov-2014 23:39
c:\program files\siemens\nx 10.0\ugii\libfeaturerecognition.dll 10.0.0.24 7feeeee0000 15000 bee9d055-4a7221b9-499a6bb3-b07878c2-1=libfeaturerecognition___1416458929cyp 20-Nov-2014 0:48
c:\program files\siemens\nx 10.0\ugii\libpgs.dll 10.0.0.24 7fedb2a0000 f0000 52ded56e-4d52411b-325c0bb5-f5d6a12c-1=libpgs___1416455735cyp 19-Nov-2014 23:55
c:\windows\system32\winspool.drv 6.1.7601.17514 7fef80e0000 71000 e75038c3-430e6e27-d64d3898-aabd36f9-1 20-Nov-2010 13:24
c:\windows\system32\dwmapi.dll 6.1.7600.16385 7fefb7d0000 18000 8683ed0c-40533dbe-2fc23e88-10f2b4d9-2 14-Jul-2009 1:40
c:\windows\system32\devobj.dll 6.1.7600.16385 7fefd7b0000 1a000 80698d17-4b78ff4b-32c6dc90-f4a78024-2 14-Jul-2009 1:40
c:\windows\system32\cfgmgr32.dll 6.1.7601.17514 7fefd840000 36000 9fa5840a-41874d3c-6421f699-e89d8ce9-2 20-Nov-2010 13:25
c:\windows\system32\setupapi.dll 6.1.7601.17514 7fefe970000 1d7000 59fe8950-47324c23-49999a3-fe04a83c-2 20-Nov-2010 13:27
c:\windows\system32\dciman32.dll 6.1.7601.18768 7fef6fd0000 8000 d0f88e14-4dc9d4ba-b5ef72a0-a85bf533-2 20-Feb-2015 4:40
c:\windows\system32\ddraw.dll 6.1.7600.16385 7fedb390000 f1000 21ffff82-4255952a-1a730bac-7d9a528a-2 14-Jul-2009 1:40
c:\windows\system32\glu32.dll 6.1.7600.16385 7feee9c0000 2d000 450a9fbd-4b80d1c1-bb518f8a-bed4c60c-1 14-Jul-2009 1:40
c:\windows\system32\opengl32.dll 6.1.7600.16385 7fedb490000 11d000 d4c4d41c-40a433d2-d3a48880-d67b00f-1 14-Jul-2009 1:41
c:\program files\siemens\nx 10.0\ugii\cggl.dll 2.0.0.15 6a400000 6a000 52b07d0d-4af12be7-319e8fb1-9317c9fe-1 18-Nov-2014 22:11
c:\program files\siemens\nx 10.0\ugii\cg.dll 2.0.0.15 6a000000 3b2000 c0928e75-4d0c45c6-3f4121ac-414aeafd-1 18-Nov-2014 21:58
c:\program files\siemens\nx 10.0\ugii\libtable.dll 10.0.0.24 7fedb5b0000 1cc000 572045ff-40ec9e63-280ed59f-6c4a7ce5-1=libtable___1416455375cyp 19-Nov-2014 23:49
c:\program files\siemens\nx 10.0\ugii\libimage.dll 10.0.0.24 7fedb780000 97000 952fd6d0-4b345293-f45557a9-c5a9013d-1=libimage___1416457884cyp 20-Nov-2014 0:31
c:\program files\siemens\nx 10.0\ugii\libptr.dll 10.0.0.24 7fedb820000 57000 b96c1129-4f3207b6-72a3eab4-cbaf78c0-1=libptr___1416452176cyp 19-Nov-2014 22:56
c:\program files\siemens\nx 10.0\ugii\libpartcommon.dll 10.0.0.24 7fef7240000 d000 8af0f4d2-45d378e6-7e79cba7-937573a1-1=libpartcommon___1416455507cyp 19-Nov-2014 23:51
c:\program files\siemens\nx 10.0\ugii\libcoreblockdata.dll 10.0.0.24 7fedb880000 204000 96a98317-484e963a-5fa9d68e-4cf9b794-1=libcoreblockdata___1416455292cyp 19-Nov-2014 23:48
c:\program files\siemens\nx 10.0\ugii\libsket.dll 10.0.0.24 7fedba90000 37d000 2ffe6f6f-4f5d485c-e890e29a-c548492c-1=libsket___1416458294cyp 20-Nov-2014 0:38
c:\program files\siemens\nx 10.0\ugii\libpdi.dll 10.0.0.24 7fedbe10000 c3000 a5c7b3f2-4fd48056-9f7a7dad-694f66a9-1=libpdi___1416454976cyp 19-Nov-2014 23:43
c:\program files\siemens\nx 10.0\ugii\libphymat.dll 10.0.0.24 7fedbee0000 141000 b3c02854-4b095099-f08fb7ae-56f59478-1=libphymat___1416456550cyp 20-Nov-2014 0:09
c:\program files\siemens\nx 10.0\ugii\libpartnav.dll 10.0.0.24 7feef240000 15000 577cb4ef-45ca294d-e9a1d48b-8896add2-1=libpartnav___1416456308cyp 20-Nov-2014 0:05
c:\program files\siemens\nx 10.0\ugii\libgenpos.dll 10.0.0.24 7fedc030000 8c000 21778c30-4ce069c3-33852f88-a5402b88-1=libgenpos___1416456071cyp 20-Nov-2014 0:01
c:\program files\siemens\nx 10.0\ugii\libpartutils.dll 10.0.0.24 7fedc0c0000 575000 8e8e355c-4cba9af1-fd496dba-72283867-1=libpartutils___1416452053cyp 19-Nov-2014 22:54
c:\program files\siemens\nx 10.0\ugii\libpartdisp.dll 10.0.0.24 7fedc640000 15a000 d649a4f1-49ae80cd-2beb8999-fbb166c1-1=libpartdisp___1416454992cyp 19-Nov-2014 23:43
c:\program files\siemens\nx 10.0\ugii\libmodlgeom.dll 10.0.0.24 7fedc7a0000 bd9000 43173cc-4a5f822b-1a893abe-173ba1d9-1=libmodlgeom___1416452133cyp 19-Nov-2014 22:56
c:\program files\siemens\nx 10.0\ugii\libmodlmath.dll 10.0.0.24 7fedd380000 48d000 f597f6e3-430411ba-e44b8aba-a3a9e3d8-1=libmodlmath___1416455875cyp 19-Nov-2014 23:58
c:\program files\siemens\nx 10.0\ugii\libcsf.dll 10.0.0.24 7fedd810000 1dc000 5fb6e9cb-4516acc4-ec1505a2-1a882513-1=libcsf___1416455073cyp 19-Nov-2014 23:44
c:\program files\siemens\nx 10.0\ugii\libcsfadp.dll 10.0.0.24 7fedd9f0000 70000 39062678-402daddc-f8d9dfb9-c74566b8-1=libcsfadp___1416452183cyp 19-Nov-2014 22:56
c:\program files\siemens\nx 10.0\ugii\libcamsmom.dll 10.0.0.24 7fedda60000 70000 89ff75d2-4be37b34-93234b89-2ccf5df9-1=libcamsmom___1416454015cyp 19-Nov-2014 23:26
c:\program files\siemens\nx 10.0\ugii\libpartmodl.dll 10.0.0.24 7feddad0000 1194000 75ba542c-4ca80ac2-47d8269a-e965493c-1=libpartmodl___1416456939cyp 20-Nov-2014 0:16
c:\program files\siemens\nx 10.0\ugii\libfeatutils.dll 10.0.0.24 7fedec70000 108000 c12c8f05-4a94d757-5f98419b-d5af3103-1=libfeatutils___1416451515cyp 19-Nov-2014 22:45
c:\program files\siemens\nx 10.0\ugii\libmodl.dll 10.0.0.24 7feded80000 13e2000 b23254d5-4193779f-6df01196-32484a19-1=libmodl___1416453370cyp 19-Nov-2014 23:17
c:\program files\siemens\nx 10.0\ugii\libinterop.dll 10.0.0.24 7feef180000 2d000 4422e979-432c5bfc-66b27dad-40137e80-1=libinterop___1416454017cyp 19-Nov-2014 23:27
c:\program files\siemens\nx 10.0\ugii\libpkp.dll 10.0.0.24 7fee0170000 10d000 d16550a8-48d650c5-ffd81f80-90d5ed20-1=libpkp___1416457246cyp 20-Nov-2014 0:20
c:\program files\siemens\nx 10.0\ugii\libpart.dll 10.0.0.24 7fee0280000 edb400 72a12983-48637e29-5960efac-d033873a-1=libpart___1416454643cyp 20-Nov-2014 1:04
c:\program files\siemens\nx 10.0\ugii\libfusion.dll 10.0.0.24 7fee1160000 91000 211a749b-4da51589-91bf63a0-8055e810-1=libfusion___1416459013cyp 20-Nov-2014 0:50
c:\program files\siemens\nx 10.0\ugii\libklo.dll 10.0.0.24 7fee1200000 10c000 a75f6d04-47bcb099-ae58eea1-b77cffbe-1=libklo___1416457106cyp 20-Nov-2014 0:18
c:\program files\siemens\nx 10.0\ugii\libugmr.dll 10.0.0.24 7fee1310000 58f000 308ff733-47517f15-d684c4b5-8ea892a9-1=libugmr___1416455472cyp 19-Nov-2014 23:51
c:\program files\siemens\nx 10.0\ugii\libdmservices.dll 10.0.0.24 7fee18a0000 1c9000 5b4f15d3-41503a77-f1cd3684-10d3e5f7-1=libdmservices___1416457492cyp 20-Nov-2014 0:25
c:\program files\siemens\nx 10.0\ugii\libdmapplication.dll 10.0.0.24 7fee1a70000 120000 36a8fd7d-4a637aa8-f125c5bd-e9f5923b-1=libdmapplication___1416451589cyp 19-Nov-2014 22:46
c:\program files\siemens\nx 10.0\ugii\libocc.dll 10.0.0.24 7fee1b90000 55b000 9e891310-4ce50d4b-e7f10c94-2031a8ee-1=libocc___1416453038cyp 19-Nov-2014 23:10
c:\program files\siemens\nx 10.0\ugii\libfacet.dll 10.0.0.24 7fee20f0000 38e000 f55a86ab-420a261a-110668b9-afab5333-1=libfacet___1416456739cyp 20-Nov-2014 0:12
c:\program files\siemens\nx 10.0\ugii\libgeomutil.dll 10.0.0.24 7fee2480000 ea000 4079e052-46320d4b-95cb3ba4-4b115a64-1=libgeomutil___1416457604cyp 20-Nov-2014 0:26
c:\program files\siemens\nx 10.0\ugii\libgeom.dll 10.0.0.24 7fee2570000 4f4000 d7b7f27e-4fe261d8-57e12c8c-1ea73c67-1=libgeom___1416457376cyp 20-Nov-2014 0:23
c:\program files\siemens\nx 10.0\ugii\libevaluator.dll 10.0.0.24 7fee2a70000 301000 87934ea9-4e6729ea-dba2bcab-be1768a0-1=libevaluator___1416457436cyp 20-Nov-2014 0:24
c:\program files\siemens\nx 10.0\ugii\libassypos.dll 10.0.0.24 7fee2d80000 58000 76cce9fa-44d02fbd-86128c-17cbd1a3-1=libassypos___1416456082cyp 20-Nov-2014 0:01
c:\program files\siemens\nx 10.0\ugii\libdraw.dll 10.0.0.24 7fee2de0000 939000 73089262-49e447a6-b796295-d307fc20-1=libdraw___1416454832cyp 19-Nov-2014 23:41
c:\program files\siemens\nx 10.0\ugii\libsmdpk.dll 10.0.0.24 7fee3720000 5d000 a8bde237-4fd882b8-d41f89a8-db8ef435-1=libsmdpk___1416457603cyp 20-Nov-2014 0:26
c:\program files\siemens\nx 10.0\ugii\pfkernel.dll 0.27.0.178 7fee3780000 120000 4875687b-4430852a-c935ff9a-e22c9f27-1=pfkernel_27_0_178 18-Nov-2014 22:06
c:\program files\siemens\nx 10.0\ugii\pskernel.dll 0.27.0.178 7fee38a0000 2854000 84960117-4d113c90-7e7e91be-d239b463-1=pskernel_27_0_178 18-Nov-2014 21:28
c:\program files\siemens\nx 10.0\ugii\libugutils.dll 10.0.0.24 7fee6100000 18e000 e5668b44-45af16c0-ea0cb3bc-ac687156-1=libugutils___1416457142cyp 20-Nov-2014 0:19
c:\program files\siemens\nx 10.0\ugii\libdman.dll 10.0.0.24 7fee6290000 5f000 e0d2dddc-4cc016bd-bf074db3-ddad4d5f-1=libdman___1416453307cyp 19-Nov-2014 23:15
c:\program files\siemens\nx 10.0\ugii\libassybox.dll 10.0.0.24 7fee62f0000 ac000 7e185870-408785ee-9cfbcfad-7d3e26fd-1=libassybox___1416453108cyp 19-Nov-2014 23:11
c:\program files\siemens\nx 10.0\ugii\libassy.dll 10.0.0.24 7fee63a0000 6a9000 3151739d-42696cac-84b9c29f-8ce5ee93-1=libassy___1416458050cyp 20-Nov-2014 0:34
c:\program files\siemens\nx 10.0\ugii\libasmo.dll 10.0.0.24 7fee6a50000 168000 12b1ea63-43b32505-3b2c86b8-97ff34d8-1=libasmo___1416456168cyp 20-Nov-2014 0:02
c:\program files\siemens\nx 10.0\ugii\libdisp.dll 10.0.0.24 7fee6bc0000 950400 6b2f5ddc-40b3d287-6603b194-d21d2f40-1=libdisp___1416453471cyp 20-Nov-2014 1:04
c:\program files\siemens\nx 10.0\ugii\libpman.dll 10.0.0.24 7feea020000 5e000 aa9f6ad1-4297b198-24d25fa9-f8d9713c-1=libpman___1416455275cyp 19-Nov-2014 23:47
c:\program files\siemens\nx 10.0\ugii\libugmath.dll 10.0.0.24 7feea080000 a8000 52d9256b-43800ac5-1b9b089e-bcfe99f3-1=libugmath___1416454967cyp 19-Nov-2014 23:42
c:\program files\siemens\nx 10.0\ugii\libcustdef.dll 10.0.0.24 7fee7520000 289000 5d2ad249-4a71b7de-8fad5f81-d00359ff-1=libcustdef___1416455304cyp 19-Nov-2014 23:48
c:\program files\siemens\nx 10.0\ugii\libann.dll 10.0.0.24 7fee77b0000 e13000 ed945561-4f1553c3-a92df91-f69bb5e9-1=libann___1416457927cyp 20-Nov-2014 0:33
c:\program files\siemens\nx 10.0\ugii\libcmod.dll 10.0.0.24 7fee85d0000 4fd000 b0fe3d94-4816907c-82327e88-509d07a4-1=libcmod___1416453236cyp 19-Nov-2014 23:14
c:\program files\siemens\nx 10.0\ugii\libufunx.dll 10.0.0.24 7fee8ad0000 45d000 6fca3722-46174857-a9f13382-29037c5a-1=libufunx___1416457507cyp 20-Nov-2014 0:25
c:\windows\system32\wkscli.dll 6.1.7601.17514 7fefb320000 15000 537df011-4d4f963e-28b691a7-38d7df7b-2 20-Nov-2010 13:27
c:\windows\system32\srvcli.dll 6.1.7601.17514 7fefcee0000 23000 a33e9ce1-4815c851-292ae391-58e113c2-2 20-Nov-2010 13:27
c:\windows\system32\netutils.dll 6.1.7601.17514 7fefc8b0000 c000 e65362a1-494aea9e-5624a185-b65be44d-2 20-Nov-2010 13:27
c:\windows\system32\netapi32.dll 6.1.7601.17887 7fefb340000 16000 f2840256-42060de6-39a10698-f517ee30-2 04-Jul-2012 22:16
c:\windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\comctl32.dll 6.10.7601.18837 7fefc050000 1f4000 b312550e-42f4a9b0-ad095c85-dc2050d8-1 24-Apr-2015 18:12
c:\windows\system32\comdlg32.dll 6.1.7601.17514 7feff750000 97000 631b5737-49fd6f85-aba8e7b2-df1f2d3d-2 20-Nov-2010 13:25
c:\windows\system32\nsi.dll 6.1.7600.16385 7feff000000 8000 dddd6b3d-49d5710d-92f61aa0-26cd1fa9-2 14-Jul-2009 1:41
c:\windows\system32\ws2_32.dll 6.1.7601.17514 7fefeb70000 4d000 348be7d2-495b2346-a27f1b84-d06b9903-2 20-Nov-2010 13:27
c:\windows\system32\oleaut32.dll 6.1.7601.18679 7fefec20000 d7000 90dcf6e7-4e284247-440fc5a4-2b9d8fd4-2 26-Nov-2014 3:53
c:\windows\system32\wintrust.dll 6.1.7601.18741 7fefd770000 3b000 f791bc19-45694886-776db095-727224b3-2 03-Feb-2015 3:31
c:\windows\system32\msasn1.dll 6.1.7601.17514 7fefd4e0000 f000 e973c31c-43dcb039-1c5430af-59aebba-2 20-Nov-2010 13:27
c:\windows\system32\crypt32.dll 6.1.7601.18741 7fefd5d0000 16d000 70580d87-49ee5943-6199ac82-77e8b41c-2 03-Feb-2015 3:30
c:\program files\siemens\nx 10.0\ugii\libpatch.dll 10.0.0.24 7fef9830000 7000 a3ea0d45-4c2df8b7-df64dd8e-41d73920-1=libpatch___1416452669cyp 19-Nov-2014 23:04
c:\program files\siemens\nx 10.0\ugii\libnxc.dll 10.0.0.24 7fef6650000 19000 154fc238-40e33860-f479b8af-8d592d38-1=libnxc___1416455186cyp 19-Nov-2014 23:46
c:\windows\system32\shell32.dll 6.1.7601.18762 7fefdaa0000 d89000 d2d567b7-4bddc03b-71477794-968738ac-2 13-Feb-2015 5:22
c:\windows\system32\shlwapi.dll 6.1.7601.17514 7feff010000 71000 820a075-4e250c1a-ea7de197-5449d057-2 20-Nov-2010 13:27
c:\windows\system32\mpr.dll 6.1.7600.16385 7fef8060000 18000 4f9e18e0-4b840067-eee7cb7-f253639c-2 14-Jul-2009 1:41
c:\windows\system32\odbc32.dll 6.1.7601.17514 7feea130000 b1000 c7cc7510-40e73718-97242b4-8d391be2-2 20-Nov-2010 13:27
c:\windows\system32\ole32.dll 6.1.7601.17514 7fefd890000 203000 ee489189-4d47724f-b5fdccae-35244853-2 20-Nov-2010 13:27
c:\windows\system32\usp10.dll 1.626.7601.18454 7feff590000 c9000 bffc0bc-461f51b8-ff5d8e97-9946e449-1 25-Apr-2014 2:34
c:\windows\system32\lpk.dll 6.1.7601.18768 7feff740000 e000 e475a859-4e4727bb-2cc28297-fb8465d4-2 20-Feb-2015 4:41
c:\windows\system32\gdi32.dll 6.1.7601.18778 7feff7f0000 67000 3da01606-4b22ebaf-1d38be80-fc04d294-2 05-Mar-2015 5:12
c:\windows\system32\user32.dll 6.1.7601.17514 77500000 fa000 953b0479-48b22b8a-e3303988-6a2ad26f-2 20-Nov-2010 13:27
c:\windows\system32\rpcrt4.dll 6.1.7601.18532 7feff860000 12d000 59235376-43a7d28d-2d89bd9b-4f89969b-2 14-Jul-2014 2:02
c:\windows\system32\sechost.dll 6.1.7601.18869 7fefeb50000 1f000 3824ad19-47aaab6c-e3d67088-8b73f171-1 25-May-2015 18:19
c:\windows\system32\msvcrt.dll 7.0.7601.17744 7feff990000 9f000 5376efb7-4b4dd7e5-f76f15a4-b0e64335-2 16-Dec-2011 8:46
c:\windows\system32\advapi32.dll 6.1.7601.18869 7feff660000 db000 91554e3a-421617b7-dffa18af-742c2101-2 25-May-2015 18:18
c:\windows\system32\msvcp110.dll 11.0.51106.1 7feee780000 a7000 cb6662b5-4792d109-d65dab8b-c89ca304-1=msvcp110.amd64 06-Nov-2012 3:26
c:\windows\system32\msvcr110.dll 11.0.51106.1 7fef7760000 d4000 d919f6d-4959d3b1-9813e7bd-6addb249-1=msvcr110.amd64 06-Nov-2012 3:26
c:\program files\siemens\nx 10.0\ugii\libsyss.dll 10.0.0.24 7fee8f30000 524000 8f80f4ae-4c747f65-c058b28c-fc266417-1=libsyss___1416456237cyp 20-Nov-2014 0:04
c:\program files\siemens\nx 10.0\ugii\libjam.dll 10.0.0.24 7fee9460000 70c000 65f06ffb-444d114b-7b56ceab-6b22f50d-1=libjam___1416454585cyp 20-Nov-2014 1:04
c:\program files\siemens\nx 10.0\ugii\libufun.dll 10.0.0.24 7feea810000 166000 e524203d-417369e7-bd013d93-8418e5cb-1=libufun___1416455333cyp 19-Nov-2014 23:49
c:\windows\system32\kernelbase.dll 6.1.7601.18869 7fefd7d0000 6c000 16612e92-44bf874f-1b2f14ae-37035276-2 25-May-2015 18:19
c:\windows\system32\kernel32.dll 6.1.7601.18869 77600000 11f000 6ce01243-4de4d1c7-15818caa-552e5897-2 25-May-2015 18:19
c:\windows\system32\ntdll.dll 6.1.7601.18869 77720000 1a9000 6279255-46362c5c-e1515690-18d7cd75-2 25-May-2015 18:21
c:\svn\dev_new\stable_v9.5\executable2013\x64\debug\Interface_nx.exe 9.5.0.0 13f660000 524e000 70020d54-403e347e-de0f3a5-414bc6e4-1 05-Jun-2015 20:06
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libcaeinit.dll
Loaded module c:\program files\siemens\nx 10.0\ugii\libcaeinit.dll 7feeee90000 1e000 2974cbdb-4bd25fe6-1233aa94-d5c4b916-1=libcaeinit___1416457452cyp version = 10.0.0.24
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libcaminit.dll
Loaded module c:\program files\siemens\nx 10.0\ugii\libcaminit.dll 7fed4360000 15000 98397990-4d0d1c65-472256b6-1c77cf22-1=libcaminit___1416455126cyp version = 10.0.0.24
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\application\liblinedesignerinit.dll
Loaded module c:\program files\siemens\nx 10.0\line_designer\application\liblinedesignerinit.dll 7fed4340000 13000 c7e88754-42dce01c-206f18a1-acd6966-1=liblinedesignerinit___1416452098cyp version = 10.0.0.24
Processing C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\ugs_linedesigner_templates.pax for File New Templates
Added template: 'Equipment', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Equipment', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'Line', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Line', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'Zone', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Zone', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'Station', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Station', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'A0 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A0-Size-template.prt'
Added template: 'A1 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A1-Size-template.prt'
Added template: 'A2 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A2-Size-template.prt'
Added template: 'A3 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A3-Size-template.prt'
Added template: 'A4 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A4-Size-template.prt'
Added template: 'A - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A-Size-template.prt'
Added template: 'B - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-B-Size-template.prt'
Added template: 'C - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-C-Size-template.prt'
Added template: 'D - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-D-Size-template.prt'
Added template: 'E - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-E-Size-template.prt'
Added template: 'F - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-F-Size-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_cae_templates.pax for File New Templates
Added template: 'NX Nastran', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranEnglish.fem'
Added template: 'NX Nastran', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranMetric.fem'
Added template: 'NX Nastran', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranEnglish.sim'
Added template: 'NX Nastran', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranMetric.sim'
Added template: 'NX Thermal/Flow', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxThermalFlowEnglish.fem'
Added template: 'NX Thermal/Flow', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxThermalFlowMetric.fem'
Added template: 'NX Thermal/Flow', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxThermalFlowEnglish.sim'
Added template: 'NX Thermal/Flow', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxThermalFlowMetric.sim'
Added template: 'NX Nastran Design', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranDesignEnglish.fem'
Added template: 'NX Nastran Design', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranDesignMetric.fem'
Added template: 'NX Nastran Design', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranDesignEnglish.sim'
Added template: 'NX Nastran Design', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranDesignMetric.sim'
Added template: 'MSC Nastran', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemMscNastranEnglish.fem'
Added template: 'MSC Nastran', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemMscNastranMetric.fem'
Added template: 'MSC Nastran', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimMscNastranEnglish.sim'
Added template: 'MSC Nastran', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimMscNastranMetric.sim'
Added template: 'Ansys', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAnsysEnglish.fem'
Added template: 'Ansys', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAnsysMetric.fem'
Added template: 'Ansys', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAnsysEnglish.sim'
Added template: 'Ansys', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAnsysMetric.sim'
Added template: 'Abaqus', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAbaqusEnglish.fem'
Added template: 'Abaqus', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAbaqusMetric.fem'
Added template: 'Abaqus', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAbaqusEnglish.sim'
Added template: 'Abaqus', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAbaqusMetric.sim'
Added template: 'NX Electronic Systems Cooling', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxElecSysCoolingMetric.fem'
Added template: 'NX Electronic Systems Cooling', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxElecSysCoolingEnglish.fem'
Added template: 'NX Electronic Systems Cooling', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxElecSysCoolingMetric.sim'
Added template: 'NX Electronic Systems Cooling', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxElecSysCoolingEnglish.sim'
Added template: 'NX Space Systems Thermal', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxSpaceSysThermalMetric.fem'
Added template: 'NX Space Systems Thermal', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxSpaceSysThermalEnglish.fem'
Added template: 'NX Space Systems Thermal', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxSpaceSysThermalMetric.sim'
Added template: 'NX Space Systems Thermal', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxSpaceSysThermalEnglish.sim'
Added template: 'LS-DYNA', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemLSDynaMetric.fem'
Added template: 'LS-DYNA', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemLSDynaEnglish.fem'
Added template: 'LS-DYNA', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimLSDynaMetric.sim'
Added template: 'LS-DYNA', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimLSDynaEnglish.sim'
Added template: 'NX Multiphysics', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxMultiPhysicsMetric.fem'
Added template: 'NX Multiphysics', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxMultiPhysicsEnglish.fem'
Added template: 'NX Multiphysics', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxMultiPhysicsMetric.sim'
Added template: 'NX Multiphysics', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxMultiPhysicsEnglish.sim'
Added template: 'Samcef', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemSamcefMetric.fem'
Added template: 'Samcef', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemSamcefEnglish.fem'
Added template: 'Samcef', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimSamcefMetric.sim'
Added template: 'Samcef', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimSamcefEnglish.sim'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_drawing_templates.pax for File New Templates
Added template: 'A0 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A0-Size2D-template.prt'
Added template: 'A1 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A1-Size2D-template.prt'
Added template: 'A2 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A2-Size2D-template.prt'
Added template: 'A3 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A3-Size2D-template.prt'
Added template: 'A4 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A4-Size2D-template.prt'
Added template: 'A - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A-Size2D-template.prt'
Added template: 'B - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-B-Size2D-template.prt'
Added template: 'C - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-C-Size2D-template.prt'
Added template: 'D - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-D-Size2D-template.prt'
Added template: 'E - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-E-Size2D-template.prt'
Added template: 'F - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-F-Size2D-template.prt'
Added template: 'Layout - A0', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A0-Size2D-template.prt'
Added template: 'Layout - A1', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A1-Size2D-template.prt'
Added template: 'Layout - C', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-C-Size2D-template.prt'
Added template: 'Layout - D', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-D-Size2D-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_inspection_templates.pax for File New Templates
Added template: 'DMIS General Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy.prt'
Added template: 'Probe Tool', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_probe_assy.prt'
Added template: 'DMIS General Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy.prt'
Added template: 'Probe Tool', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_probe_assy.prt'
Added template: '0.7 mm Steel Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_07mm_steel.prt'
Added template: '18 ga Steel Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_18ga_steel.prt'
Added template: 'BS Rotary Machine Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_BSRotary_english.prt'
Added template: 'BS Rotary Machine Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_BSRotary_mm.prt'
Added template: 'Wenzel LH65 Tool Rack Machine Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_Wenzel_LH65_mm.prt'
Added template: 'Wenzel LH65 Tool Rack Machine Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_Wenzel_LH65_english.prt'
Added template: 'Renishaw Equator 300 Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_Renishaw_Equator_300_mm.prt'
Added template: 'Renishaw Equator 300 Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_Renishaw_Equator_300_english.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_manufacturing_templates.pax for File New Templates
Added template: 'General Setup', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\mill_planar_assy.prt'
Added template: 'General Setup', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\mill_planar_assy.prt'
Added template: 'Die Mold (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\DieMold_Express.prt'
Added template: 'Die Mold (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\DieMold_Express.prt'
Added template: 'Turning (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\Turning_Express.prt'
Added template: 'Turning (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\Turning_Express.prt'
Added template: 'Machinery (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\Machinery_Express.prt'
Added template: 'Machinery (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\Machinery_Express.prt'
Added template: 'Multi-Axis (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\MultiAxis_Express.prt'
Added template: 'Multi-Axis (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\MultiAxis_Express.prt'
Added template: 'Mill Turn (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\MillTurn_Express.prt'
Added template: 'Mill Turn (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\MillTurn_Express.prt'
Added template: 'Simulation Dual Table Sinumerik', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\simulation_dualtable_sinumerik.prt'
Added template: 'Simulation Dual Table Sinumerik', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\\simulation_dualtable_sinumerik.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_mechatronics_templates.pax for File New Templates
Added template: 'General Setup', application: 'MechatronicsTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\mechatronics-inch-template.prt'
Added template: 'General Setup', application: 'MechatronicsTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\mechatronics-mm-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_model_templates.pax for File New Templates
Added template: 'Model', application: 'ModelTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\model-plain-1-inch-template.prt'
Added template: 'Model', application: 'ModelTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\model-plain-1-mm-template.prt'
Added template: 'Assembly', application: 'AssemblyTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\assembly-inch-template.prt'
Added template: 'Assembly', application: 'AssemblyTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\assembly-mm-template.prt'
Added template: 'Shape Studio', application: 'StudioTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\shape-studio-inch-template.prt'
Added template: 'Shape Studio', application: 'StudioTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\shape-studio-mm-template.prt'
Added template: 'Sheet Metal', application: 'NXSheetMetalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\sheet-metal-inch-template.prt'
Added template: 'Sheet Metal', application: 'NXSheetMetalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\sheet-metal-mm-template.prt'
Added template: 'Aero Sheet Metal', application: 'AeroSheetMetalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\aero-sheet-metal-inch-template.prt'
Added template: 'Aero Sheet Metal', application: 'AeroSheetMetalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\aero-sheet-metal-mm-template.prt'
Added template: 'Routing Logical', application: 'RoutingLogicalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-logical-inch-template.prt'
Added template: 'Routing Logical', application: 'RoutingLogicalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-logical-mm-template.prt'
Added template: 'Routing Mechanical', application: 'RoutingMechanicalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-mech-inch-template.prt'
Added template: 'Routing Mechanical', application: 'RoutingMechanicalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-mech-mm-template.prt'
Added template: 'Routing Electrical', application: 'RoutingElectricalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-elec-inch-template.prt'
Added template: 'Routing Electrical', application: 'RoutingElectricalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-elec-mm-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_sheet_templates.pax for File New Templates
Added template: 'A - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A-Size2D-template.prt'
Added template: 'B - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-B-Size2D-template.prt'
Added template: 'C - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-C-Size2D-template.prt'
Added template: 'D - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-D-Size2D-template.prt'
Added template: 'E - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-E-Size2D-template.prt'
Added template: 'F - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-F-Size2D-template.prt'
Added template: 'A0 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A0-Size2D-template.prt'
Added template: 'A1 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A1-Size2D-template.prt'
Added template: 'A2 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A2-Size2D-template.prt'
Added template: 'A3 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A3-Size2D-template.prt'
Added template: 'A4 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A4-Size2D-template.prt'
Added template: 'Layout - A0', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A0-Size2D-template.prt'
Added template: 'Layout - A1', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A1-Size2D-template.prt'
Added template: 'Layout - C', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-C-Size2D-template.prt'
Added template: 'Layout - D', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-D-Size2D-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_ship_templates.pax for File New Templates
Added template: 'Ship Reference', application: 'ShipReferenceTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-reference-inch-template.prt'
Added template: 'Ship Reference', application: 'ShipReferenceTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-reference-metric-template.prt'
Added template: 'Structural System', application: 'ShipSystemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-system-inch-template.prt'
Added template: 'Structural System', application: 'ShipSystemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-system-metric-template.prt'
Added template: 'Ship Container Assembly', application: 'ShipContainerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-container-inch-template.prt'
Added template: 'Ship Container Assembly', application: 'ShipContainerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-container-metric-template.prt'
Added template: 'Structural Detail', application: 'ShipDetailTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-detail-inch-template.prt'
Added template: 'Structural Detail', application: 'ShipDetailTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-detail-metric-template.prt'
NX Load Options Are :-
Load Options : Load from directory
Load Latest : Find exact version of partnames
Load Components : Load all the component parts
Failure Option : Do not abort load on failure
Load Fully : Do not fully load the component parts
Representations : Do not use lightweight
Load Substitution : Do not allow substitutions on load
Reference Sets : As Saved, Use Model, None, Empty
: Do not apply to all levels
Load Wave Data : Default load behaviour
Part family members : Regenerate missing members automatically
C:\temp\NXTest\NX10 example\model1.prt is on a ntfs filing system
Legacy Line Width Map
Thin - 0.35 mm
Normal - 0.70 mm
Thick - 1.40 mm
Versioning rules :-
PartNameFormat :-
PartNameSubstitution :-
PartNameMatch :-
VersionSubstitution :-
VersionType :- military
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\freetype.dll
Loaded module c:\windows\system32\msvcr100.dll 73420000 d2000 25656ec1-43b61750-ae93d896-4b98e1a9-1=msvcr100.amd64 version = 10.0.40219.325
Loaded module c:\program files\siemens\nx 10.0\ugii\freetype.dll 7fed42c0000 7e000 1654b51c-43fea75c-302270a2-d917fc76-1=freetype___130288923264 version = 8.0.0.19
*** EXCEPTION: Error code 928 in line 281 of o:\ugnx100\ip24\src\syss\sm\ind\sm_init.c at Mon Jun 22 18:32:39 2015 Eastern Daylight Time
Exception in secondary thread 5936
+++ SM call for area SM system transient area 0 from wrong thread
[ 1] 07FEE9053B74 (libsyss) [tid:5936,1]
[ 2] 07FEE905383B (libsyss) [tid:5936,1]
[ 3] 07FEE9054971 (libsyss) [tid:5936,1]
[ 4] 07FEE9054D02 (libsyss) [tid:5936,1]
[ 5] 07FEE9011F8E (libsyss) [tid:5936,1]
[ 6] 07FEE9010542 (libsyss) [tid:5936,1]
[ 7] 07FEE903378F (libsyss) [tid:5936,1]
[ 8] 07FEE902E9DC (libsyss) [tid:5936,1]
[ 9] 07FEE05FEFF6 (libpart) [tid:5936,1]
[10] 07FEE05FF347 (libpart) [tid:5936,1]
[11] 07FEE05FCFC7 (libpart) [tid:5936,1]
[12] 07FEE05FB482 (libpart) [tid:5936,1]
[13] 07FEE03D432D (libpart) [tid:5936,1]
[14] 07FEE04DA6CF (libpart) [tid:5936,1]
[15] 07FEE04D0506 (libpart) [tid:5936,1]
[16] 07FEE02961EC (libpart) [tid:5936,1]
[17] 07FEE0293CB2 (libpart) [tid:5936,1]
[18] 07FEE02938EE (libpart) [tid:5936,1]
[19] 07FEE8C1861A (libufunx) [tid:5936,1]
[20] 07FEEA88188C (libufun) [tid:5936,1]
[21] 07FEEA8827CA (libufun) [tid:5936,1]
[22] 00013FEDC28A rdnxreader\RDNXReader::Open Line 2065 +0x24a (Interface_NX) [tid:5936,1]
[23] 00013FDE52F1 cadinterfacethread\CadInterfaceThread::Process Line 47 +0x141 (Interface_NX) [tid:5936,1]
[24] 00013FEE977D progressthread\CProgressThread::Run Line 40 +0x6d (Interface_NX) [tid:5936,1]
[25] 07FED58C8B62 (mfc120ud) [tid:5936,1]
[26] 07FED518A105 (MSVCR120D) [tid:5936,1]
[27] 07FED518A357 (MSVCR120D) [tid:5936,1]
[28] 0000776159CD (kernel32) [tid:5936,1]
[29] 00007774B981 (ntdll) [tid:5936,1]
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_unload.c" at line number 1542
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_unload.c" at line number 2129
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_common.c" at line number 973
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_load.c" at line number 13561
Adding load status for C:\temp\NXTest\NX10 example\model1.prt - SM function called from the wrong thread (928)
Failed to load and update part "C:\temp\NXTest\NX10 example\model1.prt" cpu 1.311, real 4.790
Load failed "C:\temp\NXTest\NX10 example\model1.prt": CPU time: 1.311 secs, Real time: 4.790 secs
We have one application built on VC++ 2013 with NX 64-bit libraries in order to retrieve NX designs and save into our data.
Recently we found if our application is built with NX9 64-bit library and it works very well. But if it is build with NX10 64-bit library, it cannot load any NX .prt file. The Error Code 928 is caught.
Below is the log file. Any ideas will be really appreciated!
James
*** C:\temp\Inter5904870.syslog
*** system log created by [user name] on Mon Jun 22 18:32:30 2015 Eastern Daylight Time
Node Name :- m4213
Machine type :- GenuineIntel Family 6 Model 10 Stepping 5, Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
OS :- Windows NT (x64) 6.1 Windows 7 Professional (Build 7601) Service Pack 1
:- 64 bit software version
:- Session is running as administrator
# Processors :- 8
:- 1 packages, 4 cores, 8 logical processors
:- cache L1 256Kb / L2 1024Kb / L3 8192Kb
Memory :- 9207Mb
Total Swap :- 18412Mb
Free Swap :- 13773Mb
Machine supports 8TB address space
Running customer environment
Session is running in codeset 1252 17
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\ugxml.dll
UGXML is using 'UTF-8' as the local code page
************** Licensing Information **************
Server ID : ***** - OurCompamy
Webkey Access Code : *******
License File Issuer : SIEMENS
Flex Daemon Version : 11.10
Vendor Daemon Version String : 6.4
Toolkit Version : 6.4.2.1
************** Bundle Information **************
Number of bundles in use : 1
Bundle [ 0 ] : NX41000
Main executable was not signed
Attempting to see if main executable calls into a signed shared library
C:\svn\dev_new\stable_v9.5\Executable2013\x64\Debug\Interface_NX.exe - was not signed
C:\Windows\SYSTEM32\ntdll.dll - was not signed
C:\Windows\system32\kernel32.dll - was not signed
C:\Windows\system32\KERNELBASE.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libufun.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libjam.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsyss.dll - was not signed
C:\Windows\system32\MSVCR110.dll - was not signed
C:\Windows\system32\MSVCP110.dll - was not signed
C:\Windows\system32\ADVAPI32.dll - was not signed
C:\Windows\system32\msvcrt.dll - was not signed
C:\Windows\SYSTEM32\sechost.dll - was not signed
C:\Windows\system32\RPCRT4.dll - was not signed
C:\Windows\system32\USER32.dll - was not signed
C:\Windows\system32\GDI32.dll - was not signed
C:\Windows\system32\LPK.dll - was not signed
C:\Windows\system32\USP10.dll - was not signed
C:\Windows\system32\ole32.dll - was not signed
C:\Windows\system32\ODBC32.dll - was not signed
C:\Windows\system32\MPR.dll - was not signed
C:\Windows\system32\SHLWAPI.dll - was not signed
C:\Windows\system32\SHELL32.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libnxc.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpatch.dll - was not signed
C:\Windows\system32\CRYPT32.dll - was not signed
C:\Windows\system32\MSASN1.dll - was not signed
C:\Windows\system32\WINTRUST.dll - was not signed
C:\Windows\system32\OLEAUT32.dll - was not signed
C:\Windows\system32\WS2_32.dll - was not signed
C:\Windows\system32\NSI.dll - was not signed
C:\Windows\system32\COMDLG32.dll - was not signed
C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\COMCTL32.dll - was not signed
C:\Windows\system32\NETAPI32.dll - was not signed
C:\Windows\system32\netutils.dll - was not signed
C:\Windows\system32\srvcli.dll - was not signed
C:\Windows\system32\wkscli.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libufunx.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcmod.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libann.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcustdef.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugmath.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpman.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdisp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libasmo.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libassy.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libassybox.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdman.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugutils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\PSKERNEL.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\PFKERNEL.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmdpk.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdraw.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libassypos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libevaluator.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgeom.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgeomutil.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfacet.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libocc.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdmapplication.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdmservices.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugmr.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libklo.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfusion.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpart.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpkp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libinterop.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmodl.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfeatutils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartmodl.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcamsmom.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcsfadp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcsf.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmodlmath.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmodlgeom.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartdisp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartutils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgenpos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartnav.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libphymat.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpdi.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsket.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcoreblockdata.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartcommon.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libptr.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libimage.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtable.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\cg.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\cgGL.dll - was not signed
C:\Windows\system32\OPENGL32.dll - was not signed
C:\Windows\system32\GLU32.dll - was not signed
C:\Windows\system32\DDRAW.dll - was not signed
C:\Windows\system32\DCIMAN32.dll - was not signed
C:\Windows\system32\SETUPAPI.dll - was not signed
C:\Windows\system32\CFGMGR32.dll - was not signed
C:\Windows\system32\DEVOBJ.dll - was not signed
C:\Windows\system32\dwmapi.dll - was not signed
C:\Windows\system32\WINSPOOL.DRV - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpgs.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfeaturerecognition.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtceng_utils.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfacetstore.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtline.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libtemplate.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libfasthidden.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libnxpos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\xerces311.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\icuuc51.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\icudt51.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\liblwks.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmd.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\librout.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libcompos.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libautomotive.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpmi.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmsp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsmsputil.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libgdt.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libmswp.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libdctkloader.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libsbsm.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libpartmodule.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libuginit.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libugmi.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libhm.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libvsweep.dll - was not signed
C:\Program Files\Siemens\NX 10.0\UGII\libship.dll - was signed
NX 10.0.0.24
No user customizations read from UGII_PACKAGE_DIR - environment variable is not set
No user customizations read from UGII_SITE_DIR - environment variable is not set
No user customizations read from UGII_GROUP_DIR - environment variable is not set
No user customizations read from UGII_USER_DIR - environment variable is not set
Processing customer default values file C:\Users\[User_Name]\AppData\Local\Siemens\NX100\NX100_user.dpv
User customizations file C:\Users\[User_Name]\AppData\Local\Siemens\NX100\NX100_user.dpv does not exist
Failed to populate drafting standard data in level 1.
Failed to populate drafting standard data in level 2.
Failed to populate drafting standard data in level 3.
Processing drafting standard file C:\Program Files\Siemens\NX 10.0\ugii\drafting_standards\nx_ISO_Drafting_Standard_Shipped.dpv
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\application\liblinedesignerschemalocator.dll
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\application\liblinedesignerjalocator.dll
UPDATE: predefined fail option is <Unknown>
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libattr.dll
3D DCM version 480302004
Threaded compress ON decompress ON compression level 1
FR_PSMARK: system page size = 4096, ram block size = 1024, disk file threshold =32769, buffer size = 16384
*** Enabling SMP using 4 threads on 8 processors ***
Parasolid version 27.0 build 178 on 19:45:03 16-08-2014
CMOD delete: predefined, dumbify-feature option is <TRUE>
CMOD delete: predefined, propagate-delete option is <ON>
CMOD update: predefined, fail-on-missing-refs option is <OFF>
2D DCM version 630001001
Descriptive Part Names set to $FILENAME
Assemblies: Model reference set defined to be MODEL.
Lightweight Customer Defaults: Smart is disabled, Remove All
Parsing Ship Recipes file: C:\Program Files\Siemens\NX 10.0\nxship\data\ShipNamesRecipes.xml
Successfully parsed Ship Names Recipe of type Hull.
Successfully parsed Ship Names Recipe of type Deck.
Successfully parsed Ship Names Recipe of type Longitudinal Bulkhead.
Successfully parsed Ship Names Recipe of type Transverse Bulkhead.
Successfully parsed Ship Names Recipe of type Pillar System.
Successfully parsed Ship Names Recipe of type Stiffener System.
Successfully parsed Ship Names Recipe of type Edge Reinforcement System.
Successfully parsed Ship Names Recipe of type Seam.
Successfully parsed Ship Names Recipe of type Generic Plate System.
Successfully parsed Ship Names Recipe of type Standard Part.
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libnxvtk.dll
Command line:
A master env file has not been loaded
************** Locked Unigraphics Configuration Variables **************
UGII_PRODUCT_NAME NX
UGII_VERSION v10
UGII_FULL_VERSION v10.0.0.24
UGII_MAJOR_VERSION 10
UGII_MINOR_VERSION 0
UGII_SUBMINOR_VERSION 0
************** System Environment Variables **************
Path C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Siemens\NX 10.0\UGII\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;c:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\HP\Digital Imaging\bin;C:\Program Files (x86)\HP\Digital Imaging\bin\;C:\Program Files (x86)\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\TortoiseSVN\bin;c:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files (x86)\Intel\Compiler\Fortran\10.0.026\IA32\Bin\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
SPLM_LICENSE_SERVER 28000@m4213
TEMP C:\Users\[User_Name]\AppData\Local\Temp
TMP C:\Users\[User_Name]\AppData\Local\Temp
UGII_3DCONNEXION_LIBRARY C:\Program Files\Siemens\NX 10.0\ugalliance\vendor\startup\3DxNX.dll
UGII_BASE_DIR C:\Program Files\Siemens\NX 10.0
UGII_KEEP_SYSTEM_LOG YES
UGII_LANG english
UGII_ROOT_DIR C:\Program Files\Siemens\NX 10.0\UGII\
UGII_TMP_DIR C:\temp
UGII_UGDOC_BASE http:\\localhost:8181
UGS_LICENSE_SERVER 28000@m4213
UGS_LICENSING_NOTE on
USERDNSDOMAIN [User_DNS_domain_Name]
USERDOMAIN [User_domain_Name]
USERNAME [User_Name]
USERPROFILE C:\Users\[User_Name]
Using ugii_env.dat file from C:\Program Files\Siemens\NX 10.0\UGII\\ugii_env.dat
Using LineDesigner_env.dat file from C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\manifest\LineDesigner_env.dat
Using ugii_env_ug.dat file from C:\Program Files\Siemens\NX 10.0\UGII\\ugii_env_ug.dat
************** Unlocked Unigraphics Configuration Variables **************
UGCHECKMATE_HIDE_CHECKER %mqc_report_blanked_entity
PATH C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Siemens\NX 10.0\UGII\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;c:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\HP\Digital Imaging\bin;C:\Program Files (x86)\HP\Digital Imaging\bin\;C:\Program Files (x86)\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\TortoiseSVN\bin;c:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files (x86)\Intel\Compiler\Fortran\10.0.026\IA32\Bin\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\
UGII_PLATFORM x64wnt
HOME C:\Users\[User_Name]\AppData\Local\Temp
UGII_LANG english
UGII_LOCALIZATION_FILES C:\Program Files\Siemens\NX 10.0\localization\translations
GEARWIZARD_DIR C:\Program Files\Siemens\NX 10.0\localization\\GearWizard
GC_TOOL_DIR C:\Program Files\Siemens\NX 10.0\localization\\gc_tools
UGII_08_FILE C:\Program Files\Siemens\NX 10.0\ugopen\08.ugf
UGII_10_FILE C:\Program Files\Siemens\NX 10.0\ugii\10.ugf
UGII_SCHEMA C:\Program Files\Siemens\NX 10.0\ugii\ugschema
UGII_ENGLISH_THREADS C:\Program Files\Siemens\NX 10.0\ugii\thd_english.dat
UGII_METRIC_THREADS C:\Program Files\Siemens\NX 10.0\ugii\thd_metric.dat
UGII_OLD_SKETCH 0
UGII_DUMBIFY_FEATURE 1
UGII_WAVE_DELETE 0
MOLDWIZARD_DIR C:\Program Files\Siemens\NX 10.0\moldwizard
MOLDWIZARD_LIB_DIR C:\Program Files\Siemens\NX 10.0\moldwizard
ELECTRODE_DESIGN_DIR C:\Program Files\Siemens\NX 10.0\moldwizard\electrode
PDIEWIZARD_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\pdiewizard
PDIEWIZARD_LIB_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\pdiewizard
TOOLING_BASE_DIR C:\Program Files\Siemens\NX 10.0\tooling_base
EDIEWIZARD_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\ediewizard
EDIEWIZARD_LIB_DIR C:\Program Files\Siemens\NX 10.0\stamping_tools\ediewizard
UGWELD_DIR C:\Program Files\Siemens\NX 10.0\ugweld
UGII_WELD_BASE_DIR C:\Program Files\Siemens\NX 10.0\ugweld
UGII_UDF_LAYER_ORIGINAL 0
UGII_INOP_SE_IMPORT_ONLY_DESIGN_PART 0
NXDESIGNTOOLS_DIR C:\Program Files\Siemens\NX 10.0\design_tools
UGCHECKMATE_DIR C:\Program Files\Siemens\NX 10.0\design_tools\checkmate
UGCHECKMATE_CONFIG C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\customization\ugcheckmate.dat
UGCHECKMATE_XMLLOG_XSL_FILE C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\examples\checkmate_log.xsl
UGCHECKMATE_MENU_TEMPLATE_FILE C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\templates\user_defined_menu_template.txt
NXCHECKMATE_LOCALIZATION_DIR C:\Program Files\Siemens\NX 10.0\design_tools\checkmate\localization
NXREQUIREMENT_DIR C:\Program Files\Siemens\NX 10.0\design_tools\requirement
NXISSUETRACKING_DIR C:\Program Files\Siemens\NX 10.0\design_tools\issue_tracking
NXMARKUP_DIR C:\Program Files\Siemens\NX 10.0\design_tools\markup
UGII_CAM_BASE_DIR C:\Program Files\Siemens\NX 10.0\mach\
UGII_CAM_CUSTOM_DIR C:\Program Files\Siemens\NX 10.0\mach\custom\
UGII_CAM_RESOURCE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\
UGII_CAM_SAMPLES_DIR C:\Program Files\Siemens\NX 10.0\mach\samples\
UGII_CAM_AUXILIARY_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\
UGII_APT_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\apt.voc
UGII_BCL_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\bcl.voc
UGII_ISO_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\iso.voc
UGII_UNIMAJ_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\unimaj.voc
UGII_UNIMIN_VOC C:\Program Files\Siemens\NX 10.0\mach\auxiliary\unimin.voc
UGII_VERICUT C:\Program Files\Siemens\NX 10.0\win_nt\commands\vericut.bat
UGII_CAM_THREAD_MILL_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\thread_mill\
UGII_CAM_THREAD_MILL C:\Program Files\Siemens\NX 10.0\mach\auxiliary\thread_mill\thrm.dll
UGII_CAM_BATCH_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\batch\
UGII_CAMBATCH_BACKGROUND_EXE C:\Program Files\Siemens\NX 10.0\mach\auxiliary\batch\cambatch_background.exe
UGII_CAM_TAGGING_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\
UGII_CAM_TAGGING_DLL_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\application\
UGII_CAM_TAGGING_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\english\
UGII_CAM_TAGGING_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\auxiliary\tagging\metric\
UGII_CAM_FILE_SEARCH_PATH .\;C:\Program Files\Siemens\NX 10.0\mach\;C:\Program Files\Siemens\NX 10.0\mach\resource\
UGII_CAM_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\
UGII_CAM_CONFIG C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\cam_general.dat
UGII_SHOPS_DIE_MOLD_CONFIG C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\shops_diemold.dat
UGII_SHOPS_MACHINERY_CONFIG C:\Program Files\Siemens\NX 10.0\mach\resource\configuration\shops_machinery.dat
UGII_CAM_TEMPLATE_SET_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_set\
UGII_CAM_TEMPLATE_PART_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\
UGII_CAM_TEMPLATE_PART_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\
UGII_CAM_TEMPLATE_PART_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\
UGII_CAM_TEMPLATE_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\images\
UGII_CAM_LIBRARY_TEMPLATE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_dir\
UGII_CAM_LIBRARY_TEMPLATE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\template_dir\
UGII_CAM_SHOP_DOC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\shop_doc\
UGII_CAM_PART_DOC_CONFIG_FILE C:\Program Files\Siemens\NX 10.0\mach\resource\shop_doc\shop_doc.dat
UGII_CAM_POST_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\
UGII_CAM_POST_CONFIG_FILE C:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\template_post.dat
UGII_CAM_LIBRARY_MACHINE_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\
UGII_CAM_USER_DEF_EVENT_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\user_def_event\
UGII_CAM_TOOL_PATH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\tool_path\
UGII_CAM_WIZARD_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\wizard\
UGII_CAM_DEBUG_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\debug\
UGII_CAM_DEFAULT_TYPE_TEMPLATE C:\Program Files\Siemens\NX 10.0\mach\resource\template_set\cam_general.opt
UGII_CAM_IMAN_TYPE_TEMPLATE C:\Program Files\Siemens\NX 10.0\mach\resource\template_set\cam_teamcenter_general.opt
UGII_CAM_FEATURE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\
UGII_CAM_FEATURE_DATA_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\english\
UGII_CAM_FEATURE_DATA_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\metric\
UGII_CAM_FEATURE_IMAGES_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\feature\images\
UGII_CAM_SPREADSHEET_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\spreadsheet\
UGII_CAM_MACHINING_KNOWLEDGE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\machining_knowledge\
UGII_UG_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\ug_library\
UGII_CAM_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\
UGII_CAM_LIBRARY_TOOL_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\
UGII_CAM_LIBRARY_TOOL_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\ascii\
UGII_CAM_LIBRARY_TOOL_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\genius\
UGII_CAM_LIBRARY_TOOL_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\inclass\
UGII_CAM_LIBRARY_TOOL_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\english\
UGII_CAM_LIBRARY_TOOL_METRIC_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\metric\
UGII_CAM_LIBRARY_TOOL_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\mach\resource\library\tool\graphics\
UGII_CAM_LIBRARY_TOOL_ASCII_LOAD_LIMIT 100000
UGII_CAM_LIBRARY_DEVICE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\
UGII_CAM_LIBRARY_DEVICE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\ascii\
UGII_CAM_LIBRARY_DEVICE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\ascii\
UGII_CAM_LIBRARY_DEVICE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\inclass\
UGII_CAM_LIBRARY_DEVICE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\mach\resource\library\device\graphics\
UGII_CAM_LIBRARY_MACHINE_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\
UGII_CAM_LIBRARY_MACHINE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\ascii\
UGII_CAM_LIBRARY_MACHINE_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\ascii\
UGII_CAM_LIBRARY_MACHINE_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\genius\
UGII_CAM_LIBRARY_MACHINE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\inclass\
UGII_CAM_LIBRARY_MACHINE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\graphics\
UGII_CAM_LIBRARY_INSTALLED_MACHINES_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\machine\installed_machines\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_ASCII_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\ascii\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_DATA_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\ascii\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\feeds_speeds\genius\
UGII_CAM_LIBRARY_UDF_DIR C:\Program Files\Siemens\NX 10.0\mach\resource\library\udf\
UGII_UG_LIBRARY_GENIUS_TCP_HOST localhost
UGII_UG_LIBRARY_GENIUS_TCP_PORT 2326
UGII_INSPECTION_BASE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\
UGII_INSPECTION_RESOURCE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\
UGII_INSPECTION_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\configuration\
UGII_INSPECTION_CONFIG C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\configuration\inspection_general.dat
UGII_INSPECTION_USER_DEF_EVENT_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\user_def_event\
UGII_INSPECTION_TEMPLATE_SET_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_set\
UGII_INSPECTION_TEMPLATE_PART_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\
UGII_INSPECTION_TEMPLATE_PART_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\
UGII_INSPECTION_TEMPLATE_PART_METRIC_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\
UGII_INSPECTION_POST_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\postprocessor\
UGII_INSPECTION_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\
UGII_INSPECTION_LIBRARY_TOOL_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\
UGII_INSPECTION_LIBRARY_TOOL_ASCII_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\ascii\
UGII_INSPECTION_LIBRARY_TOOL_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\genius\
UGII_INSPECTION_LIBRARY_TOOL_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\inclass\
UGII_INSPECTION_LIBRARY_TOOL_ENGLISH_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\english\
UGII_INSPECTION_LIBRARY_TOOL_METRIC_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\metric\
UGII_INSPECTION_LIBRARY_TOOL_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\tool\graphics\
UGII_INSPECTION_LIBRARY_DEVICE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\
UGII_INSPECTION_LIBRARY_DEVICE_DATA_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\ascii\
UGII_INSPECTION_LIBRARY_DEVICE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\ascii\
UGII_INSPECTION_LIBRARY_DEVICE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\inclass\
UGII_INSPECTION_LIBRARY_DEVICE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\device\graphics\
UGII_INSPECTION_LIBRARY_MACHINE_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\
UGII_INSPECTION_LIBRARY_MACHINE_ASCII_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\ascii\
UGII_INSPECTION_LIBRARY_MACHINE_DATA_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\ascii\
UGII_INSPECTION_LIBRARY_MACHINE_GENIUS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\genius\
UGII_INSPECTION_LIBRARY_MACHINE_INCLASS_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\inclass\
UGII_INSPECTION_LIBRARY_MACHINE_GRAPHICS_PATH C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\graphics\
UGII_INSPECTION_LIBRARY_INSTALLED_MACHINES_DIR C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\library\machine\installed_machines\
UGII_KF_CLASS_DIR C:\Program Files\Siemens\NX 10.0\ugii\dfa
UGII_TAB_LABEL_FORMATS_FILE C:\Program Files\Siemens\NX 10.0\ugii\tab_label_format_file.xml
UGII_PMI_SYMBOL_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\ugii\symbol\PMI_Symbols
UGII_CGM_DEFAULTS C:\Program Files\Siemens\NX 10.0\ugii\cgmdef.txt
UGII_HELP_RELEASE_NOTES http:\\localhost:8181/tdoc/nx/10/release_notes/#uid:index
UGII_HELP_WHATS_NEW http:\\localhost:8181/tdoc/nx/10/whatsnew/#uid:index
UGII_HTML_UGDOC http:\\localhost:8181/tdoc/nx/10/nx_help/#uid:index
UGII_CSHELP_MAPS C:\Program Files\Siemens\NX 10.0\ugii\docmaps
UGII_CSHELP_DOCS http:\\localhost:8181/tdoc/nx/10/nx_help
UGII_CSHELP_API_DOCS http:\\localhost:8181/tdoc/nx/10/nx_api
UGII_CSHELP_DEFAULTS_DOCS http:\\localhost:8181/data_services/resources/nx/10/nx_help/en_US/graphics/fileLibrary/nx/cust_defaults/
UGII_CSHELP_FUSION_DOCS http:\\localhost:8181/data_services/resources/nx/10/nx_api/en_US/graphics/fileLibrary/nx/fusion/
UGII_LEARNING_CFM_URL https://www.siemens.com/plm/LearningAdvantage
UGALLIANCE_DIR C:\Program Files\Siemens\NX 10.0\ugalliance
UGII_DEFAULT_MENU_DIR C:\Program Files\Siemens\NX 10.0\ugii\menus
UGII_CUSTOM_DIRECTORY_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\custom_dirs.dat
UGII_UG_CUSTOM_DIRECTORY_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\ug_custom_dirs.dat
UGII_MAIN_MENU_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\ug_main.men
UGII_VIEW_POPUP_MENU_FILE C:\Program Files\Siemens\NX 10.0\ugii\menus\ug_view_popup.men
UGII_PMAN_XML_DEF_DIR C:\Program Files\Siemens\NX 10.0\LOCALIZATION
UGII_LOCAL_USER_DEFAULTS C:\Users\[User_Name]\AppData\Local\Siemens\NX100\NX100_user.dpv
UGII_CHARACTER_FONT_DIR C:\Program Files\Siemens\NX 10.0\ugii\ugfonts
UGII_CHARACTER_FONT_DEFAULT blockfont
UGII_EDITOR notepad
UGII_LIB1 C:\Users\[User_Name]\AppData\Local\Temp
UGII_LIB2 C:\Program Files\Siemens\NX 10.0\ugii\
UGII_UTIL C:\Program Files\Siemens\NX 10.0\ugii\
UGII_TAPEBAUD 1200
UGII_UGMX C:\Program Files\Siemens\NX 10.0\ugmx\me\etc\startmcad
UGII_MXUG_FILE C:\Users\[User_Name]\AppData\Local\Temp\
UGII_UGMX_FILE C:\Users\[User_Name]\AppData\Local\Temp\
UGII_SHARE C:\Program Files\Siemens\NX 10.0\UGII\
UGII_SPREADSHEET C:\Program Files\Siemens\NX 10.0\ugii\
UGII_LOAD_OPTIONS
UGII_PHYS_MATERIAL_LIB_DIR C:\Program Files\Siemens\NX 10.0\ugii\materials\english\
UGII_PHYS_MATERIAL_LIB_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugii\materials\
UGII_PHYS_MATERIAL_LIB_PATH .\;C:\Program Files\Siemens\NX 10.0\ugii\materials\
UGII_CAE_REPORT_TEMPLATES_DIR C:\Program Files\Siemens\NX 10.0\UGSTRUCTURES\
UGII_CAE_POST_TEMPLATE_USER_DIR C:\Users\[User_Name]\AppData\Local\Temp\post_template_files
USER_GEO_UNF *C:\Program Files\Siemens\NX 10.0\unfold\flatpat.grx
USER_PUNCHTOOLS *C:\Program Files\Siemens\NX 10.0\punchpress\buildtool.grx
USER_PUNCH *C:\Program Files\Siemens\NX 10.0\punchpress\punchlaser.grx
USER_PUNCHGRID *C:\Program Files\Siemens\NX 10.0\punchpress\punchgrid.grx
USER_PDAIF C:\Program Files\Siemens\NX 10.0\ugpatif\ugpatif
USER_ICADIF C:\Program Files\Siemens\NX 10.0\icadif\uficad
UNC_LANG eng
UNC_CAM_DIR C:\Program Files\Siemens\NX 10.0\sheetmfg\unc\
UGII_UGSMD_STDS_LIBRARY C:\Program Files\Siemens\NX 10.0\ugii\
UGII_ROUTE_UGMANAGER_MODE FALSE
UGII_ROUTE_ELEC_KIT_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec
UGII_ROUTE_MECH_KIT_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech
UGII_ROUTE_LGCL_KIT_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech
UGII_ROUTING_KIT_UNITS metric
UGII_ROUTING_APP_VIEW_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\appview\
UGII_ROUTE_ELEC_APP_VIEW C:\Program Files\Siemens\NX 10.0\ugroute_elec\appview\ugroute_elec_metric.xml
UGII_ROUTE_MECH_APP_VIEW C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\ugroute_mech_metric.xml
UGII_ROUTE_LGCL_APP_VIEW C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\ugroute_lgcl_metric.xml
UGII_EPLIB_PART_LIB_VIEW_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\appview\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\appview\
UGII_EPLIB_TABLE_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\tables\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\tables\
UGII_ROUTE_ELEC_PART_PATH C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\parts
UGII_ROUTE_MECH_PART_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\parts
UGII_ROUTE_LGCL_PART_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\parts
UGII_ROUTING_DESIGN_RULES_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\rules\;C:\Program Files\Siemens\NX 10.0\ugroute_elec\rules\
UGII_ROUTE_ELEC_TCL_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec\rules\tcl\
UGII_ROUTE_MECH_TCL_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\rules\tcl\
UGII_ROUTE_LGCL_TCL_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\rules\tcl\
UGII_RLIST_PATH C:\Program Files\Siemens\NX 10.0\ugroute_elec\rlist\
UGII_FMBD_FORMATS_FILE C:\Program Files\Siemens\NX 10.0\ugroute_elec\rlist\fmbd_annotation.fmt
UGII_FMBD_USE_LAYOUTS FALSE
UGII_FMBD_PATTERN_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\parts
UGII_FMBD_CGM_DIR C:\Program Files\Siemens\NX 10.0\ugroute_elec\metric\parts
UGII_FMBD_DISABLE_ROTATION_VECTOR_ALIGNMENT FALSE
UGII_RLIST_SCHEMA_FILE C:\Program Files\Siemens\NX 10.0\ugroute_elec\rlist\routelist.xsd
UGII_ROUTING_BOM_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\parts\
UGII_ROUTING_BEND_TABLES_PATH C:\Program Files\Siemens\NX 10.0\ugroute_mech\metric\tables\
UGII_ROUTE_SKIP_ENGAGE_CHARX TRUE
UGII_ROUTE_SKIP_LENGTH_ADDITION_CHARX TRUE
UGII_ROUTE_SKIP_ROUTING_LEVEL_CHECKING TRUE
UGII_ROUTE_CONVERT_SLACK_TO_LOCK_LENGTH TRUE
UGII_MECH_ROUTE_ISOGEN_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\isogen\
UGII_MECH_ROUTE_ISOGEN_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugroute_mech\isogen\\data\
MAYA_PCB_DIR C:\Program Files\Siemens\NX 10.0\ugpcbxchange
UGII_REFL_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugii\ugvisuals\
UGII_TEXTURE_TIFF_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugstudio\
UGII_NO_TIFF_SEARCH
UGII_LI_TOP C:\Program Files\Siemens\NX 10.0\ugphoto\ray_traced_studio
UGII_LI_CLBIN_DIR C:\temp
UGII_LI_LAYLA_DIR C:\Program Files\Siemens\NX 10.0\ugphoto
UGII_RENDER_ARTISTIC_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\artistic_render\
UGII_SHOWROOM_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\ug_environment
UGII_USER_SHOWROOM_DATA_DIR
UGII_CANNED_MATERIAL_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\ug_canned_mattex
UGII_HDR_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\hdr_images
UGII_ENV_IMAGE_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\env_images\
UGII_SYSTEM_SCENE_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\system_scene_data_dir
UGII_TRUESHADING_DIR C:\Program Files\Siemens\NX 10.0\ugphoto\true_shading
UGII_MAX_FACETING_SCALE 125.0
UGII_SDI_BASE C:\Program Files\Siemens\NX 10.0\nxplot
UGII_CGM2PDF C:\Program Files\Siemens\NX 10.0\nxplot\bin\pdf
UGII_SDI_OUTPUT_DIR C:\temp
UGII_SDI_PS_PAGE_SIZE 1
UGII_SDI_ALLOW_LARGE_TIF 1
UGII_SDI_EXPORT_NEW 1
STEP203UG_DIR C:\Program Files\Siemens\NX 10.0\step203ug\
STEP214UG_DIR C:\Program Files\Siemens\NX 10.0\step214ug\
DXFDWG_DIR C:\Program Files\Siemens\NX 10.0\dxfdwg\
IGES_DIR C:\Program Files\Siemens\NX 10.0\iges\
UGTO2D_DIR C:\Program Files\Siemens\NX 10.0\ugto2d\
UGII_CATIA_DIR C:\Program Files\Siemens\NX 10.0\ugcatia\
UGII_CATIAV5_DIR C:\Program Files\Siemens\NX 10.0\catiav5\
UGII_NXPROE_DIR C:\Program Files\Siemens\NX 10.0\nxproe\
UGII_SW_SCHEMA C:\Program Files\Siemens\NX 10.0\ugii
UGII_SW_LIBRARY C:\Program Files\Siemens\NX 10.0\ugii\CrossCadWareX64.dll
UGII_UGMANAGER_DIR C:\Program Files\Siemens\NX 10.0\ugmanager\
UGII_MSC_NASTRAN C:\Program Files\msc\bin\nastran.exe
UGII_NX_NASTRAN C:\Program Files\Siemens\NX 10.0\nxnastran\bin\nastran64L.exe
UGII_MSC_NASTRAN_VERSION 2005
UGII_NX_NASTRAN_VERSION 10
UGII_ANSYS C:\Program Files\ansys_inc\ansys100\win\v100\ANSYS\bin\intel\ansys100.exe
UGII_ANSYS_VERSION 10
UGII_ANSYS_PRODUCT ane3fl
UGII_ABAQUS C:\Program Files\abaqus\win\6.6-2\exec\abq662.exe
UGII_ABAQUS_VERSION 6.6
UGII_TMG_DIR C:\Program Files\Siemens\NX 10.0\nxcae_extras\tmg
UGII_MONITOR_DIR C:\Program Files\Siemens\NX 10.0\nxcae_extras\tmg\exe
UGII_CONVERT_OLD_MOTION_CONTACTS 0
UGII_CREATE_OLD_MOTION_CONTACTS 0
UG_IMAGE ugspawn.bat
UGII_USERFCN C:\Program Files\Siemens\NX 10.0\ugopen
UGII_GDT_DIR C:\Program Files\Siemens\NX 10.0\ugii\gdt_files
QUICKSTACK_DIR C:\Program Files\Siemens\NX 10.0\tolstackup\ugquickstack
UGII_QS_DEFS_DIR C:\Program Files\Siemens\NX 10.0\tolstackup\ugquickstack\application
TOLSTACKUP_DIR C:\Program Files\Siemens\NX 10.0\tolstackup
UGII_TSV_DEFS_DIR C:\Program Files\Siemens\NX 10.0\tolstackup\application
UGII_ANNOTATION_TEMPLATE_DIR C:\Program Files\Siemens\NX 10.0\ugii\inh_files\
UGII_TABLE_TEMPLATES C:\Program Files\Siemens\NX 10.0\ugii\table_files\
UGII_UPDATE_ALL_ID_SYMBOLS_WITH_PLIST 1
UGII_SURFACE_FINISH OFF
UGII_VSAEXPORT_DIR C:\Program Files\Siemens\NX 10.0\ugvsaexport
UF_MF_PA_PATH C:\moldflow\mpa300\bin
UF_MF_PA_FACET_TOL 0.05
UF_MF_PA_MAX_EDGE 10.0
UF_MF_PA_STL_DIR
UF_MF_PA_STL_SUF slp
UGII_FEAT_FAILURE_REPORT_TEMPLATE_FILE C:\Program Files\Siemens\NX 10.0\UGII\\xsl\FeatureFailureReportTemplate.xsl
UGII_ONESTEP_ANALYSIS_TEMPLATE_FILE C:\Program Files\Siemens\NX 10.0\UGII\\xsl\OnestepAnalysisTemplate.xsl
UGAUTOMOTIVE_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive
UGBODYDES_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\bodydes
UGDIEDES_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\diedes
UGDIEENG_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\dieeng
UG_VPACK_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging
AUTOSTAMPING_DATA_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\diedes
UGII_VD_WS_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_spreadsheet.xls
UGII_VD_WS_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_text.xml
UGII_VD_APO_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\a_pillar_obstruction_requirement_spreadsheet.xls
UGII_VD_APO_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\a_pillar_obstruction_requirement_text.xml
UGII_VD_MC_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\mirror_certification_requirement_spreadsheet.xls
UGII_VD_MC_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\mirror_certification_requirement_text.xml
UGII_VD_DFV_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\direct_field_view_requirement_spreadsheet.xls
UGII_VD_DFV_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\direct_field_view_requirement_text.xml
UGII_VD_DP_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\driver_posture_requirement_spreadsheet.xls
UGII_VD_DP_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\driver_posture_requirement_text.xml
UGII_VD_JOINT_REQ_SPREADSHEET_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\manikin_joint_angle_requirement_spreadsheet.xls
UGII_VD_JOINT_REQ_XML_FILE C:\Program Files\Siemens\NX 10.0\ugautomotive\packaging\requirements\manikin_joint_angle_requirement_text.xml
UGDIEDES_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugautomotive\diedes
NXSHIP_DIR C:\Program Files\Siemens\NX 10.0\nxship
NXSHIP_GSD_DIR C:\Program Files\Siemens\NX 10.0\nxship\shipgsd
NXSHIP_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\nxship\data
UGII_PYTHON_HOME C:\Program Files\Siemens\NX 10.0\ugii\python
UGII_PYTHON_DLL python33.dll
UGII_PYTHON_LIBRARY_DIR C:\Program Files\Siemens\NX 10.0\ugii\python
UGII_PYTHONPATH C:\Program Files\Siemens\NX 10.0\ugii\python;C:\Program Files\Siemens\NX 10.0\ugii\python\Python33.zip
JK_KIT C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit
JK_KIT_DEV C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit
JK_KIT_PLATFORM nt4
PYTHONPATH C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit\lib\python2.5;C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit\library\script;C:\Program Files\Siemens\NX 10.0\nxhuman\jack_toolkit\lib
UGII_BACKGROUND_URL C:\Program Files\Siemens\NX 10.0\UGTIPS\background\english\background.html
OT_PUB_APPLICATION_DIR C:\Program Files\Siemens\NX 10.0\pvtrans\ot_pub
UGII_DOTNET_USE_USER_DEFINED_KEYS 1
UGII_JVM_LIBRARY_DIR \bin\server
UGII_JVM_OPTIONS
UGII_CLASSPATH
PVTRANSUI_DIR C:\Program Files\Siemens\NX 10.0\pvtrans
UGII_DRAFTING_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\drafting_standards
UGII_LOCAL_USER_DRAFTING_STANDARD_DIR C:\Users\[User_Name]\AppData\Local\Siemens\NX100
UGII_PMI_DIR C:\Program Files\Siemens\NX 10.0\ugii\pmi
UGII_CAE_AFUAPP C:\Program Files\Siemens\NX 10.0\ugstructures\ftk\afuapp.jar
UGII_SCREW_CLEARANCE_HOLE_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\modeling_standards
UGII_THREADED_HOLE_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\modeling_standards
UGII_ENABLE_HOLE_SERIES 1
UGII_DRILL_SIZE_HOLE_STANDARD_DIR C:\Program Files\Siemens\NX 10.0\ugii\modeling_standards
UGII_DRAWING_COMPARE_OUTPUT_XML 0
UGII_SHIP_DRAFTING_DIR C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting
UGII_SHIP_DRAFTING_CONFIG_DIR C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\application
UGII_SHIP_DRAFTING_ANNOTATION_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_annotation_mapping_file.xml
UGII_SHIP_DRAFTING_AREACENTERLINES_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_area_centerline_mapping_file.xml
UGII_SHIP_DRAFTING_DRAFTINGLINES_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_drafting_line_mapping_file.xml
UGII_SHIP_DRAFTING_SYMBOLS_MAPPING C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\XML\ship_symbols_mapping_file.xml
UGII_SHIP_DRAFTING_ANNOTATION_SYMBOLS C:\Program Files\Siemens\NX 10.0\nxship\shipdrafting\symbol\ug_drafting_shipbuilding_default_symbols.sbf
UGII_TC_SOA_VERSION TC11000.1.0
NXREPORTS_DIR C:\Program Files\Siemens\NX 10.0\nxreports
NXVISUALREPORTING_DIR C:\Program Files\Siemens\NX 10.0\nxreports\visual_reporting
UGII_STEREO 1
UGII_STEREO_DISABLES_UI_TRANSPARENCY 1
UGII_STEREO_ADJUST_PERSPECTIVE_AUTOMATICALLY 1
UGII_LEGACY_TOL_FEAT_SETTINGS 0
UGII_ENABLE_TS_UPDATE_FOR_SLIVER_REGIONS 0
LOCALAPPDATA C:\Users\[User_Name]\AppData\Local
UGII_LANG english
LINE_DESIGNER_APP_DIR C:\Program Files\Siemens\NX 10.0\line_designer
NX_VERSION=10.0.0.24
Versions of DLLs are:
c:\program files\siemens\nx 10.0\ugii\dbghelp.dll 6.11.1.404 6e4c0000 169000 3678414c-4cb6b373-ddc11881-91f03434-1 18-Nov-2014 21:46
c:\program files\siemens\nx 10.0\ugii\pvmtoolkit.dll 0.27.0.70 7fed4380000 427000 0-0-0-0-0 18-Nov-2014 22:14
c:\program files\siemens\nx 10.0\ugii\vtk.dll 0.11.4.12 7fed47b0000 335000 0-0-0-0-0 18-Nov-2014 21:43
c:\program files\siemens\nx 10.0\ugii\libnxvtk.dll 10.0.0.24 7fed4af0000 d0000 49cf7f0f-4bb500e0-c7b290-dffcc72d-1=libnxvtk___1416455362cyp 19-Nov-2014 23:49
c:\program files\siemens\nx 10.0\ugii\libhidl.dll 10.0.0.24 7fed4d40000 54000 c9b3b954-4479df83-c9d8aa0-7ac35b91-1=libhidl___1416455823cyp 19-Nov-2014 23:57
c:\program files\siemens\nx 10.0\ugii\libattr.dll 10.0.0.24 7fed4bc0000 b1000 de36ac92-472a8614-f8f317b3-5444ff0b-1=libattr___1416456751cyp 20-Nov-2014 0:12
c:\program files\siemens\nx 10.0\line_designer\application\liblinedesignerjalocator.dll 10.0.0.24 7feeeec0000 d000 1c766765-457219ca-680f41a8-4d30fe7a-1=liblinedesignerjalocator___1416455666cyp 19-Nov-2014 23:54
c:\program files\siemens\nx 10.0\line_designer\application\liblinedesignerschemalocator.dll 10.0.0.24 7feeeed0000 7000 8ae8e712-4f5be8db-7f6be185-e860eff-1=liblinedesignerschemalocator___1416454626cyp 19-Nov-2014 23:37
c:\windows\system32\wship6.dll 6.1.7600.16385 7fefcc60000 7000 be71ccca-4d102676-1b946e83-d2c9de34-2 14-Jul-2009 1:41
c:\windows\system32\dhcpcsvc.dll 6.1.7600.16385 7fef7ec0000 18000 8dc91c79-44329e40-d41461ab-5d8c8d77-2 14-Jul-2009 1:40
c:\windows\system32\dhcpcsvc6.dll 6.1.7601.17970 7fef7ef0000 11000 4463cba8-447cf16f-e08fd585-1beea6ec-2 09-Oct-2012 18:17
c:\windows\system32\icmp.dll 6.1.7600.16385 733a0000 3000 55994337-48cf1b83-e8abb797-a37a1423-2 14-Jul-2009 1:27
c:\program files\siemens\nx 10.0\ugii\ugxml.dll 10.0.0.24 7fed4da0000 21000 7085b88f-4825056f-3e3169ab-31f441d7-1=ugxml___1416454537cyp 19-Nov-2014 23:35
c:\windows\system32\ntdsapi.dll 6.1.7600.16385 7fef9180000 27000 9e965c81-42fe0277-29adefae-fe8e75f7-2 14-Jul-2009 1:41
c:\windows\system32\wbem\fastprox.dll 6.1.7600.16385 7fef6bd0000 e2000 c00ea070-487950c6-aba4d88c-e21af810-2 14-Jul-2009 1:40
c:\windows\system32\wbem\wbemsvc.dll 6.1.7600.16385 7fef6a80000 14000 dfe6ffac-4abb97b2-fb7e25a9-356777e-2 14-Jul-2009 1:41
c:\windows\system32\wbemcomn.dll 6.1.7601.17514 7fef87b0000 86000 3a1fa1e9-49ea0abe-bad06cb9-ff424b85-2 20-Nov-2010 13:27
c:\windows\system32\wbem\wbemprox.dll 6.1.7600.16385 7fef8840000 f000 901a9329-4c144bba-1a530fab-8a3c0cad-2 14-Jul-2009 1:41
c:\windows\system32\netbios.dll 6.1.7600.16385 7fed4dd0000 a000 d704d499-4161beb8-4f76c299-4a24d0a5-2 14-Jul-2009 1:41
c:\windows\system32\rasadhlp.dll 6.1.7600.16385 7fef9280000 8000 c6a5b28b-48c4c3e7-f680b4aa-bad860a7-2 14-Jul-2009 1:41
c:\windows\system32\fwpuclnt.dll 6.1.7601.18283 7fef7f10000 53000 e9841642-48264d43-a08d1bb1-74229135-2 12-Oct-2013 2:29
c:\windows\system32\winnsi.dll 6.1.7600.16385 7fef97f0000 b000 20d0e4c9-45af82ca-a60f26a5-1856c2e6-2 14-Jul-2009 1:41
c:\windows\system32\iphlpapi.dll 6.1.7601.17514 7fefa400000 27000 8b5a2d4e-425e17ef-5777bb2-c792bcd3-2 20-Nov-2010 13:26
c:\windows\system32\winrnr.dll 6.1.7600.16385 7fef9270000 b000 9207717-4b377dfc-38e949bd-39817c37-2 14-Jul-2009 1:41
c:\windows\system32\dnsapi.dll 6.1.7601.17570 7fefcaf0000 5b000 94b9dfed-487e96e6-483f77a1-c36d6014-2 03-Mar-2011 6:24
c:\program files\common files\microsoft shared\windows live\wlidnsp.dll 7.250.4225.0 7fef9310000 2e000 eb02dea5-4a43b860-fbe1e196-f39b94b-1 21-Sep-2010 18:49
c:\windows\system32\pnrpnsp.dll 6.1.7600.16385 7fef91d0000 19000 7346e3b8-41fe3165-78b059b9-9acc857f-2 14-Jul-2009 1:41
c:\windows\system32\napinsp.dll 6.1.7600.16385 7fef91b0000 15000 d77abf6d-43d68c46-aa21a7a4-cb7e3453-2 14-Jul-2009 1:41
c:\windows\system32\nlaapi.dll 6.1.7601.17964 7fefab20000 15000 3edbfa33-4a04d500-9f63478b-986e2a39-2 03-Oct-2012 17:44
c:\windows\system32\wshtcpip.dll 6.1.7600.16385 7fefc610000 7000 cda0b508-4b9ab885-8b4b9b92-85b3a106-2 14-Jul-2009 1:41
c:\windows\system32\winmm.dll 6.1.7600.16385 7fefaf20000 3b000 df6e9d24-4ddf11ce-69c398b3-6bc95bd0-2 14-Jul-2009 1:41
c:\windows\system32\linkinfo.dll 6.1.7600.16385 7fef6f60000 c000 c2631c18-4b16996d-a4cd8f80-98aeb0d9-2 14-Jul-2009 1:41
c:\windows\system32\networkexplorer.dll 6.1.7601.17514 7fef0d80000 19c000 ec2b7b4e-43353312-827916bc-be8093a6-2 20-Nov-2010 13:27
c:\windows\system32\slc.dll 6.1.7600.16385 7fefa660000 b000 bec5c21c-44e4ffe1-2f04708e-271dff52-1 14-Jul-2009 1:41
c:\windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll 6.2.9200.16492 7fef6680000 4000 7b3fc2ad-45b8863b-9c1e30b3-a58f5b1c-1 14-Jun-2013 21:45
c:\windows\system32\ieframe.dll 11.0.9600.17840 7fef0f90000 dc3000 30378c67-430f46c8-b709378c-14fcf5ee-2 22-May-2015 17:57
c:\windows\system32\shdocvw.dll 6.1.7601.18222 7fef4db0000 34000 140dcf70-4638695f-b8e89e8f-6155b8ba-2 26-Jul-2013 2:24
c:\windows\system32\searchfolder.dll 6.1.7601.17514 7feead50000 d7000 9713a195-42aa67a2-5434cbb-84e3726b-2 20-Nov-2010 13:27
c:\windows\system32\psapi.dll 6.1.7600.16385 778e0000 7000 cabcb96-4c455961-85fc50a7-d6632a66-2 14-Jul-2009 1:41
c:\windows\system32\thumbcache.dll 6.1.7601.17514 7fef71a0000 1f000 ff0e912-42d955fe-cb26829b-c3b71cb5-2 20-Nov-2010 13:27
c:\windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll 6.2.9200.16492 7fefa480000 4000 132f4760-4c59bf95-ec6d719c-54fea763-1 14-Jun-2013 21:45
c:\program files\internet explorer\ieproxy.dll 11.0.9600.17840 7feef0b0000 ba000 a41c8756-4a2acfa2-1104ce8c-149c8877-2 22-May-2015 17:21
c:\windows\system32\actxprxy.dll 6.1.7601.17514 7fef3b60000 ee000 69c2fd19-42821a2c-139237a2-ad026b34-2 20-Nov-2010 13:25
c:\windows\system32\sspicli.dll 6.1.7601.18869 7fefd2a0000 25000 7fc8506a-4af236d1-3b55eeb0-ec78c43e-2 25-May-2015 18:19
c:\windows\system32\secur32.dll 6.1.7601.18869 7fefd240000 b000 e8cd8424-4b41c450-b21b5685-7abb16f4-2 25-May-2015 18:19
c:\windows\system32\structuredquery.dll 7.0.7601.17514 7feeae30000 7b000 1dd182a4-4a61de89-fa5aeb9-b5394ab0-1 20-Nov-2010 13:27
c:\windows\system32\xmllite.dll 1.3.1001.0 7fefb790000 35000 83e39fac-4f602fa2-570bd1a1-1e815291-2 16-Jun-2011 5:49
c:\windows\system32\msls31.dll 3.10.349.0 7fef4910000 42000 37ac0096-4e2cf922-c26ce585-346891e-2 16-Dec-2013 15:41
c:\windows\system32\cscapi.dll 6.1.7601.17514 7fef5e50000 f000 9a2b5950-4290695a-55a1cfa2-a4a6353c-2 20-Nov-2010 13:25
c:\windows\system32\cscdll.dll 6.1.7601.17514 7fef8040000 c000 83477b6b-4a83abbc-f2e1e480-e1fbc535-2 20-Nov-2010 13:25
c:\windows\system32\cscui.dll 6.1.7601.17514 7fef4960000 7e000 45ee018-4e9bcad0-15a8ed98-b3efd23a-2 20-Nov-2010 13:25
c:\windows\system32\ehstorshell.dll 6.1.7600.16385 7fef6120000 35000 c0b7993f-443e69de-63c3048b-e30827d6-1 14-Jul-2009 1:40
c:\windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcp90.dll 9.0.30729.6161 6f800000 d3000 61205b8e-42b8a845-8bddec86-b8dc04d7-1=msvcp90.amd64 01-Jul-2011 7:23
c:\program files\tortoisesvn\bin\intl3_tsvn.dll 0.14.4.0 180000000 17000 c327fef2-4336c770-af4d5eb0-4dff39ba-1 17-Apr-2010 16:10
c:\program files\tortoisesvn\bin\libaprutil_tsvn.dll 1.3.9.0 6ee60000 3d000 c6c23d5c-473ba47e-5be0d29f-db0fcafa-1 17-Apr-2010 16:10
c:\windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcr90.dll 9.0.30729.6161 74d80000 a3000 36e1a242-4825d264-db2eb9ab-a88c05d4-1=msvcr90.amd64 01-Jul-2011 7:23
c:\windows\system32\mswsock.dll 6.1.7601.18254 7fefcc70000 55000 1d73630d-481803bc-dd76c0b6-8ef5af90-2 08-Sep-2013 2:27
c:\program files\tortoisesvn\bin\libapr_tsvn.dll 1.3.8.0 6eec0000 2a000 bae7b101-426e3bfd-9f5d86b6-a499a074-1 17-Apr-2010 16:10
c:\windows\system32\userenv.dll 6.1.7601.17514 7fefd510000 1e000 9279a318-45e88c07-fb9db88b-671b0d6-2 20-Nov-2010 13:27
c:\windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll 6.2.9200.16492 7fefd500000 5000 9eadf45e-44a8cfab-b8955b9a-fa5e5768-1 14-Jun-2013 21:45
c:\windows\system32\iertutil.dll 11.0.9600.17840 7feff090000 2c7000 59a314e5-4058fa25-fb65ef9e-dfb1ea5f-2 22-May-2015 19:00
c:\windows\system32\normaliz.dll 6.1.7600.16385 778f0000 3000 c00c7f7-44c5797e-816f6582-418366b-1 14-Jul-2009 1:31
c:\windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll 6.2.9200.16492 7fefd4f0000 3000 d8e99801-401b5d4f-57b68c9d-c3fe333-1 14-Jun-2013 21:45
c:\windows\system32\api-ms-win-downlevel-version-l1-1-0.dll 6.2.9200.16492 7fefd760000 4000 db5dfd4e-4ae6294d-9597b8b0-f1c32159-1 14-Jun-2013 21:45
c:\windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll 6.2.9200.16492 7fefd750000 4000 ad372fe0-4793bacc-8d33a6bc-c749cf61-1 14-Jun-2013 21:45
c:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll 6.2.9200.16492 7fefd880000 4000 a9f1e723-464f81b9-18ec1585-a5f46f73-1 14-Jun-2013 21:45
c:\windows\system32\wininet.dll 11.0.9600.17840 7fefeda0000 25a000 87534f12-40661c9e-24f822b8-e88fca92-2 22-May-2015 17:50
c:\windows\system32\shfolder.dll 6.1.7600.16385 7fef8050000 7000 d94d04f6-4fe1baab-bc129299-7d76aa6-2 14-Jul-2009 1:41
c:\program files\tortoisesvn\bin\tortoisesvn.dll 1.6.8.19260 5590000 fe000 b8392a5-4202d1ce-7253f0b6-669a05e2-1=TortoiseShell 17-Apr-2010 16:10
c:\program files\tortoisesvn\bin\tortoisestub.dll 1.6.8.19260 5940000 10000 0-0-0-0-0 17-Apr-2010 16:10
c:\program files\common files\tortoiseoverlays\tortoiseoverlays.dll 1.1.1.19039 5960000 1b000 630458e1-45c83b44-5af657a0-2f95be54-1 21-Mar-2010 12:55
c:\windows\system32\apphelp.dll 6.1.7601.18777 7fefd2d0000 57000 664c4a18-44387f4a-1e2546b2-899880a3-2 04-Mar-2015 4:41
c:\windows\system32\windowscodecs.dll 6.2.9200.17251 7fefb620000 161000 58566eb3-44dfe01d-d8377694-bf26a7e2-1 03-Feb-2015 3:31
c:\windows\system32\dui70.dll 6.1.7600.16385 7fefba10000 f2000 5e6c1900-4d33d2e0-89596d8b-3edc7d67-2 14-Jul-2009 1:40
c:\windows\system32\duser.dll 6.1.7600.16385 7fefb9c0000 43000 6066e433-413b9825-58bfcf88-73775f85-2 14-Jul-2009 1:40
c:\windows\system32\explorerframe.dll 6.1.7601.17514 7fef3810000 1ca000 ddd7bebf-44c2392b-183e61be-5a73342e-2 20-Nov-2010 13:26
c:\program files\common files\microsoft shared\ink\tiptsf.dll 6.1.7601.18512 7fef2010000 7f000 3d4f7786-4c53feea-49480896-c3195fd2-1 18-Jun-2014 2:19
c:\windows\system32\profapi.dll 6.1.7600.16385 7fefd4d0000 f000 dc86d275-437fbbb0-4bcdb294-34b9d406-2 14-Jul-2009 1:41
c:\windows\system32\wldap32.dll 6.1.7601.17514 7fefebc0000 52000 8b747af7-4791eb20-b60d7eb5-bc5526d9-2 20-Nov-2010 13:27
c:\windows\system32\ntmarta.dll 6.1.7600.16385 7fefc020000 2d000 60a5ad5f-461cc924-76105abb-eecdeca8-2 14-Jul-2009 1:41
c:\windows\system32\propsys.dll 7.0.7601.17514 7fefb7f0000 12c000 df712cbf-4df1a5ab-1779d1a5-3ff5f8b6-2 20-Nov-2010 13:27
c:\windows\system32\sxs.dll 6.1.7601.17514 7fefd340000 91000 aa08dde0-4b7af906-c5c283b6-ef548e02-2 20-Nov-2010 13:27
c:\windows\system32\rpcrtremote.dll 6.1.7601.17514 7fefd420000 14000 eb674539-4fcb4d5b-beada088-1c7ba11e-2 20-Nov-2010 13:27
c:\windows\system32\rsaenh.dll 6.1.7600.16385 7fefc9d0000 47000 2bfa66bb-4b12f64f-a7e7b3b0-2d4ce58a-2 14-Jul-2009 1:43
c:\windows\system32\cryptsp.dll 6.1.7601.18741 7fefccd0000 18000 9dd8ff5e-4cdad686-fd99d396-a96ff856-1 03-Feb-2015 3:30
c:\windows\system32\version.dll 6.1.7600.16385 7fefc540000 c000 f7695888-4d77add1-5a42d593-17d71c6-2 14-Jul-2009 1:41
c:\program files\[our application]\common\xceedzipx64.dll 6.5.14460.0 7fed4f90000 c9000 eb2d96f2-42ea31b1-2306a68e-e258cde4-1 25-Sep-2014 23:37
c:\windows\system32\clbcatq.dll 2001.12.8530.16385 7feff360000 99000 60b9d310-440bc472-bf663fa1-e339fcf0-2 14-Jul-2009 1:40
c:\windows\system32\cryptbase.dll 6.1.7600.16385 7fefd330000 f000 f03e074b-4c9fb9e7-e4b0bf9b-aba0f32e-2 14-Jul-2009 1:40
c:\windows\system32\odbcint.dll 6.1.7600.16385 70ce0000 38000 0-0-0-0-0 14-Jul-2009 1:31
c:\windows\system32\imagehlp.dll 6.1.7601.18288 7fefed00000 19000 c957a42c-48d8302b-26e0029e-61494722-2 19-Oct-2013 2:18
c:\windows\system32\msvcp120d.dll 12.0.21005.1 7fed5060000 113000 6522ef5a-40fe8b49-2f6c44b0-9c1320de-1=msvcp120d.amd64 05-Oct-2013 3:58
c:\windows\system32\uxtheme.dll 6.1.7600.16385 7fefbfc0000 56000 b0692f27-454fb52c-c38a7ac-63e85d07-2 14-Jul-2009 1:41
c:\windows\system32\msctf.dll 6.1.7601.18731 7fefe860000 109000 933e1903-40fbd775-16beeaa7-f7126ca4-2 17-Jan-2015 2:48
c:\windows\system32\imm32.dll 6.1.7600.16385 7fefe830000 2e000 98f27ba5-41ecaee5-d00ce0be-ee0fd53a-2 14-Jul-2009 1:41
c:\windows\system32\msvcr120d.dll 12.0.21005.1 7fed5180000 211000 a9a944fa-4c0b7ed5-75cdf8b-7ca76e7d-1=msvcr120d.amd64 05-Oct-2013 3:58
c:\windows\system32\mfc120ud.dll 12.0.21005.1 7fed53a0000 a84000 4899bd79-43449817-ecacf5bc-78ea2139-17=mfc120ud.amd64 05-Oct-2013 3:58
c:\program files\siemens\nx 10.0\ugii\libdrfcmp.dll 10.0.0.24 7feea7f0000 13000 99915144-46e90eb3-21338d94-6f1e11db-1=libdrfcmp___1416454013cyp 19-Nov-2014 23:26
c:\program files\siemens\nx 10.0\ugii\libvdac.dll 10.0.0.24 7fed5e30000 ae000 789d99d0-45d2a1c8-8fb4e886-aad6e90-1=libvdac___1416457110cyp 20-Nov-2014 0:18
c:\windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18834_none_2b26557a71eb7442\gdiplus.dll 6.1.7601.18834 7fefbda0000 216000 e4eb4efa-424c9736-d701c8ab-ffc30acb-1=MicrosoftWindowsGdiPlus-1.1.7601.18834-gdiplus 20-Apr-2015 3:11
c:\program files\siemens\nx 10.0\ugii\libdrafting.dll 10.0.0.24 7fed5ee0000 1fb000 135e50b2-4f42697b-ae2c56ad-c4a4342f-1=libdrafting___1416455349cyp 19-Nov-2014 23:49
c:\program files\siemens\nx 10.0\ugii\libop2utils.dll 10.0.0.24 7fed60e0000 98000 5dc40f06-4234d81e-2e2764a3-f9f0d0e8-1=libop2utils___1416454752cyp 19-Nov-2014 23:39
c:\program files\siemens\nx 10.0\ugii\libschemalocator.dll 10.0.0.24 7fed6180000 29e000 dd5d69d7-405c225d-5b12e5a6-c8d5b9e7-1=libschemalocator___1416458429cyp 20-Nov-2014 0:44
c:\program files\siemens\nx 10.0\ugii\libaerosm.dll 10.0.0.24 7fed6420000 108000 e7398bbc-49de3dfe-1dc87b99-9f3f195c-1=libaerosm___1416452833cyp 19-Nov-2014 23:07
c:\program files\siemens\nx 10.0\ugii\libweld.dll 10.0.0.24 7fed6530000 485000 6eb0ce67-461471f7-c7d1dab4-cf180ed6-1=libweld___1416458275cyp 20-Nov-2014 0:38
c:\program files\siemens\nx 10.0\ugii\libmqccore.dll 10.0.0.24 7fed69c0000 132000 2b83db7e-46554b96-aff5d995-12a31948-1=libmqccore___1416457371cyp 20-Nov-2014 0:22
c:\program files\siemens\nx 10.0\ugii\libtoolingutils.dll 10.0.0.24 7fed6b00000 d1000 503a8344-4bf55144-11bbb395-73553d2-1=libtoolingutils___1416457022cyp 20-Nov-2014 0:17
c:\program files\siemens\nx 10.0\ugii\libkru.dll 10.0.0.24 7fed6be0000 26a000 8e833308-4dadba93-619a7183-3351c0f0-1=libkru___1416457872cyp 20-Nov-2014 0:31
c:\program files\siemens\nx 10.0\ugii\libship.dll 10.0.0.24 7fed6e50000 a15000 653ac8c3-4c09300c-110d1884-8c646ffc-1=libship___1416456502cyp 20-Nov-2014 0:08
c:\program files\siemens\nx 10.0\ugii\libvsweep.dll 10.0.0.24 7fed7870000 d0000 a0a19e56-41090518-554656ae-a6c9f80a-1=libvsweep___1416456128cyp 20-Nov-2014 0:02
c:\program files\siemens\nx 10.0\ugii\libhm.dll 10.0.0.24 7fed7940000 e0000 8c61fd55-45beaa5e-7f5a62ba-a5d0a58f-1=libhm___1416457075cyp 20-Nov-2014 0:18
c:\program files\siemens\nx 10.0\ugii\libugmi.dll 10.0.0.24 7fed7a20000 2d000 d5efd6e7-474424c1-6bf73792-71d19ead-1=libugmi___1416456161cyp 20-Nov-2014 0:02
c:\program files\siemens\nx 10.0\ugii\libuginit.dll 10.0.0.24 7fee9ff0000 22000 3e08f47d-4643466c-2498dd90-c4667ca5-1=libuginit___1416455757cyp 19-Nov-2014 23:56
c:\program files\siemens\nx 10.0\ugii\libpartmodule.dll 10.0.0.24 7fed7a50000 10f000 4f2fdba4-423f133d-9493b4b5-ea080bd9-1=libpartmodule___1416452701cyp 19-Nov-2014 23:05
c:\program files\siemens\nx 10.0\ugii\libsbsm.dll 10.0.0.24 7fed7b60000 59f000 eaf5f7ef-42976808-b01e97ad-356c3ef3-1=libsbsm___1416456375cyp 20-Nov-2014 0:06
c:\program files\siemens\nx 10.0\ugii\libdctkloader.dll 10.0.0.24 7feeacb0000 1c000 8d06bd3d-4d818468-349c2ebd-349c67ad-1=libdctkloader___1416455874cyp 19-Nov-2014 23:57
c:\program files\siemens\nx 10.0\ugii\libmswp.dll 10.0.0.24 7fed8100000 8c000 b1516bbb-496884a7-8b8597a0-cdcc038b-1=libmswp___1416456933cyp 20-Nov-2014 0:15
c:\program files\siemens\nx 10.0\ugii\libgdt.dll 10.0.0.24 7fed8190000 35d000 9551f8e5-468db7ce-c0cd6ba5-cad9b527-1=libgdt___1416454546cyp 19-Nov-2014 23:35
c:\program files\siemens\nx 10.0\ugii\libsmsputil.dll 10.0.0.24 7fed84f0000 38000 ab3e200f-4d8869f9-369e32af-89792b4d-1=libsmsputil___1416455864cyp 19-Nov-2014 23:57
c:\program files\siemens\nx 10.0\ugii\libsmsp.dll 10.0.0.24 7fed8530000 134000 9be33f88-488ea297-a668d895-b463172b-1=libsmsp___1416455523cyp 19-Nov-2014 23:52
c:\program files\siemens\nx 10.0\ugii\libpmi.dll 10.0.0.24 7fed8670000 8b3000 f8ea1499-4a95a7f9-ab73ea0-a26fe16c-1=libpmi___1416456261cyp 20-Nov-2014 0:05
c:\program files\siemens\nx 10.0\ugii\libautomotive.dll 10.0.0.24 7fed8f30000 c98000 c3c8af31-457eb323-e5d8ab4-6e9ff7c1-1=libautomotive___1416456038cyp 20-Nov-2014 0:01
c:\program files\siemens\nx 10.0\ugii\libcompos.dll 10.0.0.24 7fed9bd0000 18d000 3d880b1d-48d70621-fa2de38b-c3d0bb62-1=libcompos___1416453211cyp 19-Nov-2014 23:13
c:\program files\siemens\nx 10.0\ugii\librout.dll 10.0.0.24 7fed9d60000 bcb000 a92e0a35-40b42a32-478118ac-9360061b-1=librout___1416456653cyp 20-Nov-2014 0:11
c:\program files\siemens\nx 10.0\ugii\libsmd.dll 10.0.0.24 7feda930000 548000 eb65cffa-4f19f882-cf72ccad-d9287802-1=libsmd___1416455225cyp 19-Nov-2014 23:47
c:\program files\siemens\nx 10.0\ugii\liblwks.dll 10.0.0.24 7fedae80000 1f6000 7cab8167-46cab5ac-c3c68a9e-d83b623c-1=liblwks___1416457199cyp 20-Nov-2014 0:20
c:\program files\siemens\nx 10.0\ugii\icudt51.dll 51.2.0.0 6e630000 19f000 0-0-0-0-0 18-Nov-2014 21:47
c:\program files\siemens\nx 10.0\ugii\icuuc51.dll 51.2.0.0 6e9d0000 13d000 0-0-0-0-0 18-Nov-2014 21:20
c:\program files\siemens\nx 10.0\ugii\xerces311.dll 3.1.1.0 12000000 257000 42513dc3-47f0dc62-f7cc26ae-f0364fc7-1 18-Nov-2014 21:18
c:\program files\siemens\nx 10.0\ugii\libnxpos.dll 10.0.0.24 7fedb080000 98000 e2de0a5a-45a51ce8-c3494690-bd134381-1=libnxpos___1416456476cyp 20-Nov-2014 0:08
c:\program files\siemens\nx 10.0\ugii\libfasthidden.dll 10.0.0.24 7fedb120000 cf000 4a497dcd-45cb37c4-cc05ba3-11d3d27a-1=libfasthidden___1416455652cyp 19-Nov-2014 23:54
c:\program files\siemens\nx 10.0\ugii\libtemplate.dll 10.0.0.24 7fedb1f0000 3e000 7450ec81-4d307021-3edd18ba-1fa042e4-1=libtemplate___1416456936cyp 20-Nov-2014 0:15
c:\program files\siemens\nx 10.0\ugii\libtline.dll 10.0.0.24 7feeacd0000 24000 11c9341-43c76a2f-c71e3994-ae5fe965-1=libtline___1416457090cyp 20-Nov-2014 0:18
c:\program files\siemens\nx 10.0\ugii\libfacetstore.dll 10.0.0.24 7fedb230000 66000 eeb84873-40ab11e5-a895bea4-a8b90d5-1=libfacetstore___1416457432cyp 20-Nov-2014 0:23
c:\program files\siemens\nx 10.0\ugii\libtceng_utils.dll 10.0.0.24 7fef6110000 a000 5636552a-4d0341ee-dad3cc85-9fe4c567-1=libtceng_utils___1416454783cyp 19-Nov-2014 23:39
c:\program files\siemens\nx 10.0\ugii\libfeaturerecognition.dll 10.0.0.24 7feeeee0000 15000 bee9d055-4a7221b9-499a6bb3-b07878c2-1=libfeaturerecognition___1416458929cyp 20-Nov-2014 0:48
c:\program files\siemens\nx 10.0\ugii\libpgs.dll 10.0.0.24 7fedb2a0000 f0000 52ded56e-4d52411b-325c0bb5-f5d6a12c-1=libpgs___1416455735cyp 19-Nov-2014 23:55
c:\windows\system32\winspool.drv 6.1.7601.17514 7fef80e0000 71000 e75038c3-430e6e27-d64d3898-aabd36f9-1 20-Nov-2010 13:24
c:\windows\system32\dwmapi.dll 6.1.7600.16385 7fefb7d0000 18000 8683ed0c-40533dbe-2fc23e88-10f2b4d9-2 14-Jul-2009 1:40
c:\windows\system32\devobj.dll 6.1.7600.16385 7fefd7b0000 1a000 80698d17-4b78ff4b-32c6dc90-f4a78024-2 14-Jul-2009 1:40
c:\windows\system32\cfgmgr32.dll 6.1.7601.17514 7fefd840000 36000 9fa5840a-41874d3c-6421f699-e89d8ce9-2 20-Nov-2010 13:25
c:\windows\system32\setupapi.dll 6.1.7601.17514 7fefe970000 1d7000 59fe8950-47324c23-49999a3-fe04a83c-2 20-Nov-2010 13:27
c:\windows\system32\dciman32.dll 6.1.7601.18768 7fef6fd0000 8000 d0f88e14-4dc9d4ba-b5ef72a0-a85bf533-2 20-Feb-2015 4:40
c:\windows\system32\ddraw.dll 6.1.7600.16385 7fedb390000 f1000 21ffff82-4255952a-1a730bac-7d9a528a-2 14-Jul-2009 1:40
c:\windows\system32\glu32.dll 6.1.7600.16385 7feee9c0000 2d000 450a9fbd-4b80d1c1-bb518f8a-bed4c60c-1 14-Jul-2009 1:40
c:\windows\system32\opengl32.dll 6.1.7600.16385 7fedb490000 11d000 d4c4d41c-40a433d2-d3a48880-d67b00f-1 14-Jul-2009 1:41
c:\program files\siemens\nx 10.0\ugii\cggl.dll 2.0.0.15 6a400000 6a000 52b07d0d-4af12be7-319e8fb1-9317c9fe-1 18-Nov-2014 22:11
c:\program files\siemens\nx 10.0\ugii\cg.dll 2.0.0.15 6a000000 3b2000 c0928e75-4d0c45c6-3f4121ac-414aeafd-1 18-Nov-2014 21:58
c:\program files\siemens\nx 10.0\ugii\libtable.dll 10.0.0.24 7fedb5b0000 1cc000 572045ff-40ec9e63-280ed59f-6c4a7ce5-1=libtable___1416455375cyp 19-Nov-2014 23:49
c:\program files\siemens\nx 10.0\ugii\libimage.dll 10.0.0.24 7fedb780000 97000 952fd6d0-4b345293-f45557a9-c5a9013d-1=libimage___1416457884cyp 20-Nov-2014 0:31
c:\program files\siemens\nx 10.0\ugii\libptr.dll 10.0.0.24 7fedb820000 57000 b96c1129-4f3207b6-72a3eab4-cbaf78c0-1=libptr___1416452176cyp 19-Nov-2014 22:56
c:\program files\siemens\nx 10.0\ugii\libpartcommon.dll 10.0.0.24 7fef7240000 d000 8af0f4d2-45d378e6-7e79cba7-937573a1-1=libpartcommon___1416455507cyp 19-Nov-2014 23:51
c:\program files\siemens\nx 10.0\ugii\libcoreblockdata.dll 10.0.0.24 7fedb880000 204000 96a98317-484e963a-5fa9d68e-4cf9b794-1=libcoreblockdata___1416455292cyp 19-Nov-2014 23:48
c:\program files\siemens\nx 10.0\ugii\libsket.dll 10.0.0.24 7fedba90000 37d000 2ffe6f6f-4f5d485c-e890e29a-c548492c-1=libsket___1416458294cyp 20-Nov-2014 0:38
c:\program files\siemens\nx 10.0\ugii\libpdi.dll 10.0.0.24 7fedbe10000 c3000 a5c7b3f2-4fd48056-9f7a7dad-694f66a9-1=libpdi___1416454976cyp 19-Nov-2014 23:43
c:\program files\siemens\nx 10.0\ugii\libphymat.dll 10.0.0.24 7fedbee0000 141000 b3c02854-4b095099-f08fb7ae-56f59478-1=libphymat___1416456550cyp 20-Nov-2014 0:09
c:\program files\siemens\nx 10.0\ugii\libpartnav.dll 10.0.0.24 7feef240000 15000 577cb4ef-45ca294d-e9a1d48b-8896add2-1=libpartnav___1416456308cyp 20-Nov-2014 0:05
c:\program files\siemens\nx 10.0\ugii\libgenpos.dll 10.0.0.24 7fedc030000 8c000 21778c30-4ce069c3-33852f88-a5402b88-1=libgenpos___1416456071cyp 20-Nov-2014 0:01
c:\program files\siemens\nx 10.0\ugii\libpartutils.dll 10.0.0.24 7fedc0c0000 575000 8e8e355c-4cba9af1-fd496dba-72283867-1=libpartutils___1416452053cyp 19-Nov-2014 22:54
c:\program files\siemens\nx 10.0\ugii\libpartdisp.dll 10.0.0.24 7fedc640000 15a000 d649a4f1-49ae80cd-2beb8999-fbb166c1-1=libpartdisp___1416454992cyp 19-Nov-2014 23:43
c:\program files\siemens\nx 10.0\ugii\libmodlgeom.dll 10.0.0.24 7fedc7a0000 bd9000 43173cc-4a5f822b-1a893abe-173ba1d9-1=libmodlgeom___1416452133cyp 19-Nov-2014 22:56
c:\program files\siemens\nx 10.0\ugii\libmodlmath.dll 10.0.0.24 7fedd380000 48d000 f597f6e3-430411ba-e44b8aba-a3a9e3d8-1=libmodlmath___1416455875cyp 19-Nov-2014 23:58
c:\program files\siemens\nx 10.0\ugii\libcsf.dll 10.0.0.24 7fedd810000 1dc000 5fb6e9cb-4516acc4-ec1505a2-1a882513-1=libcsf___1416455073cyp 19-Nov-2014 23:44
c:\program files\siemens\nx 10.0\ugii\libcsfadp.dll 10.0.0.24 7fedd9f0000 70000 39062678-402daddc-f8d9dfb9-c74566b8-1=libcsfadp___1416452183cyp 19-Nov-2014 22:56
c:\program files\siemens\nx 10.0\ugii\libcamsmom.dll 10.0.0.24 7fedda60000 70000 89ff75d2-4be37b34-93234b89-2ccf5df9-1=libcamsmom___1416454015cyp 19-Nov-2014 23:26
c:\program files\siemens\nx 10.0\ugii\libpartmodl.dll 10.0.0.24 7feddad0000 1194000 75ba542c-4ca80ac2-47d8269a-e965493c-1=libpartmodl___1416456939cyp 20-Nov-2014 0:16
c:\program files\siemens\nx 10.0\ugii\libfeatutils.dll 10.0.0.24 7fedec70000 108000 c12c8f05-4a94d757-5f98419b-d5af3103-1=libfeatutils___1416451515cyp 19-Nov-2014 22:45
c:\program files\siemens\nx 10.0\ugii\libmodl.dll 10.0.0.24 7feded80000 13e2000 b23254d5-4193779f-6df01196-32484a19-1=libmodl___1416453370cyp 19-Nov-2014 23:17
c:\program files\siemens\nx 10.0\ugii\libinterop.dll 10.0.0.24 7feef180000 2d000 4422e979-432c5bfc-66b27dad-40137e80-1=libinterop___1416454017cyp 19-Nov-2014 23:27
c:\program files\siemens\nx 10.0\ugii\libpkp.dll 10.0.0.24 7fee0170000 10d000 d16550a8-48d650c5-ffd81f80-90d5ed20-1=libpkp___1416457246cyp 20-Nov-2014 0:20
c:\program files\siemens\nx 10.0\ugii\libpart.dll 10.0.0.24 7fee0280000 edb400 72a12983-48637e29-5960efac-d033873a-1=libpart___1416454643cyp 20-Nov-2014 1:04
c:\program files\siemens\nx 10.0\ugii\libfusion.dll 10.0.0.24 7fee1160000 91000 211a749b-4da51589-91bf63a0-8055e810-1=libfusion___1416459013cyp 20-Nov-2014 0:50
c:\program files\siemens\nx 10.0\ugii\libklo.dll 10.0.0.24 7fee1200000 10c000 a75f6d04-47bcb099-ae58eea1-b77cffbe-1=libklo___1416457106cyp 20-Nov-2014 0:18
c:\program files\siemens\nx 10.0\ugii\libugmr.dll 10.0.0.24 7fee1310000 58f000 308ff733-47517f15-d684c4b5-8ea892a9-1=libugmr___1416455472cyp 19-Nov-2014 23:51
c:\program files\siemens\nx 10.0\ugii\libdmservices.dll 10.0.0.24 7fee18a0000 1c9000 5b4f15d3-41503a77-f1cd3684-10d3e5f7-1=libdmservices___1416457492cyp 20-Nov-2014 0:25
c:\program files\siemens\nx 10.0\ugii\libdmapplication.dll 10.0.0.24 7fee1a70000 120000 36a8fd7d-4a637aa8-f125c5bd-e9f5923b-1=libdmapplication___1416451589cyp 19-Nov-2014 22:46
c:\program files\siemens\nx 10.0\ugii\libocc.dll 10.0.0.24 7fee1b90000 55b000 9e891310-4ce50d4b-e7f10c94-2031a8ee-1=libocc___1416453038cyp 19-Nov-2014 23:10
c:\program files\siemens\nx 10.0\ugii\libfacet.dll 10.0.0.24 7fee20f0000 38e000 f55a86ab-420a261a-110668b9-afab5333-1=libfacet___1416456739cyp 20-Nov-2014 0:12
c:\program files\siemens\nx 10.0\ugii\libgeomutil.dll 10.0.0.24 7fee2480000 ea000 4079e052-46320d4b-95cb3ba4-4b115a64-1=libgeomutil___1416457604cyp 20-Nov-2014 0:26
c:\program files\siemens\nx 10.0\ugii\libgeom.dll 10.0.0.24 7fee2570000 4f4000 d7b7f27e-4fe261d8-57e12c8c-1ea73c67-1=libgeom___1416457376cyp 20-Nov-2014 0:23
c:\program files\siemens\nx 10.0\ugii\libevaluator.dll 10.0.0.24 7fee2a70000 301000 87934ea9-4e6729ea-dba2bcab-be1768a0-1=libevaluator___1416457436cyp 20-Nov-2014 0:24
c:\program files\siemens\nx 10.0\ugii\libassypos.dll 10.0.0.24 7fee2d80000 58000 76cce9fa-44d02fbd-86128c-17cbd1a3-1=libassypos___1416456082cyp 20-Nov-2014 0:01
c:\program files\siemens\nx 10.0\ugii\libdraw.dll 10.0.0.24 7fee2de0000 939000 73089262-49e447a6-b796295-d307fc20-1=libdraw___1416454832cyp 19-Nov-2014 23:41
c:\program files\siemens\nx 10.0\ugii\libsmdpk.dll 10.0.0.24 7fee3720000 5d000 a8bde237-4fd882b8-d41f89a8-db8ef435-1=libsmdpk___1416457603cyp 20-Nov-2014 0:26
c:\program files\siemens\nx 10.0\ugii\pfkernel.dll 0.27.0.178 7fee3780000 120000 4875687b-4430852a-c935ff9a-e22c9f27-1=pfkernel_27_0_178 18-Nov-2014 22:06
c:\program files\siemens\nx 10.0\ugii\pskernel.dll 0.27.0.178 7fee38a0000 2854000 84960117-4d113c90-7e7e91be-d239b463-1=pskernel_27_0_178 18-Nov-2014 21:28
c:\program files\siemens\nx 10.0\ugii\libugutils.dll 10.0.0.24 7fee6100000 18e000 e5668b44-45af16c0-ea0cb3bc-ac687156-1=libugutils___1416457142cyp 20-Nov-2014 0:19
c:\program files\siemens\nx 10.0\ugii\libdman.dll 10.0.0.24 7fee6290000 5f000 e0d2dddc-4cc016bd-bf074db3-ddad4d5f-1=libdman___1416453307cyp 19-Nov-2014 23:15
c:\program files\siemens\nx 10.0\ugii\libassybox.dll 10.0.0.24 7fee62f0000 ac000 7e185870-408785ee-9cfbcfad-7d3e26fd-1=libassybox___1416453108cyp 19-Nov-2014 23:11
c:\program files\siemens\nx 10.0\ugii\libassy.dll 10.0.0.24 7fee63a0000 6a9000 3151739d-42696cac-84b9c29f-8ce5ee93-1=libassy___1416458050cyp 20-Nov-2014 0:34
c:\program files\siemens\nx 10.0\ugii\libasmo.dll 10.0.0.24 7fee6a50000 168000 12b1ea63-43b32505-3b2c86b8-97ff34d8-1=libasmo___1416456168cyp 20-Nov-2014 0:02
c:\program files\siemens\nx 10.0\ugii\libdisp.dll 10.0.0.24 7fee6bc0000 950400 6b2f5ddc-40b3d287-6603b194-d21d2f40-1=libdisp___1416453471cyp 20-Nov-2014 1:04
c:\program files\siemens\nx 10.0\ugii\libpman.dll 10.0.0.24 7feea020000 5e000 aa9f6ad1-4297b198-24d25fa9-f8d9713c-1=libpman___1416455275cyp 19-Nov-2014 23:47
c:\program files\siemens\nx 10.0\ugii\libugmath.dll 10.0.0.24 7feea080000 a8000 52d9256b-43800ac5-1b9b089e-bcfe99f3-1=libugmath___1416454967cyp 19-Nov-2014 23:42
c:\program files\siemens\nx 10.0\ugii\libcustdef.dll 10.0.0.24 7fee7520000 289000 5d2ad249-4a71b7de-8fad5f81-d00359ff-1=libcustdef___1416455304cyp 19-Nov-2014 23:48
c:\program files\siemens\nx 10.0\ugii\libann.dll 10.0.0.24 7fee77b0000 e13000 ed945561-4f1553c3-a92df91-f69bb5e9-1=libann___1416457927cyp 20-Nov-2014 0:33
c:\program files\siemens\nx 10.0\ugii\libcmod.dll 10.0.0.24 7fee85d0000 4fd000 b0fe3d94-4816907c-82327e88-509d07a4-1=libcmod___1416453236cyp 19-Nov-2014 23:14
c:\program files\siemens\nx 10.0\ugii\libufunx.dll 10.0.0.24 7fee8ad0000 45d000 6fca3722-46174857-a9f13382-29037c5a-1=libufunx___1416457507cyp 20-Nov-2014 0:25
c:\windows\system32\wkscli.dll 6.1.7601.17514 7fefb320000 15000 537df011-4d4f963e-28b691a7-38d7df7b-2 20-Nov-2010 13:27
c:\windows\system32\srvcli.dll 6.1.7601.17514 7fefcee0000 23000 a33e9ce1-4815c851-292ae391-58e113c2-2 20-Nov-2010 13:27
c:\windows\system32\netutils.dll 6.1.7601.17514 7fefc8b0000 c000 e65362a1-494aea9e-5624a185-b65be44d-2 20-Nov-2010 13:27
c:\windows\system32\netapi32.dll 6.1.7601.17887 7fefb340000 16000 f2840256-42060de6-39a10698-f517ee30-2 04-Jul-2012 22:16
c:\windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\comctl32.dll 6.10.7601.18837 7fefc050000 1f4000 b312550e-42f4a9b0-ad095c85-dc2050d8-1 24-Apr-2015 18:12
c:\windows\system32\comdlg32.dll 6.1.7601.17514 7feff750000 97000 631b5737-49fd6f85-aba8e7b2-df1f2d3d-2 20-Nov-2010 13:25
c:\windows\system32\nsi.dll 6.1.7600.16385 7feff000000 8000 dddd6b3d-49d5710d-92f61aa0-26cd1fa9-2 14-Jul-2009 1:41
c:\windows\system32\ws2_32.dll 6.1.7601.17514 7fefeb70000 4d000 348be7d2-495b2346-a27f1b84-d06b9903-2 20-Nov-2010 13:27
c:\windows\system32\oleaut32.dll 6.1.7601.18679 7fefec20000 d7000 90dcf6e7-4e284247-440fc5a4-2b9d8fd4-2 26-Nov-2014 3:53
c:\windows\system32\wintrust.dll 6.1.7601.18741 7fefd770000 3b000 f791bc19-45694886-776db095-727224b3-2 03-Feb-2015 3:31
c:\windows\system32\msasn1.dll 6.1.7601.17514 7fefd4e0000 f000 e973c31c-43dcb039-1c5430af-59aebba-2 20-Nov-2010 13:27
c:\windows\system32\crypt32.dll 6.1.7601.18741 7fefd5d0000 16d000 70580d87-49ee5943-6199ac82-77e8b41c-2 03-Feb-2015 3:30
c:\program files\siemens\nx 10.0\ugii\libpatch.dll 10.0.0.24 7fef9830000 7000 a3ea0d45-4c2df8b7-df64dd8e-41d73920-1=libpatch___1416452669cyp 19-Nov-2014 23:04
c:\program files\siemens\nx 10.0\ugii\libnxc.dll 10.0.0.24 7fef6650000 19000 154fc238-40e33860-f479b8af-8d592d38-1=libnxc___1416455186cyp 19-Nov-2014 23:46
c:\windows\system32\shell32.dll 6.1.7601.18762 7fefdaa0000 d89000 d2d567b7-4bddc03b-71477794-968738ac-2 13-Feb-2015 5:22
c:\windows\system32\shlwapi.dll 6.1.7601.17514 7feff010000 71000 820a075-4e250c1a-ea7de197-5449d057-2 20-Nov-2010 13:27
c:\windows\system32\mpr.dll 6.1.7600.16385 7fef8060000 18000 4f9e18e0-4b840067-eee7cb7-f253639c-2 14-Jul-2009 1:41
c:\windows\system32\odbc32.dll 6.1.7601.17514 7feea130000 b1000 c7cc7510-40e73718-97242b4-8d391be2-2 20-Nov-2010 13:27
c:\windows\system32\ole32.dll 6.1.7601.17514 7fefd890000 203000 ee489189-4d47724f-b5fdccae-35244853-2 20-Nov-2010 13:27
c:\windows\system32\usp10.dll 1.626.7601.18454 7feff590000 c9000 bffc0bc-461f51b8-ff5d8e97-9946e449-1 25-Apr-2014 2:34
c:\windows\system32\lpk.dll 6.1.7601.18768 7feff740000 e000 e475a859-4e4727bb-2cc28297-fb8465d4-2 20-Feb-2015 4:41
c:\windows\system32\gdi32.dll 6.1.7601.18778 7feff7f0000 67000 3da01606-4b22ebaf-1d38be80-fc04d294-2 05-Mar-2015 5:12
c:\windows\system32\user32.dll 6.1.7601.17514 77500000 fa000 953b0479-48b22b8a-e3303988-6a2ad26f-2 20-Nov-2010 13:27
c:\windows\system32\rpcrt4.dll 6.1.7601.18532 7feff860000 12d000 59235376-43a7d28d-2d89bd9b-4f89969b-2 14-Jul-2014 2:02
c:\windows\system32\sechost.dll 6.1.7601.18869 7fefeb50000 1f000 3824ad19-47aaab6c-e3d67088-8b73f171-1 25-May-2015 18:19
c:\windows\system32\msvcrt.dll 7.0.7601.17744 7feff990000 9f000 5376efb7-4b4dd7e5-f76f15a4-b0e64335-2 16-Dec-2011 8:46
c:\windows\system32\advapi32.dll 6.1.7601.18869 7feff660000 db000 91554e3a-421617b7-dffa18af-742c2101-2 25-May-2015 18:18
c:\windows\system32\msvcp110.dll 11.0.51106.1 7feee780000 a7000 cb6662b5-4792d109-d65dab8b-c89ca304-1=msvcp110.amd64 06-Nov-2012 3:26
c:\windows\system32\msvcr110.dll 11.0.51106.1 7fef7760000 d4000 d919f6d-4959d3b1-9813e7bd-6addb249-1=msvcr110.amd64 06-Nov-2012 3:26
c:\program files\siemens\nx 10.0\ugii\libsyss.dll 10.0.0.24 7fee8f30000 524000 8f80f4ae-4c747f65-c058b28c-fc266417-1=libsyss___1416456237cyp 20-Nov-2014 0:04
c:\program files\siemens\nx 10.0\ugii\libjam.dll 10.0.0.24 7fee9460000 70c000 65f06ffb-444d114b-7b56ceab-6b22f50d-1=libjam___1416454585cyp 20-Nov-2014 1:04
c:\program files\siemens\nx 10.0\ugii\libufun.dll 10.0.0.24 7feea810000 166000 e524203d-417369e7-bd013d93-8418e5cb-1=libufun___1416455333cyp 19-Nov-2014 23:49
c:\windows\system32\kernelbase.dll 6.1.7601.18869 7fefd7d0000 6c000 16612e92-44bf874f-1b2f14ae-37035276-2 25-May-2015 18:19
c:\windows\system32\kernel32.dll 6.1.7601.18869 77600000 11f000 6ce01243-4de4d1c7-15818caa-552e5897-2 25-May-2015 18:19
c:\windows\system32\ntdll.dll 6.1.7601.18869 77720000 1a9000 6279255-46362c5c-e1515690-18d7cd75-2 25-May-2015 18:21
c:\svn\dev_new\stable_v9.5\executable2013\x64\debug\Interface_nx.exe 9.5.0.0 13f660000 524e000 70020d54-403e347e-de0f3a5-414bc6e4-1 05-Jun-2015 20:06
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libcaeinit.dll
Loaded module c:\program files\siemens\nx 10.0\ugii\libcaeinit.dll 7feeee90000 1e000 2974cbdb-4bd25fe6-1233aa94-d5c4b916-1=libcaeinit___1416457452cyp version = 10.0.0.24
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\libcaminit.dll
Loaded module c:\program files\siemens\nx 10.0\ugii\libcaminit.dll 7fed4360000 15000 98397990-4d0d1c65-472256b6-1c77cf22-1=libcaminit___1416455126cyp version = 10.0.0.24
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\application\liblinedesignerinit.dll
Loaded module c:\program files\siemens\nx 10.0\line_designer\application\liblinedesignerinit.dll 7fed4340000 13000 c7e88754-42dce01c-206f18a1-acd6966-1=liblinedesignerinit___1416452098cyp version = 10.0.0.24
Processing C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\ugs_linedesigner_templates.pax for File New Templates
Added template: 'Equipment', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Equipment', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'Line', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Line', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'Zone', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Zone', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'Station', application: 'LineDesignerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-mm-part-template.prt'
Added template: 'Station', application: 'LineDesignerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\LINE_DESIGNER\templates\linedesigner-inch-part-template.prt'
Added template: 'A0 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A0-Size-template.prt'
Added template: 'A1 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A1-Size-template.prt'
Added template: 'A2 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A2-Size-template.prt'
Added template: 'A3 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A3-Size-template.prt'
Added template: 'A4 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A4-Size-template.prt'
Added template: 'A - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A-Size-template.prt'
Added template: 'B - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-B-Size-template.prt'
Added template: 'C - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-C-Size-template.prt'
Added template: 'D - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-D-Size-template.prt'
Added template: 'E - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-E-Size-template.prt'
Added template: 'F - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-F-Size-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_cae_templates.pax for File New Templates
Added template: 'NX Nastran', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranEnglish.fem'
Added template: 'NX Nastran', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranMetric.fem'
Added template: 'NX Nastran', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranEnglish.sim'
Added template: 'NX Nastran', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranMetric.sim'
Added template: 'NX Thermal/Flow', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxThermalFlowEnglish.fem'
Added template: 'NX Thermal/Flow', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxThermalFlowMetric.fem'
Added template: 'NX Thermal/Flow', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxThermalFlowEnglish.sim'
Added template: 'NX Thermal/Flow', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxThermalFlowMetric.sim'
Added template: 'NX Nastran Design', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranDesignEnglish.fem'
Added template: 'NX Nastran Design', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxNastranDesignMetric.fem'
Added template: 'NX Nastran Design', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranDesignEnglish.sim'
Added template: 'NX Nastran Design', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxNastranDesignMetric.sim'
Added template: 'MSC Nastran', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemMscNastranEnglish.fem'
Added template: 'MSC Nastran', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemMscNastranMetric.fem'
Added template: 'MSC Nastran', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimMscNastranEnglish.sim'
Added template: 'MSC Nastran', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimMscNastranMetric.sim'
Added template: 'Ansys', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAnsysEnglish.fem'
Added template: 'Ansys', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAnsysMetric.fem'
Added template: 'Ansys', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAnsysEnglish.sim'
Added template: 'Ansys', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAnsysMetric.sim'
Added template: 'Abaqus', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAbaqusEnglish.fem'
Added template: 'Abaqus', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemAbaqusMetric.fem'
Added template: 'Abaqus', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAbaqusEnglish.sim'
Added template: 'Abaqus', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimAbaqusMetric.sim'
Added template: 'NX Electronic Systems Cooling', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxElecSysCoolingMetric.fem'
Added template: 'NX Electronic Systems Cooling', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxElecSysCoolingEnglish.fem'
Added template: 'NX Electronic Systems Cooling', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxElecSysCoolingMetric.sim'
Added template: 'NX Electronic Systems Cooling', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxElecSysCoolingEnglish.sim'
Added template: 'NX Space Systems Thermal', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxSpaceSysThermalMetric.fem'
Added template: 'NX Space Systems Thermal', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxSpaceSysThermalEnglish.fem'
Added template: 'NX Space Systems Thermal', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxSpaceSysThermalMetric.sim'
Added template: 'NX Space Systems Thermal', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxSpaceSysThermalEnglish.sim'
Added template: 'LS-DYNA', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemLSDynaMetric.fem'
Added template: 'LS-DYNA', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemLSDynaEnglish.fem'
Added template: 'LS-DYNA', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimLSDynaMetric.sim'
Added template: 'LS-DYNA', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimLSDynaEnglish.sim'
Added template: 'NX Multiphysics', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxMultiPhysicsMetric.fem'
Added template: 'NX Multiphysics', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemNxMultiPhysicsEnglish.fem'
Added template: 'NX Multiphysics', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxMultiPhysicsMetric.sim'
Added template: 'NX Multiphysics', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimNxMultiPhysicsEnglish.sim'
Added template: 'Samcef', application: 'CaeFemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemSamcefMetric.fem'
Added template: 'Samcef', application: 'CaeFemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\FemSamcefEnglish.fem'
Added template: 'Samcef', application: 'CaeSimTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimSamcefMetric.sim'
Added template: 'Samcef', application: 'CaeSimTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\SimSamcefEnglish.sim'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_drawing_templates.pax for File New Templates
Added template: 'A0 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A0-Size2D-template.prt'
Added template: 'A1 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A1-Size2D-template.prt'
Added template: 'A2 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A2-Size2D-template.prt'
Added template: 'A3 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A3-Size2D-template.prt'
Added template: 'A4 - Size', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A4-Size2D-template.prt'
Added template: 'A - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A-Size2D-template.prt'
Added template: 'B - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-B-Size2D-template.prt'
Added template: 'C - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-C-Size2D-template.prt'
Added template: 'D - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-D-Size2D-template.prt'
Added template: 'E - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-E-Size2D-template.prt'
Added template: 'F - Size', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-F-Size2D-template.prt'
Added template: 'Layout - A0', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A0-Size2D-template.prt'
Added template: 'Layout - A1', application: 'DrawingTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A1-Size2D-template.prt'
Added template: 'Layout - C', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-C-Size2D-template.prt'
Added template: 'Layout - D', application: 'DrawingTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-D-Size2D-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_inspection_templates.pax for File New Templates
Added template: 'DMIS General Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy.prt'
Added template: 'Probe Tool', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_probe_assy.prt'
Added template: 'DMIS General Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy.prt'
Added template: 'Probe Tool', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_probe_assy.prt'
Added template: '0.7 mm Steel Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_07mm_steel.prt'
Added template: '18 ga Steel Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_18ga_steel.prt'
Added template: 'BS Rotary Machine Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_BSRotary_english.prt'
Added template: 'BS Rotary Machine Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_BSRotary_mm.prt'
Added template: 'Wenzel LH65 Tool Rack Machine Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_Wenzel_LH65_mm.prt'
Added template: 'Wenzel LH65 Tool Rack Machine Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_Wenzel_LH65_english.prt'
Added template: 'Renishaw Equator 300 Setup', application: 'InspectionTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\metric\insp_general_assy_Renishaw_Equator_300_mm.prt'
Added template: 'Renishaw Equator 300 Setup', application: 'InspectionTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\cmm_inspection\resource\template_part\english\insp_general_assy_Renishaw_Equator_300_english.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_manufacturing_templates.pax for File New Templates
Added template: 'General Setup', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\mill_planar_assy.prt'
Added template: 'General Setup', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\mill_planar_assy.prt'
Added template: 'Die Mold (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\DieMold_Express.prt'
Added template: 'Die Mold (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\DieMold_Express.prt'
Added template: 'Turning (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\Turning_Express.prt'
Added template: 'Turning (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\Turning_Express.prt'
Added template: 'Machinery (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\Machinery_Express.prt'
Added template: 'Machinery (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\Machinery_Express.prt'
Added template: 'Multi-Axis (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\MultiAxis_Express.prt'
Added template: 'Multi-Axis (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\MultiAxis_Express.prt'
Added template: 'Mill Turn (Express)', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\MillTurn_Express.prt'
Added template: 'Mill Turn (Express)', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\MillTurn_Express.prt'
Added template: 'Simulation Dual Table Sinumerik', application: 'CamTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\metric\simulation_dualtable_sinumerik.prt'
Added template: 'Simulation Dual Table Sinumerik', application: 'CamTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\mach\resource\template_part\english\\simulation_dualtable_sinumerik.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_mechatronics_templates.pax for File New Templates
Added template: 'General Setup', application: 'MechatronicsTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\mechatronics-inch-template.prt'
Added template: 'General Setup', application: 'MechatronicsTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\mechatronics-mm-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_model_templates.pax for File New Templates
Added template: 'Model', application: 'ModelTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\model-plain-1-inch-template.prt'
Added template: 'Model', application: 'ModelTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\model-plain-1-mm-template.prt'
Added template: 'Assembly', application: 'AssemblyTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\assembly-inch-template.prt'
Added template: 'Assembly', application: 'AssemblyTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\assembly-mm-template.prt'
Added template: 'Shape Studio', application: 'StudioTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\shape-studio-inch-template.prt'
Added template: 'Shape Studio', application: 'StudioTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\shape-studio-mm-template.prt'
Added template: 'Sheet Metal', application: 'NXSheetMetalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\sheet-metal-inch-template.prt'
Added template: 'Sheet Metal', application: 'NXSheetMetalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\sheet-metal-mm-template.prt'
Added template: 'Aero Sheet Metal', application: 'AeroSheetMetalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\aero-sheet-metal-inch-template.prt'
Added template: 'Aero Sheet Metal', application: 'AeroSheetMetalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\aero-sheet-metal-mm-template.prt'
Added template: 'Routing Logical', application: 'RoutingLogicalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-logical-inch-template.prt'
Added template: 'Routing Logical', application: 'RoutingLogicalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-logical-mm-template.prt'
Added template: 'Routing Mechanical', application: 'RoutingMechanicalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-mech-inch-template.prt'
Added template: 'Routing Mechanical', application: 'RoutingMechanicalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-mech-mm-template.prt'
Added template: 'Routing Electrical', application: 'RoutingElectricalTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-elec-inch-template.prt'
Added template: 'Routing Electrical', application: 'RoutingElectricalTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\routing-elec-mm-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_sheet_templates.pax for File New Templates
Added template: 'A - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A-Size2D-template.prt'
Added template: 'B - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-B-Size2D-template.prt'
Added template: 'C - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-C-Size2D-template.prt'
Added template: 'D - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-D-Size2D-template.prt'
Added template: 'E - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-E-Size2D-template.prt'
Added template: 'F - Size', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-F-Size2D-template.prt'
Added template: 'A0 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A0-Size2D-template.prt'
Added template: 'A1 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A1-Size2D-template.prt'
Added template: 'A2 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A2-Size2D-template.prt'
Added template: 'A3 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A3-Size2D-template.prt'
Added template: 'A4 - Size', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Drawing-A4-Size2D-template.prt'
Added template: 'Layout - A0', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A0-Size2D-template.prt'
Added template: 'Layout - A1', application: 'SheetTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-A1-Size2D-template.prt'
Added template: 'Layout - C', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-C-Size2D-template.prt'
Added template: 'Layout - D', application: 'SheetTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\Layout-D-Size2D-template.prt'
Processing C:\Program Files\Siemens\NX 10.0\UGII\templates\ugs_ship_templates.pax for File New Templates
Added template: 'Ship Reference', application: 'ShipReferenceTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-reference-inch-template.prt'
Added template: 'Ship Reference', application: 'ShipReferenceTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-reference-metric-template.prt'
Added template: 'Structural System', application: 'ShipSystemTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-system-inch-template.prt'
Added template: 'Structural System', application: 'ShipSystemTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-system-metric-template.prt'
Added template: 'Ship Container Assembly', application: 'ShipContainerTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-container-inch-template.prt'
Added template: 'Ship Container Assembly', application: 'ShipContainerTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-container-metric-template.prt'
Added template: 'Structural Detail', application: 'ShipDetailTemplate', units: 'English', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-detail-inch-template.prt'
Added template: 'Structural Detail', application: 'ShipDetailTemplate', units: 'Metric', file: 'C:\Program Files\Siemens\NX 10.0\UGII\templates\nxship-detail-metric-template.prt'
NX Load Options Are :-
Load Options : Load from directory
Load Latest : Find exact version of partnames
Load Components : Load all the component parts
Failure Option : Do not abort load on failure
Load Fully : Do not fully load the component parts
Representations : Do not use lightweight
Load Substitution : Do not allow substitutions on load
Reference Sets : As Saved, Use Model, None, Empty
: Do not apply to all levels
Load Wave Data : Default load behaviour
Part family members : Regenerate missing members automatically
C:\temp\NXTest\NX10 example\model1.prt is on a ntfs filing system
Legacy Line Width Map
Thin - 0.35 mm
Normal - 0.70 mm
Thick - 1.40 mm
Versioning rules :-
PartNameFormat :-
PartNameSubstitution :-
PartNameMatch :-
VersionSubstitution :-
VersionType :- military
Successfully loaded dynamic module C:\Program Files\Siemens\NX 10.0\ugii\freetype.dll
Loaded module c:\windows\system32\msvcr100.dll 73420000 d2000 25656ec1-43b61750-ae93d896-4b98e1a9-1=msvcr100.amd64 version = 10.0.40219.325
Loaded module c:\program files\siemens\nx 10.0\ugii\freetype.dll 7fed42c0000 7e000 1654b51c-43fea75c-302270a2-d917fc76-1=freetype___130288923264 version = 8.0.0.19
*** EXCEPTION: Error code 928 in line 281 of o:\ugnx100\ip24\src\syss\sm\ind\sm_init.c at Mon Jun 22 18:32:39 2015 Eastern Daylight Time
Exception in secondary thread 5936
+++ SM call for area SM system transient area 0 from wrong thread
[ 1] 07FEE9053B74 (libsyss) [tid:5936,1]
[ 2] 07FEE905383B (libsyss) [tid:5936,1]
[ 3] 07FEE9054971 (libsyss) [tid:5936,1]
[ 4] 07FEE9054D02 (libsyss) [tid:5936,1]
[ 5] 07FEE9011F8E (libsyss) [tid:5936,1]
[ 6] 07FEE9010542 (libsyss) [tid:5936,1]
[ 7] 07FEE903378F (libsyss) [tid:5936,1]
[ 8] 07FEE902E9DC (libsyss) [tid:5936,1]
[ 9] 07FEE05FEFF6 (libpart) [tid:5936,1]
[10] 07FEE05FF347 (libpart) [tid:5936,1]
[11] 07FEE05FCFC7 (libpart) [tid:5936,1]
[12] 07FEE05FB482 (libpart) [tid:5936,1]
[13] 07FEE03D432D (libpart) [tid:5936,1]
[14] 07FEE04DA6CF (libpart) [tid:5936,1]
[15] 07FEE04D0506 (libpart) [tid:5936,1]
[16] 07FEE02961EC (libpart) [tid:5936,1]
[17] 07FEE0293CB2 (libpart) [tid:5936,1]
[18] 07FEE02938EE (libpart) [tid:5936,1]
[19] 07FEE8C1861A (libufunx) [tid:5936,1]
[20] 07FEEA88188C (libufun) [tid:5936,1]
[21] 07FEEA8827CA (libufun) [tid:5936,1]
[22] 00013FEDC28A rdnxreader\RDNXReader::Open Line 2065 +0x24a (Interface_NX) [tid:5936,1]
[23] 00013FDE52F1 cadinterfacethread\CadInterfaceThread::Process Line 47 +0x141 (Interface_NX) [tid:5936,1]
[24] 00013FEE977D progressthread\CProgressThread::Run Line 40 +0x6d (Interface_NX) [tid:5936,1]
[25] 07FED58C8B62 (mfc120ud) [tid:5936,1]
[26] 07FED518A105 (MSVCR120D) [tid:5936,1]
[27] 07FED518A357 (MSVCR120D) [tid:5936,1]
[28] 0000776159CD (kernel32) [tid:5936,1]
[29] 00007774B981 (ntdll) [tid:5936,1]
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_unload.c" at line number 1542
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_unload.c" at line number 2129
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_common.c" at line number 973
>>>> Error code 928 caught in file "o:\ugnx100\ip24\src\part\no\ind\part_load.c" at line number 13561
Adding load status for C:\temp\NXTest\NX10 example\model1.prt - SM function called from the wrong thread (928)
Failed to load and update part "C:\temp\NXTest\NX10 example\model1.prt" cpu 1.311, real 4.790
Load failed "C:\temp\NXTest\NX10 example\model1.prt": CPU time: 1.311 secs, Real time: 4.790 secs
RE: Error code 928 caught when loading a .prt file in our VC++ application
Ben Loosli
