correction factor
correction factor
correction factor
can anybody explain me simply how correction factor of a flow transmeter FT works
i mean .. how it reads a specified flow on a pressure and temperature ... and in another place with different pressure and temperature it reads the same flow
thx
RE: correction factor
Are you talking about P+T compensation for flow measurement?
The selection of equation is depent on which Flow instrument type.
If you are using dp flow, this link may help you: -> http://www.eng-tips.com/viewthread.cfm?qid=320614
For other flow intrument type, you should check the manual from vendor.
Following is examination for I&C engineer from my friends:
To make things more complicated, there are correction factors for mol wt and Z also (in gas service).
