groove weld material thickness
Can a WPS be qualified to unlimited material thickness groove joint?
I know you can qualify up to 8" but what about thicker material??
moe27
moe27
RE: groove weld material thickness
(6) For test coupons over 6 in. (150 mm) thick, the full thickness of the test coupon shall be welded.
For the 1.5 " to 6" coupon thickness the maximum qualified for a WPS is 8"
Beyond the 6" coupon thickness, the coupon thickness qualified is 1.33T as the maximum thickness.
