Assembly question
Assembly question
Is it possible to change the way the default assembly mode works
When I open a a component from an assembly and do some work, then go back to the assembly, the component is the work part. If the assembly is large sometimes it takes a few minutes for the part to pop back to the assembly and then I have to right away double click top level to get the assembly active again
Is there a way to, when you go back to the main assembly, have the top level become active by default
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Win 7 Pro x64
RE: Assembly question
Preferences -> assemblies -> work part -> uncheck the "maintain" option. If this option is on, NX will try to make the displayed part the work part when switching back to the assembly. When it is turned off, the assembly will be the work part when switching back.
www.nxjournaling.com
NX 9.0.2.5 / PDW
Win 7 Pro x64
