Wanted - manufacturers of 'large' PCB circuits
I have a requirement to manufacture large, flexible (polyimide), double sided PCB's. Can anyone give me information on companies that have the capability to manufacture boards larger than the 600mm wide? Ideally I'd like at least 1metre x 1metre.
Thanks.
Matt B
Thanks.
Matt B
RE: Wanted - manufacturers of 'large' PCB circuits
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
Do you care what country the vendor is in?
Is this costs sensitive?
(linewidth, separation )? Do you need plated-through holes ?
<nbucska@pcperipherals.com>
My requirements are for 125micron Kapton with 1/2oz copper either side. The minimum track width is 200micron but I would be interested to learn how much I could reduce this to - I am in touch with a company that can photoplot to 10micron pattern accuracy.
I also have a requirement for accurate registration between the top and bottom sides. My contact can offer less than 19micron but unfortunately cannot find anyone that can make the boards from the plots.
The circuit is very simple and there are no drill holes required.
Thanks all.
Matt B
I forgot a couple of points.
The minimum separation in the pattern is 200micron. At this stage I need about 30 square metres. in the long term there may be a requirement for bulk manufacture - it depends on how I get on with the prototype.
Matt Bryanton
(with solder, conductive adhesive, etc)
Can U give more info ? (NDA OK )
Also, I don't require any solders, joins etc. to connect the 30sqm together.
Matt B
