NXInputBox
NXInputBox
NXInputBox
I am trying to add some code to my journal that would exit the sub when the user presses "Cancel".
Below is the code, it won't get past the inputbox line when the "Cancel" button is pressed so I can't check the value.
'----------USER INPUTS---------------------------------------------------------------------------------------
Dim UserInputNumber As Double
Dim JobNumber As String
UserInputNumber = NXInputBox.GetInputNumber("Enter a 5 Digit Job Number", "Jobnumber","")
If UserInputNumber.ToString = "" Then
'user pressed cancel
Exit Sub
End If
JobNumber = UserInputNumber
Kevin
NX8 Windows7
RE: NXInputBox
Dim answer As String = ""
Dim iuserentry As Integer
Do
Dim prompt As String = "Enter a 5 Digit Job Number"
Dim title As String = "Jobnumber"
Dim defaultvalue As String = ""
answer = NXInputBox.GetInputString(prompt, title,defaultvalue)
'if cancel is pressed, exit sub
If answer = "" Then Exit Sub
Loop Until Integer.TryParse(answer, iuserentry)
RE: NXInputBox
JXB0809,
Thank You!
