Multi-jog leader, triangle
I think I found a bug. I turned it into my VAR.
When using a note triangle, and change it to a multi-jog leader, the leader will jump around the triangle from the bottom to center to point when moving the triangle.
This only happens on the triangle, other shapes are good.
My guess is when the spline leader was introduced, it somehow carried over to the multi-jog leader.
Chris, CSWA
SolidWorks '15
SolidWorks Legion
