Can't get path stresses??
I am using Ansys for mechanical analysis. When I read in an RST file and use SET command, I can get stresses along a path. But when I assign the results to an load case ID using LCDEF, I get 0 stresses along the path. Any idea what I am missing?
-Al
RE: Can't get path stresses??
Make sure you read the load case by issuing the LCASE,# in /POST1 (where # is the number that you assigned using the LCDEF command).
/POST1
LCASE,#
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
So it seems when SUMTYPE,PRIN is used, you can't get path stresses or section stresses from load cases.
