dependent and independent part instances
hi all
I started using Abaqus recently for my summer internship. I dont seem to clearly understand the dependent and independent part instances despite reading about them in the abaqus tutorial site.could someone please explain them to me in simplest possible way? do cover their advantages/disadvantages and when & where either can be used.
thanks in advance.
thanks in advance.
RE: dependent and independent part instances
Read that and ask again if something is still not clear.
A/CAE Manual 13.3.2 What is the difference between a dependent and an independent part instance?
A/CAE Manual 13.3.3 How do I decide whether to create a dependent or an independent part instance?
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
@mustaine will check them out and get my doubts cleared if any; thanks! :)
@IceBreakerSours yup. i am new to this forum. will read the two posts. thank you !
