Min. Walkway or platform width
Hi
May I ask if anyone knows of any code statement or something from somehere that they give the limits for the width of an elevated walkway (outside of the building) parallel to building?
Type of structure: Steel structure in an Industrial Facility/Plant
Don't know to use 2'-6" , 3'-00" or 4'-00"?
I appreciate if anyone that has designed platforms and walkways let me know where to get the min. width for an elevated platform/walkway?
Purporse: We have cut an openning in higher level of exterior of a building, the walkway is along building (metal siding).
Thank you
Thank you
RE: Min. Walkway or platform width
NFPA 101 table 40.2.5.2.1 - Industrial equipment access dimensional criteria
Minimum horizontal dimension of any walkway, landing, or platform - 22" clear
http://publicecodes.cyberregs.com/icod/ibc/2009/ic...
IBC 2012 has the code moved into another section, but I believe the general requirement hasn't changed.
Thaidavid
