Concrete cone failure
Does anyone know if I want to check the concrete cone failure according to the BS code(probably due to an anchor bolt), should be used the concrete maximum allowable shear stress, i.e. 0.8*(fcu)^0.5, or use the concrete shear stress, vc?? Thanks for reply!!!
