How to design polymer?
Hello, I was assigned to help design a small plastic structure. My background is more in concrete. I modeled the structure using FEA. The structure will be buried and loaded with soil cover and vehicle load. My questions are the following:
1. What shall I use as my limiting factor? Shall I use the yield strength of the material? Do I add some kind of reduction factor to account for creep? Is there a design book I can follow?
2. When I design concrete we typically factor the load instead of Factor of Safety. The load factors are determined by AASHTO. From what I see so far, most people use unfactored load and use factor of safety to design plastic. How do you determine the Factor of Safety?
Thank you!
Thank you!
RE: How to design polymer?
Chris DeArmitt PhD
President - Phantom Plastics LLC
Trusted adviser to leading companies around the world
www.phantomplastics.com
Chris DeArmitt PhD
Amorphous polymers creep less than semi-crystalline ones in general. You want the thermoplastics to have a Tg above the highest use temperature as well. Then load it up with glass fiber or even better, carbon fiber (way more expensive).
