Surface normal vector orientation
Group,
I'm currently modeling a fluid storage tank that is under a pressure load. I'm having difficulties getting the applied pressure loads to be applied in the same direction for all of the surfaces. Some of the surfaces have the load vector pointing inwards on the tank and others are point outward (preferred direction). I'm using FEMAP 9.3.1 under NeiNastran. I'm been searching for hours trying to find the normal vector orientation of the surfaces and then a method to modify the vector for that surface. Any help would be greatly appreciated.
Yes, I've though about reversing the pressure sign on the wrong load vectors, but it would be very clumsy and time consuming.
Thank you.
Thank you.
RE: Surface normal vector orientation
If you have access to this command you're lucky but if not you should upgrade to the latest Femap versions:
- Modify / Update Other / Surface Normal
or
- Geometry / Solid / Stitch
You can also apply the pressure loads directly on elements then you should correctly orient their normal vectors:
-Modify / Update Elements / Reverse Normal
Good Luck
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac û France
If yes, I can help you to create the "pressure loads" through the normal vector of the elements surface (that should point outwards).
