Stress under circular loads
I need to calculate the vertical stresses under a circular uniform load (a reactor) but I need to do this for random points. So I cannot use the Boussinesq formula as it refers only to points below the circle axis.
Also, since I need to do this for almost 2,500 points, I cannot use diagrams and tables. Is there any analytical solution, some equation or anything else I can use in Excel?
RE: Stress under circular loads
If you can use charts or tables, Elastic Solutions for Soil and Rock Mechanics by Poulos and Davis has good ones and is available free online.
Boussinesq is for a uniform pressure on a semi-infinite isotropic medium, of course. Your reactor foundation is probably pretty rigid, and your soil layer is not semi-infinite (there is rock down there somewhere). So you results can be mathematically correct, but far from the truth. Be especially careful about the pressures near the edge of a rigid foundation, which can be very high. The above book has useful solutions for rigid foundations and infinite thicknesses of soil.
My problem is the following:
I have a rectangular raft foundation which also carries one extra uniformly loaded rectangular load and one circular. The foundation level is 9 meters from the ground level and the water table is 3 meters from the ground level. I have created a spreadsheet that calculates the vertical stress caused by each of the three loads but I am confused about which is the q included in the equations; I have read that it is the load applied by the structures minus the weight of the excavated soil. By ''weight of the excavated soil'' it is meant the effective stress at foundation level (3*γb+6*γsat-6*γwater) ??
Also, since I am not familiar with the term:
which one is the average gross effective foundation pressure?
I would appreciate very much your help since it has been a long time that I have not dealt with geotechnical issues.
