maximum steel structure span without expansion joint
dears,
according to ASCE, AISC or UBC what is maximum steel structure span without expansion joint ,
in other word what is the maximum steel structure span can be designed without take effect of temperature variation loads .,
RE: maximum steel structure span without expansion joint
It depends on the configuration of your building, the anticipated temperature range, etc. Unfortunately there isn't all that much information out there: Link. Based on the ubiquitous tech report #65 graph, 200 ft seems to be the catchall maximum. I don't know of any specific limitations in the codes.
thanks KootK
