Missing reference points on import of *inp file
I am generating part geometries external to the Abaqus environment and importing them via *.inp files
In these files I add a reference point by including the following lines;
Where node 11 is the reference point in this instance.
But the reference point does not get imported with the *.inp file.
Anybody know why?
CODE -->
*Node
11, 0., 0., 0.
*Nset, nset=RIGIDCONTACTTEMPLATE_1-RefPt_, internal
11, Where node 11 is the reference point in this instance.
Anybody know why?
RE: Missing reference points on import of *inp file
Also, to be sure, are the display settings set to default? Sometimes I turn a something off and end up banging my head against the wall for not being able to see something in the Viewer.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
I finally fixed it by assigning the reference point inside the import script I was using.
