Section view doesn't show up...?
I have a problem with section view after I change drafting standard from TOOLS/DRAFTING STANDARD.
I will try to explain in details:
1. I enter drafting mode and create new drawing with company template
2. I go to TOOLS/DRAFTING STANDARD and change it to DIN
3. I place BASE VIEW and select SECTION VIEW/select parent view/define cut position and when NX asks to INDICATE CENTER OF SECTION VIEW ON SHEET nothing happens, wherever I click no section view appears?
This doesn't happens if I don't change drafting standard.
Please help me because I will have mental breakdown from this software.
Thank you
P.S. I use NX 7.5
RE: Section view doesn't show up...?
Check in the section view dialog under the settings area. It's most likely set to section line only.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
THAT WAS IT, CANT BELIEVE IT!!!
Thank you
