Custom Flange Design
Hi Guys,
I need some info in regards to performing custom flange design calculations on a storage tank.
I use PVElite software to perform the flange design calculations and always have used the bolting material like A193-B8 or A193-B8M class 1 or class 2 bolting which are listed materials in ASME SEC VIII and AS 1210 code.
Now my question is can we use the structural bolting like A2-70 or A4-70 to perform the flange design calculations even if these bolting material or type isn't listed in any of the codes above.
I really appreciate the help...
Chandanraj
Chandanraj
RE: Custom Flange Design
So, yes you can perform the calculations but the resulting design will not be Code compliant due to non-listed material.
Mike
