Double Induction Case Hardening
I saw this thread and was looking for additional detail. I am currently a studying metallurgical engineer interning at a plant where this is sometimes the common practice. They try to reach a case depth of >50Rc at .050 inches, and <40 at .100 inches. Occasionally a part will be over hardened and be around 50Rc at 0.110, for example. Can this simple be reran through? Currently when this happens it runs through and is not rechecked. But would the martensite down at .110 be tempered enough or transformed to reduce the hardness below 30Rc?
Any thoughts would be appreciated. It is ran so as to be only case hardened. Therefore the core is not heated and only the surface, which leads me to believe that it would be too hard still farther down if they merely ran it at paramaters to harden it to 0.050.
Link to a previously closed thread below.
thread330-255489: double induction & quenching
RE: Double Induction Case Hardening
I'll be sure and post any conclusions I come to here for future similar issues.
