Select all hidden lines in drawing
Is it possible to select all hidden lines in particular view. If I want to hide all hidden lines, I can hide it by view properties. But, in my case, i have shown one particular component visible in hidden line mode by using overload properties. My requirement is I want particular rib and hole on that component only need to show. Remaining hidden lines of that component to be removed. For that, now I am selecting by CTRL key. If I able to select all hidden lines in one click, then I can deselect that particular hole and rib & hide all remaining things. Kindly provide any idea if it is possible by filter or search.
Suresh
RE: Select all hidden lines in drawing
You can do an EDIT + Search. In the GENERAL option, hit the MORE button to see the options for Line Properties.
Hi Jackk,
Thanks for the reply. It is working fine. Earlier, i was unable to select hidden lines in the search option. From your idea, i came to know that we can select additional properties from 'more' option. Definitely it will improve my drafting skill.
Suresh
