trim and extend help is solid works 2014
Sir Maam,
I using a SOLID WORKS 2014having problem with trim and exend feature in solid works. iam making a mast with cross
but when i sure the trim eand extend , the reuslt is not the way i want, i still dint conseder ma main post as part of the trimming bodies. i encounter this many namy times . and the my work harder and slower. can i please elp me this one??
a attached the said problem.
RE: trim and extend help is solid works 2014
It worked fine for me. Simply select the bodies to be trimmed, then use face/plane and the bottom face of the upper chord.
Jeff Mirisola, CSWE
My Blog
You need to trim to the face, not the bodies... It is "fish mouthing" the joints.
There is a check box for trimming to face or body.
David
Connect with me on LinkedIn. http://lnkd.in/fY7-QK
Quote: "If it ain't broke, I must not've fixed it good enough"
