French Drain question
I live in California where the soil is mostly clay. I'm having a French drain put around the house to keep the water out. Got two bids...with each contractor using a different technique.
Both are recommending to dig 12"-16" trench, 6" below the foundation, put in a 4" perforated PVC pipe, place a 10mil plastic liner on the foundation side, fill trench with crushed rock. The differences are:
Contractor #1 will do the above and also wrap the gravel with a geo Fabric. Slope of the pipe will be 1/8" for every foot. (pretty standard)
Contractor #2 will do the above but does not want to wrap the gravel or pipe with geo fabric. He will slope the pipe 1/4" for every foot and have several clean out along the system.
Contractor #2s reasoning is that the geo fabric will eventually clog up and reduce water flow and eventually fail. He allows some of the dirt to flow into the pipe and the steeper slope helps the dirt to flow out. Plus he recommends flushing the pipe with a garden hose every couple of years to wash way any soil build up.
Anyone have any experience of not using fabric to wrap the gravel? Has anyone experienced geo fabric clogging with Clay soil?
thanks
dave
PS- I read some of the other informative threads that recommend using sand vs rock as the filler.
thanks
dave
RE: French Drain question
You can solve all these questions by specifying that all backfill around the pipe and maybe up a foot or so should be ASTM C-33 Fine aggregate (not coarse aggregate). This is commonly the fine aggregate used in concrete, sometimes called Torpedo sand in my area. Depending on the hole or slot sizes in the pipe, here may or may not be the need for a sock on the pipe. Concrete sand is a perfect all-around filter. This was proven in the 1930's by an extensive study by the US Corps of Engineers.
To be sure these well meaning, but ignorant in these things, contractors from still using crushed rock, specify that no crushed rock, single sized rock, open graded rock is allowed on the property.
I've been preaching this treatment of under drains ever since I received my Masters Degree studying these forms of drains in highway applications in 1956. Unfortunately for years folks have figured that rock with big voids will drain fast, but they forget about all the stuff that fills those voids. I've never had one of my installations plug up!!
If you want more proof look up US Navy NAFAC manuals on the internet,probably in DM-7. In my old version Figure 8-8 shows this subject deadline with filters of various types.
After doing this backfill properly it hardly makes any difference which slope, and other treatments, since you will prevent plugging of the system.
You may hear from guys who surround all that crushed rock with filter fabric. It works, but is labor intensive to do it right, especially in caving ground and is more costly than my simple method that really can't be done wrong.
B+W Engineering and Design | Los Angeles Civil Engineer and Structural Engineer http://bwengr.com
f-d
ípapß gordo ainÆt no madre flaca!
