Journal: Getting the source part occurrence of a WAVE link
I'm writing a program to allow the user to select a new source assembly which will automatically re-link all wave links in a part to the new source assembly. That way the user doesn't have to manually re-link every wave link feature when parts/assemblies are copied, renamed etc.
To get the current source part of a wave link feature, I use this:
CODE -->
ufs.Wave.AskLinkSource(in_linkedfeature, in_allowload, out_sourceentity)
Dim outObject As NXObject = NXObjectManager.Get(out_sourceentity)
out_part = outObject.OwningPart
but out_part is the prototype part. What if there are many instances of the same prototype part, how can I find out which part instance the wave link feature is linking to?
I've tried this:
CODE -->
Dim partocc As Tag = ufs.Assem.AskPartOccurrence(out_sourceentity)
but it returns null.
NX10.0 Win8.1 64bit i7-3770K 16GB Quadro2000
RE: Journal: Getting the source part occurrence of a WAVE link
Below is a short journal that will find the parent "component" by using the UF function: AskAssyCtxtPartOcc.
To use it, create a small assembly: add a part as a component - specify a number of duplicates (spread them out - use the "scatter" option). Add a new empty part as a component and create a wave linked mirror body feature in the new part; pick any component instance you like to be the parent of the mirror body. Give the "parent component" a unique name, this will help when testing the journal (RMB the component, properties, general, enter name, OK). Run the journal with the assembly as the displayed/work part. The journal will process all the components and report the parent component of the linked mirror body. Parts must be fully loaded for the journal to work, journal only reports the first linked mirror body found in each component. The same strategy will work for other linked features, this journal only looks specifically for linked mirror bodies.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
        Const undoMarkName As String = "NXJ journal"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Try
            Dim c As ComponentAssembly = theSession.Parts.Display.ComponentAssembly
            If Not IsNothing(c.RootComponent) Then
                'lw.WriteLine("processing components...")
                ProcessChildren(c.RootComponent, 0)
            Else
                '*** insert code to process piece part
                'lw.WriteLine("Part has no components")
            End If
        Catch e As Exception
            theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
        End Try
        lw.Close()
    End Sub
    Sub ProcessChildren(ByVal comp As Component, _
    ByVal indent As Integer)
        'lw.WriteLine("component: " & comp.DisplayName)
        Dim linkedFeature As Features.Feature
        For Each child As Component In comp.GetChildren()
            Dim part1 As Part = child.Prototype.OwningPart
            linkedFeature = ProcessFeatures(part1)
            If Not IsNothing(linkedFeature) Then
                Dim theXformTag As Tag
                Dim fromPartOccTag As Tag
                Dim fromComp As Assemblies.Component
                theUfSession.Wave.AskLinkXform(linkedFeature.Tag, theXformTag)
                theUfSession.So.AskAssyCtxtPartOcc(theXformTag, child.Tag, fromPartOccTag)
                fromComp = Utilities.NXObjectManager.Get(fromPartOccTag)
                lw.WriteLine("linked from part: " & fromComp.Prototype.OwningPart.Leaf & " [component name: " & fromComp.Name & "]")
                lw.WriteLine("")
            End If
            ProcessChildren(child, indent + 1)
        Next
    End Sub
    Function ProcessFeatures(ByVal thePart As Part) As Features.Feature
        'return first linked mirror feature
        For Each myfeature As Features.Feature In thePart.Features
            If myfeature.FeatureType = "LINKED_MIRROR" Then
                lw.WriteLine("linked mirror body feature found in part: " & thePart.Leaf)
                Return myfeature
            End If
        Next
        Return Nothing
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Thanks cowski, that helps.
However, here is a situation where AskAssyCtxtPartOcc fails:
Create an assembly like this:
MAIN.PRT
SOURCE1.PRT
A.PRT
A.PRT
A.PRT
A.PRT (A-4)
A.PRT
SOURCE2.PRT
A.PRT
A.PRT
A.PRT
A.PRT (A-4)
A.PRT
B.PRT
Suppress SOURCE2.PRT. Create the linked mirror body to A-4 from SOURCE1.PRT. Run your journal (include code to ignore suppressed parts, like If child.Prototype.OwningPart IsNot Nothing Then).
The journal works fine.
Now suppress SOURCE1.PRT and unsuppress SOURCE2.PRT. Run the journal again. Now AskAssyCtxtPartOcc gives null.
Is there a way to find the identical A-4 from SOURCE2?
