Get Length
Get Length
Hello,I was wondering if somebody could tell me how to measure the length along the x, y and z coordinates of every model part in the assembly in a journal. I tried using the bounding box function but the numbers it is giving me will not work. I'd have to use a transformation matrix to convert them to the correct values. Are there other functions I can use?
RE: Get Length
There are several program there dealing with the Bounding Box function.
"create part attributes from exact bounding box" might be close to what you're looking for.
