New Drafting BOM Column: value = value of the qty columns * 1.1 ?
In NX8.5, is there a possibility to have in a BOM column the value of the quantity column multiplied by a user constant value?
RE: New Drafting BOM Column: value = value of the qty columns * 1.1 ?
Just turn on the 'evaluate cell as formula'.
Then in the default text field put in $~Q*1.1 (or whatever multiplier you need).
To use 1.1, make sure the number of decimal places for the column is set as well.
The image below shows how it's done
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
