Are Lt. wt. fittings always seamless?
Are Light weight fittings (eg. elbow, reducers) always seamless? Thanks
RE: Are Lt. wt. fittings always seamless?
size is normally more important as is manufacturing technique.
Most B16 elbows and reducers I have seen are seamless.
why do you ask?
When asking engineering questions, you must be far more specific with the words you use when writing your questions.
Piping Design Central
I am asking to know what the longitudinal seam factor would be. For instance seamless or ERW = 1 as longitudinal factor. Thanks
There is no change in anything whether the fitting is seamless or welded for the same material.
Most people try not to get the longitudinal seam lined up on connecting pipe / fittings, but other than that I don't know where you would use a factor like that on a fitting
