Failure (frayed) of boiler steam Drum gasket
What are the factors to consider to determine the cause of failure of boiler steam drum gasket during testing of safety valve at 1450 psi, our normal working pressure is 1350 psi.
RE: Failure (frayed) of boiler steam Drum gasket
