Co-simulation:time increment error message in Abaqus
HI GUYS!
I'm doing a co-simulation in Abaqus but after many steps the analysis abortes with the following error:
''The Abaqus Analysis is terminated because the time increment is smaller than minimum allowable increment size specified on the procedure option'' (in Abaqus Standard-Explicit).
I tried to run the CFD alone and it works, so the error is just that one in Abaqus Standard. I reduced the time increment but the analysis abortes again with the same message (but with more steps).
Do you know how to solve such a problem?
thanks in advance
anna
thanks in advance
anna
RE: Co-simulation:time increment error message in Abaqus
