venturi optimization
How can a venturi for air induction be optimized? I am inducing air into a closed vessel via water flowing circumferentially about a tube vented to atmosphere. The nature of the water flow creates a negative pressure (vacuum) and induces air into the closed volume (there is a one-way check valve at the "top" of the tube to prevent water from escaping as the closed volume becomes pressurized). Any experience with venturi induction is appreciated...
