three wire female connector
green to green is easy on the cable the remaining two are black and white on the female connector one of the screw is silverish, the other is a little yellowish
where does the black go, and where the white?
i have seen similar questions in other forums
one answer said put this on the hot side which is the hot side if i knew that for sure i would'nt ask you
another answer said the one on the right of the green i shot the one on the the left
thank you
thank you
RE: three wire female connector
the green or green/yellow wire goes to the green (ground) screw,
the white (neutral) wire goes to the silvery (neutral) screw,
the wire of any other color (hot), usually black,
goes to the goldish/brass/yellow (hot) screw.
If you have difficulty installing the wires neatly, it probably means you're putting the connector on the wrong end of the cable.
If the above is not absolutely crystal clear to you,
PLEASE PAY AN ELECTRICIAN TO DO THE WORK.
It won't take long, and it may save your life.
Electricity is serious shit.
Mike Halloran
Pembroke Pines, FL, USA
regards
HOT
NEUTRAL
SAFETY GROUND
Some of us are old enough to remember the television advertisements for the introduction of the "3-PRONG PLUG".
You should be very careful. Mistakes can have serious consequences.
Before terminating any circuit, shut off the breaker so there are no hot wires.
Mike Halloran
Bill
"Why not the best?"
Jimmy Carter
