NXOpen AskBoundaries error with CamDrive
I am attempting to find the number of drive boundaries within a fixed-contour Cam operation and am having the same issue as found in this post.
Any help would be greatly appreciated.
This is the code that I am using:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ask_boundary_count
    Dim theSession As Session = Session.GetSession()
    Dim WorkPart As Part = theSession.Parts.Work
    Dim DisplayPart As Part = theSession.Parts.Display
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If WorkPart IsNot Nothing Then
            Dim setupTag As Tag
            ufs.Cam.InitSession()
            ufs.Setup.AskSetup(setupTag)
            Try
                Dim selectedTags() As NXOpen.Tag
                Dim selectedCount As Integer
                lw.Open()
                lw.WriteLine(vbLf & "Searching for selected nodes...")
                ufs.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
                If selectedCount <= 0 Then
                    lw.WriteLine("No CAM node selected...exit")
                    Return
                End If
                lw.WriteLine(" Found " & selectedCount & " selected nodes...")
                Dim inx As Integer = 0
                Dim setBnd() As IntPtr
                ufs.Cambnd.AskBoundaries(selectedTags(0), CamGeomType.CamDrive, inx, setBnd)
                lw.WriteLine("count " & inx)
            Catch ex As NXOpen.NXException
                lw.Open()
                lw.WriteLine("Error: ")
                lw.WriteLine(ex.Message)
            End Try
        End If
    End Sub
End Module
thread561-265526: NXOpen. AskBoundaries + CamGeomType.CamDrive
