Amada FO3015 Fanuc C4000A/E Glass O-Rings
Laser went down couple days ago, (Gas Controller & sometimes Power Down) they called me in yesterday and I took a look at it, massive leak, so I finally going to get to troubleshoot this leak it has had a while which just got much worse (see thread http://www.eng-tips.com/viewthread.cfm?qid=366265 if your interested in the prequel).
So I built a vacuum rig from old vacuum pump I had so I could troubleshoot this without having to go through the tedious procedure Fanuc uses requiring power up, wait 9 minutes, power down, etc etc. plus this way I could isolate sections. So my leak was in the resonator. found it was an o-ring in the discharge tubes. Our laser for some reason has two different types used, the majority were white non jacketed o-rings that had a flat surface on the inside (unless time made it that way), the one that was leaking has a FEP encased red o-ring. I put in standard Buna 214's from grainger because it was only thing I could get right away today which worked. I do not want to keep them in because I don't think they will do well over time.
Ok to the point: Do you guys have a preference? I am not a fan of the FEP encased because on our 2000 they seem to fail also, they get rock hard on the inner surface, they are also obscenely expensive which is fine if they are really that much better. other lasers I worked on always used viton in similar setups, but those are oil cooled systems.
Cliffs: what do you like to use for orings on your glass? Do you also have a Vacuum Grease Preference? I use the 3M.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
RE: Amada FO3015 Fanuc C4000A/E Glass O-Rings
Finally, come out to Portland sometime and I will show you how to do a positive pressure leak test. Not always super accurate but damn easy.
found a lot of info here: https://www.parker.com/literature/ORD%205700%20Par...
Has anyone ever tried other types of O-rings in Fanuc Resonators? How often do you pull the tubes out and clean them? Think I am going to try once a year so I never have this issue again, though I hate opening up a resonator.
I thought about applying about 5 PSI to the tubes to check for leaks, but decided to just take my time and check all the optic seals and glass since it was long overdue. I set my pump up with a filter and stone so I go release the vacuum without sucking too much crap in, I think I will modify it so I can have N2 regulated backfilling instead, which then could also be used to apply positive pressure too as you suggest. I could also use it as a purge when removing optics. How much PSI is safe to apply to the resonator do you think?
I like the Fanucs, but that Vacuum leak procedure is crazy IMO.
