Where to Find Specs on Old Integral Recips?
Hi guys. I am doing a project involving some ancient Clark RA-32's. I am in need of performance data on the power end and the available cylinders. Where does a guy look for data on these old recips?
Thanks guys! Pete
RE: Where to Find Specs on Old Integral Recips?
i "believe" i have some old documentation for various clark, cb, worthington, etc. engine data, but it is at home. i get home tonight - hopefully, i remember to look.
http://www.networkintl.com/contents%2Fauction%2FQF...
some info in above link, but i think not what you need.
good luck!
sorry, i cannot find the documentation. probably lost it when hard drive failed.
try contacting one of the gas transmission companies as someone knows someone whom will have the engine data.
It may be worth giving Dresser-Rand Painted Post, NY tech services a call. They still maintain many records and information on the Clark Brothers engine lineup. If you have serial numbers available, they should be able to help you out. The information I have access to is limited.. Feel free to email me: bniessing@dresser-rand.com and I can put you in touch directly with our integral engine team.
Brian Niessing
BNessing,
That was a nice response. Site management prefers that we don't include linkable e-mail addresses in posts because it encourages some bad behavior by the bots. If KernOily has gotten the word, you might want to edit your post and pull out your e-mail.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Guys - Thanks for the great replies. Sorry for the delayed response. Brian - I will email you offline. Thanks again!! Pete
