NX Manager : Given matrix is not from required part Error
Hi All,
NX manager 8.5.3. Trying to load assembly and getting "Given matrix is not from required part" error message.. Any ideas what this means? How to resolve this?
Tried to look up on Siemens solution site, no clear way of how to resolve the situation.
Any ideas and thoughts are very much appreciated..
RE: NX Manager : Given matrix is not from required part Error
Well, it does not matter.. I tried to load fully and all components..It is still failing..
1. Close all parts
2. Menu->Preferences->Teamcenter Integration->Assembly Tab
3. Change the structure update on load to None and OK the dialogue (Take note of what this is set to initially).
4. Now attempt to load the assy
If it loads without error, this may point to a corrupt/ problematic BVR in Teamcenter. Ask your TC admin to investigate this further if this fixes the issue. (delete bvr, resave in NX etc.).
Just remember to set the preference back.
That option is already set to None..
