deflection formula 2 cont spans
Does anyone know where I can find the formula for the deflection along the x axis on a beam that is continuous over 3 supports but is loaded only along one span. I can find the max deflection but I want to graph the deflection
RE: deflection formula 2 cont spans
www.interactiveds.com.au/software/ConBeamU.zip
The Italian chart was helpful for another purpose.
Kam93 you are correct and I did that but I was having a problem with the second span. I was not getting the correct deflections.
I solved that by going from a to b for the first span and from c to b for the second span.
Its been a long time since I have used calculus!!!
