WELDING OF API 5L X70 40" PIPE
Hai Experts,
Please help me what type of filler metal (GTAW) and electrode (SMAW) to be used for the welding of 40" pipe API5L X70 pipe.Also please specify the AWS specification for the same..
RE: WELDING OF API 5L X70 40" PIPE
As a preliminar choice, you can consider the use of these electrodes:
SMAW: E7018, AWS 5.1, ASME SFA 5.1.
GMAW: E71T-1, AWS 5.20, ASME SFA 5.20.
GTAW: ER70S-6, AWS 5.18, ASME SFA 5.18.
El que no puede andar, se sienta.
What code and what country is the pipe?
Does your company have a quilified weld procedure or qualified welder and NDE?
