disappearing detail views in drawings
My detail views disappear (sometimes) when I save and close, then re-open the drawing, although the annotations and dimensions are still there.  If I select edit sketch (on the detail circle), then rebuild, the detail view comes back up.  Any adivice would be much appreciated.
RE: disappearing detail views in drawings
The way I handle it, is to just do a ctrl-q (forced rebuild) & usually everything goes back to normal.
Charley Leonard
CSWP
www.2Dto3D.com
2Dto3D
Thanks for the tip, I have been fighting this for weeks.
Bradley
You could try and go to the view menu and switch the hidden detail on and then switch it off on whatever view has disappeared. That usually works for me. Otherwise switching the Tangent Edges on and off might work as well.
I get the same thing in all of my drawings. I have reported this to Solidworks repeatedly but their stock responce is that they can't reproduce it.
I'm a mold designer and most of my drawings are 20-50 sheets. I have to go sheet by sheet CTRL-Qing each one.
This problem has plagued me since SWX 97 or 98. I don't think it's going away anytime soon.
Ken
