Static analysis step
I have a static analysis in which the load case are pressure loads.
I would like to ask what difference does it make what kind of stabilization should i use (or not use)
Thank you
RE: Static analysis step
If not necessary, don't use it.
If you use stabilization evaluate results carefully.
Thank you
