Select sub-assembly level components in scene
When editing scenes, is it possible to select sub- assembly level. In my case, I have created scene and completed the drawing. Then, I worked in the model and moved some component in sub assembly level. To correct that particular components, I went to scene, apply assembly on scene. It show all the components in last children level. i.e. each bolt and nuts. In my case, if it shows in the main sub-assembly level is enough. My requirement is , if I need I should expand that sub-assembly and select that particular part. If I don’t need, I should able to select whole sub-assembly without selecting it’s children one by one and give apply position. Kindly give any idea.
Suresh
