Need suggestions for a portable battery for a 250 W DC motor
Hi everyone! I need to find a portable power supply system for a specific motor and I don't know how to go about it since I have no experience in this area. My motor is a brushed DC motor from Maxon, specifically RE65 (model number 388987): voltage = 48V ; Nominal power: 250W. I want to use the motor in its "short-duration operation" mode, where I extract more power from it over a short duration of operation.
My requirements for the battery system are:
Power: 300W
Voltage: 48V
Portable
Preferably small and light
Most batteries I have researched are of the AC type. and the DC ones have very low voltage and/or power rating. Please suggest the type of battery I should research and also some companies that may supply the battery-or at least where to look. Please also suggest If I should prefer a different voltage too. The power however cannot be less than 300W. I have attached the product catalogue page for reference. Thank you!
Power: 300W
Voltage: 48V
Portable
RE: Need suggestions for a portable battery for a 250 W DC motor
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Keep in mind that it might be easier to switch motors at any point in the design.
And it isn't a drone project. But, this pathway might be helpful for me to find the battery that I need!
TTFN
Worth mentioning, you'll need to include safety features to protect equipment and people. Those powerful batteries can bite.
Keith Cress
My project is basically a lifting device, so it operates only for the short duration of lifting from H = 0 to 1000mm in around 15s. So cycle - wise , 300W is used per cycle. And right thereafter the device will not be used for a considerably large amount of time.
I was also looking at batteries used in electric bikes- they have adequate protection already and many of the batteries fall within my power and voltage range. Would this be a good area to look at, or is this also "overkill" ?
You'll see some very heavy gauge wiring being used, because providing a higher supply voltage is even more of an inconvenience than high current. It should be easy to work out the optimum voltage (and thus current, and thus necessary battery solution); just try a few options. It's likely to be a lower voltage that matches available Li-poly packs, or several packs in series.
If it's too long, I would suggest conventional alkaline D-cell type batteries. While D-cells are not specifically rated in terms of large discharge currents, they can do it. A typical AA battery can dump 10A for short durations, ~5 to 10 minutes. This is how most RC cars operate, and why they need to recharged so soon.
This sort of problem is all about margins, which is why a more complete set of requirements is mandatory.
TTFN
Two of those are typical packs for 12V and 24V applications and that's the 14.4V and 25.2V packs respectively.
The most commonly found Li-Ion battery is the 18650 which supplies about 2600mAhrs. You can draw about 2C from them possibly more for a short time.
If not hand held I'd be reaching for Lead Acid batteries as they can dish out a lot of current for a short while, are probably 1/5th the cost, and chargers are simple and cheap. No protection and charge balancing circuits are needed as they are for Li-Ion applications.
Keith Cress
As long as your capacity is sized for the idle time discharge, then you should be good to go. As an example, you could get: http://www.ebay.com/itm/MaxAMPS-11000mah-40C-25-9V..., which could theoretically stand idle for a 18 months and still provide at least 12 operations.
I used extremely conservative numbers:
> 40A*15s
> 50% derate capacity for high current
> 5%/month self discharge
TTFN
