NFPA 11 : foam expansion ratio for fire fighting
Hello
I am designing a fire fighting system for a storage tank according to the NFPA standard (NFPA 11 to be precise)
my question: is the expansion ratio for low expansion foam included in the discharge rate in the NFPA 11?
if it is included, what is the ratio
thank you in advance
RE: NFPA 11 : foam expansion ratio for fire fighting
I would also like to know wether NFPA states a certain depth for the foam, other standard does
thank you in advanvce
