Required shear force to combined tension and shear
I need to calculate the demand required shear force to combined tension and shear in beam to column flange connection .
the Loads:
Tension : 1.3 KN
Compression : -72.53 KN
Shear : 230.01 KN
Knowing that, a beam is sloped with 15 degree about horizontal axes .
RE: Required shear force to combined tension and shear
can you elaborate? Diagrams may help?
is this a student post ?
Thank you kiwitom 235
But the problem is solved
