Type(s) of sheetmetal used in Honda chasis?
Hi. I am extremely new to metal fabrication. I was wondering if anyone could tell me the type or types of sheetmetal used in production Honda automobiles. If the answer varies from car to car, to be more specific, the type(s) used on the EG6 Civic. I would also like to if there are any simple test I could perform to determine the metal type.
Thank you so much!
Thank you so much!
RE: Type(s) of sheetmetal used in Honda chasis?
I don't know how to test a stamping in-situ to determine the grade.
Cheers
Greg Locock
If you are trying to find out the grade of steel. a simple hardness test can work provided you choose an area that has not been work hardened.
There are different grades for different applications. These include formable grades where deep drawing is used to produce the shape, high strength low alloy grades for structural parts, dent resistant grades for body panels, martensitic grades for intrusion beams and bumpers, to mention a few.
When you say "automotive bodies", do you mean the exterior sheet metal panels (hood, roof, fenders, etc.) or do you mean the body-in-white, which is the main structure of the vehicle to which the rest of the components (powertrain, suspension, external panels, etc.) are attached?
GregLocock and gdodd both gave you good information. Many different grades of steel (or aluminum in the case of some vehicles) are used in the construction of the body-in-white, while fewer are used to stamp the external panels. Cold-rolled, mild steels are typically used in external panels and some body-in-white applications where the highest formability is required. Cold-rolled sheet also has the best surface appearance for exposed/painted panels. Structural parts of the body-in-white typically use hot-rolled steels (Bake Hardenable grades, HSLA, Dual Phase, etc.).
The following industry standards cover these types of materials:
SAE J2329 CATAGORIZATION AND PROPERTIES OF LOW CARBON AUTOMOTIVE SHEET
SAE J2340 CATEGORIZATION AND PROPERTIES OF DENT RESISTANT, HIGH STRENGTH, AND ULTRA HIGH STRENGTH AUTOMOTIVE SHEET STEEL
ASTM A 1008M STANDARD SPECIFICATION FOR STEEL, SHEET, COLD-ROLLED, CARBON, STRUCTURAL, HIGH-STRENGTH LOW-ALLOY AND HIGH-STRENGTH LOW-ALLOY WITH IMPROVED FORMABILITY
ASTM A 1011M STANDARD SPECIFICATION FOR STEEL, SHEET AND STRIP, HOT-ROLLED, CARBON, STRUCTURAL, HIGH-STRENGTH LOW-ALLOY AND HIGH-STRENGTH LOW-ALLOY WITH IMPROVED FORMABILITY
For more information, I recommend you visit the following websites:
Auto Steel Partnership at http://www.a-sp.org , especially the publications section. There is a huge amount of information here. One area with a lot of information on the various grades and where they are used is the Automotive Steel Design Manual (http://www.a-sp.org/database/default.asp?doc=28) Chapter 2. MATERIALS.
Other sites with good technical information:
http://www.aksteel.com/markets/carbon_steels.asp
and
http://www.aksteel.com/markets/pdf/Cold_Rolled.pdf
http://ussautomotive.com/auto/index.htm
http://www.dofasco.ca/PRODUCTS_AND_MARKETS/body_products_frameset.html
http://www.rougesteel.com/ (click on Product Information)
http://www.bethsteel.com/customers/tech_auto.shtml
Information on aluminum can be found at the following websites:
http://www.autoaluminum.org/
http://www.alcanautomotive.com/overview.html
http://www.alcoa.com/car_truck/en/home.asp
http://www.a-sp.org/database/custom/twbmanual/printsection.asp?hid=9
