Dual rising mains
Dual rising mains
Dual rising mains
Anybody know of a calculator that determines pump flow rates, velocities and head losses when using 2 rising mains of differing sizes? For example a Stage 1 140mm RM will be installed for a pump rate of 13 L/s and 7 years later an additional RM will be installed for up to 34 L/s mallowing possible use of either or both RM's depending on flows required - I can't get my head around the differing velocities and head losses - can it equalise in the system?
RE: Dual rising mains
You really need to sketch this out so we can understand what you're talking about, but it sounds like some sort of parallel or twin lines. Then your only common points are the pressure / head at the common points where they start or end.
If you have different sizes of pipe, you will find the larger one takes flow in much larger proportion than you might think.
any simple flow calculation off the web will give you answers based on either flow to find pressure drop or pressure drop to find flow for wholly liquid filled lines.
