Wind load combination
Got a question about wind loads and the use in combinations. Its been a while since I have done a wind load design.
For the combinations, it seems that wind loads are always 1.0 in ASCE 7-10
From PCI, they are 1.6. I always use 1.6. That is ASCE 7-5 reference.
Did ASCE 7-10 change the wind loads to be higher, thus a 1.0 can be used?
Feel stupid asking this question.
RE: Wind load combination
in 7-05, for example, in the central US, you'd use a wind speed of 90 mph. Now in 7-10 the speed is 115 mph for a basic risk building.
There is also no longer a wind importance factor as it is built in the multiple wind maps.
Probably to best educate yourself go to the commentaries in 7-10 where they discuss this a bit deeper.
