Hot Water Heat Exchanger
I am working on design-replacement of two older heating water boilers with two new condensing boilers- 3,300 MBH each. One of my colleagues mentioned that during summer we can use the heating water out of these boilers and preheat domestic water via a heat exchanger. Does this have any energy conservation benefit?
RE: Hot Water Heat Exchanger
what you save is space and possible some upfront cost, but you need more controls, possibly a larger boiler...so you may not really save much.
One problem also is you need a double-wall heat exchanger because your boiler system has anti-corrosion and biocide chemicals in them and if your HX has a leak, you don't want to drink that.
In the end there is a reason why domestic and heating hot water often is separated. I know some residential and "hack" installations use waterheaters as boilers with just a single-wall HX. but they all have in common that a code-official never had a look at that.
Only if your heating demand is so low as to make your burners inefficient would it seem to make an sort of sense.
Done right with the right type of domestic water heaters, there is the potential for energy savings.
The only way I can imagine there being energy savings is if the domestic water heaters are 'standard' efficiency gas fired heaters. Even so, you will need a complex sequence of operations to get the energy savings. And what saving you do get is minimal.
You could see utility cost savings if the domestic water heaters are electric and the cost of gas per BTUH is significantly lower than electricity.
A couple years ago, I worked on a new building project where we did something similar to what you are suggesting in an effort to get a couple extra LEED points. Royal pain in the a$$ to get setup right.
In my opinion, it's not worth the effort.
If you have an inefficient gas fired (or oil fired) hot water heater heater, you may save energy by using your condensing boilers to preheat domestic hot water, because your new boilers may have a better efficiency. That's if you don't have to keep an entire network of pipes hot during the summer just to preheat domestic water because you will use energy to keep those pipes on temperature and also the heat losses from the pipes may have to be cooled by your A/C if you have A/C in the building.
One efficient thing we do here is to install a high temperature heat pump to do simultaneaous cooling (for A/C and heat recovery) and heating. If you have a low temperature HWR (I'm assuming you have one because of the condensing boilers you are installing), you can reject the energy from the condenser of the high temperature heat pump to your hot water network. In winter and mid-season, that energy will heat your building and in summer, you can preheat domestic hot water and other things (reheat after deshumidification, preheat steam makeup, etc). Basically, we recover energy that otherwise would be lost in cooling towers, air evacuations and drain pipes to heat the building and domestic hot water . This is probabely out of reach for your boilers replacement project though.
