short stopp fitting description
I have short stopp fitting described as below. Is the information enough for me to determine the ANSI rating, max. test pressure and design pressure respectively? If yes, kindly explain more. Thank you
8" shortstopp fitting full encirclement 300 ser.
RE: short stopp fitting description
I do not know about anybody else but I have no idea what a "short stopp" fitting is.
Could you please furnish more information? How about a sketch, a picture or a description?
Sometimes its possible to do all the right things and still get bad results
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
TTFN
